Use Indigo to control HomeKit-enabled devices?
Wed Jan 11, 2017 3:50 pm
billearl offline
I would like to control a HomeKit-enabled device, such as the upcoming Incipio four-outlet Smart Power Strip, using Indigo and AppleScript from my iMac (macOS Sierra).
Currently, I control some Insteon on/off modules using an Insteon 2413U via Indigo and AppleScript, but the Incipio Smart Power Strip is a tempting alternative.
Is there way to do this now, without using Siri?
https://9to5mac.com/2017/01/04/incipio- ... wer-strip/
Wed Jan 11, 2017 4:06 pm
Re: Use Indigo to control HomeKit-enabled devices?
AFAIK, it's not possible for anything outside of a HomeKit app on iOS to control a HomeKit native device. The SDK for doing so only exists on iOS.
There are other options with other technologies however. I'm not positive that that particular one is supported by Indigo yet, but it probably wouldn't take a lot of work to get a definition in for it once someone has one.
[EDIT] Indigo does support controlling the 4 controllable outlets. Aeotec implemented the energy monitoring very badly so it will require some custom programming to get that part working (it's on the to do list but no ETA).
Wed Jan 11, 2017 6:39 pm
billearl offline
Thanks, Jay! I'll try the Aeotec Power Strip (and Aeotec Z-Stick, Gen5).
Thu Jan 12, 2017 3:48 am
durosity offline
If you want the best of both worlds you can get the Aeotec Power Strip and then setup HomeBridgeBuddy (viewtopic.php?f=204&t=17405) which would let you control that power strip via siri.
Thu Jan 12, 2017 11:02 am
billearl offline
Thanks, I might give that a try too, although I'm a bit old-school when it comes to verbally conversing with an electronic device (so far). For now, I use Butler menus to run AppleScript scripts to do my bidding.
Tue Jan 24, 2017 5:47 pm
billearl offline
Just to follow up, I switched out some Insteon on/off modules for the Aeotec Power Strip (and Aeotec Z-Stick, Gen5). I'm happy with the results so far, and switching seems faster and cleaner, and possibly more reliable.
I noticed that the Aeotec Z-Stick has to be reconfigured if it's unplugged, and then replugged, which is really a non-issue for me since I don't intend to unplug it. It didn't work with the one USB3 hub I tried it with. Also, the Z-Stick light flashes constantly because, apparently, it is not intended to be used plugged in, which is an Indigo requirement.
Tue Jan 24, 2017 6:37 pm
It shouldn't - what did you have to do to reconfigure it? And is it a Gen5 stick or the older Series 2?
Wed Jan 25, 2017 12:47 am
billearl offline
It's a Gen5. The reconfigure consisted only of resetting the Serial Port to "usbmodem1411". Connection type is the default "Local (physical)". It's plugged directly into my iMac. Shutting down and restarting the iMac causes no loss of the configuration setting.
After my previous post, I also had to re-sync the power strip, but that hopefully was only a one-off, not surprising for a new setup.
Wed Jan 25, 2017 10:14 am
Odd, it should have remembered the serial port. Try it again for us - just unplug the stick, wait a couple of minutes, then plug it back in and see if it automatically reconnects (as it's supposed to).
Wed Jan 25, 2017 1:49 pm
billearl offline
Thanks, Jay. It worked correctly this time. Perhaps insufficiently charged right out of the box on the first attempts?
Wed Jan 25, 2017 3:24 pm
Let us know if it happens again.
