matt (support) wrote:
0x70 0x05 0x01
Also try:
0x70 0x05 0x02
0x70 0x05 0x03
What is the Event Log results?
Z-Wave sent "Gordijn Woonkamer" raw command [70 05 01]
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 14 0A 32 02 21 44 00 00 0C 2A 00 00 86
Z-Wave Debug . . requestMeterLevel: node 020, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 31.14 kWh (float: 31.140000)
Z-Wave Debug received "HIFI Wall Plug" energy total to 31.14 kWh
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 14 06 31 05 04 22 03 28 DC
Z-Wave Debug . . requestVarSensorStatus: node 020, endpoint None, type 4, raw value 2203...
Z-Wave Debug . . requestVarSensorStatus: 80.8 W (float: 80.800000)
Z-Wave Debug received "HIFI Wall Plug" power load to 80.8 W
2016-12-03 12:21:24.062 Z-Wave sent "Gordijn Woonkamer" raw command [70 05 02]
2016-12-03 12:21:28.724 OWServer Getting OWServer data...
2016-12-03 12:21:28.993 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 31 06 31 05 04 22 00 05 D7
2016-12-03 12:21:28.994 Z-Wave Debug . . requestVarSensorStatus: node 049, endpoint None, type 4, raw value 2200...
2016-12-03 12:21:28.995 Z-Wave Debug . . requestVarSensorStatus: 0.5 W (float: 0.500000)
2016-12-03 12:21:28.996 Z-Wave Debug received "Boiler" power load to 0.5 W
2016-12-03 12:21:29.122 OWServer Total of 1 servers polled.
2016-12-03 12:21:29.124 OWServer Total of 4 devices updated.
2016-12-03 12:21:29.125 OWServer OWServer data parsed successfully.
2016-12-03 12:21:29.682 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 14 06 31 05 04 22 02 A0 55
2016-12-03 12:21:29.683 Z-Wave Debug . . requestVarSensorStatus: node 020, endpoint None, type 4, raw value 2202...
2016-12-03 12:21:29.684 Z-Wave Debug . . requestVarSensorStatus: 67.2 W (float: 67.200000)
2016-12-03 12:21:29.685 Z-Wave Debug received "HIFI Wall Plug" power load to 67.2 W
2016-12-03 12:21:30.685 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 04 22 01 B3 52
2016-12-03 12:21:30.687 Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 4, raw value 2201...
2016-12-03 12:21:30.688 Z-Wave Debug . . requestVarSensorStatus: 43.5 W (float: 43.500000)
2016-12-03 12:21:30.688 Z-Wave Debug received "Espresso Machine" power load to 43.5 W
2016-12-03 12:21:30.760 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 14 06 31 05 04 22 01 DD 2B
2016-12-03 12:21:30.761 Z-Wave Debug . . requestVarSensorStatus: node 020, endpoint None, type 4, raw value 2201...
2016-12-03 12:21:30.762 Z-Wave Debug . . requestVarSensorStatus: 47.7 W (float: 47.700000)
2016-12-03 12:21:30.763 Z-Wave Debug received "HIFI Wall Plug" power load to 47.7 W
2016-12-03 12:21:30.985 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 31 06 31 05 04 22 00 06 D4
2016-12-03 12:21:30.987 Z-Wave Debug . . requestVarSensorStatus: node 049, endpoint None, type 4, raw value 2200...
2016-12-03 12:21:30.988 Z-Wave Debug . . requestVarSensorStatus: 0.6 W (float: 0.600000)
2016-12-03 12:21:30.988 Z-Wave Debug received "Boiler" power load to 0.6 W
2016-12-03 12:21:31.638 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 04 22 2E FD 33
2016-12-03 12:21:31.639 Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 4, raw value 222E...
2016-12-03 12:21:31.640 Z-Wave Debug . . requestVarSensorStatus: 1202.9 W (float: 1202.900000)
2016-12-03 12:21:31.641 Z-Wave Debug received "Espresso Machine" power load to 1202.9 W
2016-12-03 12:21:33.982 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 31 06 31 05 04 22 00 05 D7
2016-12-03 12:21:33.984 Z-Wave Debug . . requestVarSensorStatus: node 049, endpoint None, type 4, raw value 2200...
2016-12-03 12:21:33.984 Z-Wave Debug . . requestVarSensorStatus: 0.5 W (float: 0.500000)
2016-12-03 12:21:33.985 Z-Wave Debug received "Boiler" power load to 0.5 W
2016-12-03 12:21:34.985 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 31 06 31 05 04 22 00 06 D4
2016-12-03 12:21:34.986 Z-Wave Debug . . requestVarSensorStatus: node 049, endpoint None, type 4, raw value 2200...
2016-12-03 12:21:34.987 Z-Wave Debug . . requestVarSensorStatus: 0.6 W (float: 0.600000)
2016-12-03 12:21:34.988 Z-Wave Debug received "Boiler" power load to 0.6 W
2016-12-03 12:21:35.541 Z-Wave Debug SENT sendRawZwaveCommand: 01 0A 00 13 12 03 70 05 03 25 75 D1
2016-12-03 12:21:35.566 Z-Wave sent "Gordijn Woonkamer" raw command [70 05 03]
2016-12-03 12:21:36.635 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 04 22 01 67 86
2016-12-03 12:21:36.636 Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 4, raw value 2201...
2016-12-03 12:21:36.637 Z-Wave Debug . . requestVarSensorStatus: 35.9 W (float: 35.900000)
2016-12-03 12:21:36.638 Z-Wave Debug received "Espresso Machine" power load to 35.9 W
2016-12-03 12:21:37.637 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 03 06 31 05 04 22 00 19 F9
2016-12-03 12:21:37.638 Z-Wave Debug . . requestVarSensorStatus: node 003, endpoint None, type 4, raw value 2200...
2016-12-03 12:21:37.639 Z-Wave Debug . . requestVarSensorStatus: 2.5 W (float: 2.500000)
2016-12-03 12:21:37.640 Z-Wave Debug received "Espresso Machine" power load to 2.5 W
2016-12-03 12:21:37.985 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 31 06 31 05 04 22 00 05 D7
2016-12-03 12:21:37.987 Z-Wave Debug . . requestVarSensorStatus: node 049, endpoint None, type 4, raw value 2200...
2016-12-03 12:21:37.988 Z-Wave Debug . . requestVarSensorStatus: 0.5 W (float: 0.500000)
2016-12-03 12:21:37.988 Z-Wave Debug received "Boiler" power load to 0.5 W
2016-12-03 12:21:50.660 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 14 06 31 05 04 22 02 41 B4
2016-12-03 12:21:50.662 Z-Wave Debug . . requestVarSensorStatus: node 020, endpoint None, type 4, raw value 2202...
2016-12-03 12:21:50.663 Z-Wave Debug . . requestVarSensorStatus: 57.7 W (float: 57.700000)
2016-12-03 12:21:50.664 Z-Wave Debug received "HIFI Wall Plug" power load to 57.7 W
matt (support) wrote:Also, with the debug logging still enabled, are any commands sent to Indigo when you manually press the open/close buttons on the module itself?
No also manually press it does not report back. Only polling gives me status.
