How to monitor propane grill?
Wed Dec 07, 2016 5:37 pm
Mea culpa. I left the grill on. For several days. :oops:
What kind of sensor would work to detect that the grill stays hot too long? It's in a covered summer kitchen (lanai) so it's outside but not really exposed.
I also need to put a monitor on the underground propane tank. There was a thread about that on the boards somewhere. Need to find it.
Wed Dec 07, 2016 6:41 pm
roussell offline
Re: How to monitor propane grill?
I'd weigh the tank using a load cell and use a thermocouple for sensing the heat. An Arduino could get the data back to Indigo.
Terry
Wed Dec 07, 2016 6:57 pm
It's a 500gal underground tank. I did say it ran for several days before it noticed it was left on....
The thermocouple would work, I guess. I was hoping for possibly a Z-wave sensor so I don't need to add lots of new devices to maintain.
Wed Dec 07, 2016 7:06 pm
Colorado4Wheeler offline
You could go the cheap route and put in an inexpensive temperature monitor under the grill, even from a foot away it should be substantially warmer than the ambient temperature.
Wed Dec 07, 2016 7:31 pm
Yeah, that was sort of what I was thinking. Any specific units you think would work? I don't currently have any temperature sensors at all, except for the Ecobee sensors.
Wed Dec 07, 2016 7:48 pm
ryanbuckner offline
What about an RFXCOM with a temp monitor close by?
Wed Dec 07, 2016 7:51 pm
Pretty pricey just to get one temp sensor. I could put a Z-wave multi-sensor under the grill for a lot less. But I don't need motion, light, humidity, etc.
Wed Dec 07, 2016 7:53 pm
Those are probably the least expensive of the prebuilt types.
Wed Dec 07, 2016 10:48 pm
If you are into to it. Esp8622+varistor. $10 total
there a several plugins that can be used to get the info to indigo. Mqtt and arduino plugin.
Thu Dec 08, 2016 6:04 am
johnpolasek offline
But not if you already HAVE the RFX watching the refrigerator and freezer temperatures as I do... plus half a dozen other temp sensors scattered around the house, although those aren't anywhere near as critical as knowing before several hundred dollars of frozen food is about to thaw...
