matt (support) wrote:Unfortunately, they removed the capability to change the motion sensor sensitivity and LED brightness in the firmware of the Motion Sensor II. We haven't added UI yet for the other settings, [size=150][size=150][b]but I'm curious which ones you think are priority (most interesting) to have control over?
[/b][/size][/size]
We will not be adding support for the Insteon Hub as a controller.
Command 1 Byte: 0x2E
Command 2 Byte: 0x02
Send Extended Message: CHECKED
D1-D14 Bytes: 0x00
Copy the results out of the Event Log and paste them into a reply for me, and I'll see if I can come up with the parameters to change that one particular setting.
Sent INSTEON "New Motion Sensor II" raw insteon command (2E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00; ack: 02)
Debug SENT: insteon 44.85.08 4F.9C.AD 10 2E 02
Debug SENT: extended data 00 00 00 00 00 00 00 00 00 00 00 00 00 D0
Debug RCVD: insteon 4F.9C.AD 44.85.08 20 2E 02
Debug RCVD: ack from 4F.9C.AD for command 2E 02
Debug SENT: GetImInfo packet to see if connection is alive
Debug processing unexpected packet 02 51 (trying to send a command)
Debug RCVD: insteon 4F.9C.AD 44.85.08 1F 2E 02
Debug RCVD: extended data 01 01 40 50 C0 80 3C 3C 05 00 21 00 00 60
Debug waiting 1084 for idle input queue
Debug SENT: insteon 44.85.08 4F.9C.AD 10 2E 00
Debug SENT: extended data 00 00 00 00 00 00 00 00 00 00 00 00 00 D2
Debug RCVD: insteon 4F.9C.AD 44.85.08 20 2E 00
Debug RCVD: ack from 4F.9C.AD for command 2E 00
Sent INSTEON "New Motion Sensor II" raw insteon command (2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Debug waiting 57 for idle input queue
Debug timeout signal
Debug SENT: insteon 44.85.08 4F.9C.AD 10 2E 01
Debug SENT: extended data 00 00 00 00 00 00 00 00 00 00 00 00 00 D1
Debug prism tunnel watchdog - connection test passed
Debug RCVD: insteon 4F.9C.AD 44.85.08 2F 2E 01
Debug RCVD: ack from 4F.9C.AD for command 2E 01
Sent INSTEON "New Motion Sensor II" raw insteon command (2E 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00; ack: 01)
Debug SENT: insteon 44.85.08 4F.9C.AD 10 2E 03
Debug SENT: extended data 00 00 00 00 00 00 00 00 00 00 00 00 00 CF
Debug RCVD: insteon 4F.9C.AD 44.85.08 2B 2E 03
Debug RCVD: ack from 4F.9C.AD for command 2E 03
Sent INSTEON "New Motion Sensor II" raw insteon command (2E 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00; ack: 03)
Debug RCVD: insteon 4F.9C.AD 44.85.08 1B 2E 03
Debug RCVD: extended data 01 01 BE D3 78 C6 96 78 00 00 00 00 00 F0
