Z-Wave Greenwave 5 Port PowerNode (UK model) - more issues
Sun Jun 07, 2015 2:49 pm
KostasV offline
Hello everyone,
I'm using the UK model for a few weeks and it is not a 'frustration' free time.
I have plugged in only two appliances to it and kept the other 3 sockets on just to see how it goes and for some strange reason I see through indigo 'load' on 3 of them? Where does the extra load go to as only two physical sockets are plugged in???
The problem goes away briefly with a "Define and Sync" but then appears again... Somewhere I read that there is a 'master' plug device in there that maybe indigo is getting confused?
I have it configured to be polled every 5mins - if that makes any difference.
Anyone else facing similar issues?
Kostas
Sun Jun 07, 2015 5:02 pm
Re: Z-Wave Greenwave 5 Port PowerNode (UK model) - more issu
You asked a similar / related question here: viewtopic.php?t=14146
That thread also has a link to another thread; between them they give (good?) info about this model - though a lot of it is from me, through trial and error.
Having said that, on this following thread, another user and myself have had issues with low-polling times on this device.
viewtopic.php?t=14149
The device appears to give false info if you poll it too often.
If you send it an on/off command it always responds with its new status and power draw for that socket, so you might find you don't need it on 5 minute poll?
Mon Jun 08, 2015 2:12 pm
KostasV offline
Thanks howartp! I posted a new topic as I thought this might be a different issue.
I will change the polling and see what happens.
Kostas
