DHS Motion Sensor Error (onOffState not defined)
Tue Dec 08, 2015 12:54 pm
Hank.wheeler offline
Hi, I am having trouble getting a DHS Motion Sensor to work ... see log file below ... any ideas?
9 Dec 2015 4:44:01 am
Z-Wave Indigo Device "Entry - Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.355
Node ID: 12
Model: Binary Sensor
Model ID: 11805501
Manufacturer: Digital Home Systems
Manufacturer ID: 0097
Protocol Version: 2.97
Application Version: 0.64
Model Definition Version: 0
Library Type: 6
Class Name: Binary Sensor
Class Hierarchy: 04 : 20 : 00
Command Class Base: 31
Command Versions: 20v1 80v1 84v1 85v1 86v1 71v1 70v1 60v2 30v1 31v1 72v1
Multi-Endpoint Types: 1:(21 : 00), 2:(21 : 00)
Multi-Endpoint Classes: 1:[31], 2:[31]
Features: routing, battery, beaming, waking
Neighbors: 3
Associations: 1:[1]
Config Values: - none -
Z-Wave received "Entry - Sensor" status update is on
Error device "Entry - Sensor" state key onOffState not defined (ignoring update request)
9 Dec 2015 4:44:36 am
Z-Wave received "Entry - Sensor" status update is off
Thu Dec 10, 2015 10:29 am
Re: DHS Motion Sensor Error (onOffState not defined)
Did you just recently create the device in Indigo or is this one you've had for a while? Try deleting the device in Indigo then recreating it.
Thu Dec 10, 2015 2:35 pm
Hi Jay ... This sensor is a new addition.
I deleted the device, then created/synced it again for same result ... what am I doing wrong?
11 Dec 2015 6:30:15 am
Z-Wave Syncing - started for device "012 - Binary Sensor"
Z-Wave Syncing - retrieved module neighbors list: 3
Z-Wave Syncing - requesting neighbor list update of "012 - Binary Sensor"
Z-Wave Syncing - neighbor list update complete (no change)
Z-Wave Syncing - assigning return route to "012 - Binary Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Digital Home Systems - 0097, Binary Sensor - 11805501
Z-Wave Syncing - retrieved protocol version 2.97, app version 0.64
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Binary Sensor : -- (04 : 20 : 00, base 30)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v1 85v1 86v1 71v1 70v1 60v2 30v1 31v1 72v1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "012 - Binary Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved multi-endpoint types: 1:(21 : 00), 2:(21 : 00)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[31], 2:[31]
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "012 - Multilevel Sensor"
Z-Wave Syncing - created device "012 - Multilevel Sensor 2"
Z-Wave Syncing - complete
Z-Wave sent "012 - Multilevel Sensor" status request
Z-Wave sent "012 - Multilevel Sensor 2" status request
Z-Wave received "012 - Multilevel Sensor" status update battery level 100%
Z-Wave received "012 - Multilevel Sensor 2" sensor update to 57%
Z-Wave received "012 - Multilevel Sensor 2" units changed to %
11 Dec 2015 6:31:18 am
11 Dec 2015 6:31:35 am
Z-Wave received "012 - Multilevel Sensor" status update is on
Error device "012 - Multilevel Sensor" state key onOffState not defined (ignoring update request)
Thu Dec 10, 2015 10:35 pm
Indigo doesn't have a device definition for that sensor yet, but does support the DHS MultiSensor model DHS-ZW-SNMT-01.
What is the model number of the particular sensor you have, and what capabilities does it have? The one Indigo supports has motion, temperature, and luminance sensors.
Fri Dec 11, 2015 1:28 pm
Device info below:
Cat No. DHS-SNS-MS-DHS
The DHS Z-Wave Multi-Sensor is a smart, battery-powered Motion/Temperature/Luminosity sensor. This device is capable of sending Z-Wave commands to any associated Z-Wave devices within its Z-Wave network when someone moves inside a room or the Temperature/Luminosity changes.
Wed Dec 16, 2015 10:39 am
It looks like this one matches the existing device profile we have so we will add support for it to the next Indigo 6.1 dot release.
Wed Dec 16, 2015 3:26 pm
Thanks Matt, much appreciated.
Thu Jan 21, 2016 2:05 pm
I've added the new device definition for this multi sensor to v6.1.5 (now available).
Sat Jan 23, 2016 6:09 pm
Please get the just-released Indigo 6.1.6 installer. There was an issue in 6.1.5 which might effect this change.
Mon Feb 01, 2016 7:14 pm
SOLVED: DHS Motion Sensor Error (onOffState not defined)
Working great now ... thank you very much!
