Edit Folder Name
Thu Nov 09, 2017 6:56 am
Midnightsun offline
Edit Folder Name
I simply cannot figure out how to edit my folder name for device location. Can someone point me in the right direction please.
Thu Nov 09, 2017 7:35 am
autolog offline
Re: Edit Folder Name
Not sure if this is what you are looking for:
  • Select any device in the Indigo UI
  • Click the + sign in the bottom left.
    This will create a new folder which you can rename.
    You can rename/delete an existing folder by selecting it and then clicking the gear symbol in the bottom left.
  • Select the device in the main window (that you want to be in the new folder) and drag it to the folder name on the left-hand side.
    The device will be moved to the folder and the folder name updated in the device
Hope this helps? :)
Thu Nov 09, 2017 3:12 pm
Midnightsun offline
Thanks that helped. One thing I should mention is every new device is entered in a device folder. If you create a new folder, and want to move it there, simply drag and drop it into the new folder.
