Hi all, just checking in to see if anyone else has had no response from their HomePods and Indigo devices connected via HomeKit Bridge plugin. The Home app says no response on any of the devices from Indigo. I realize it is no longer supported but it is very intuitive and worked mostly well up until 2022.2.0. I've unplugged all of the HomePods and AppleTV, rebooted the Indigo Mac, etc, but she's not coming back.
Edit: One thing to note is that this time around I moved the database to the new default location under /Library/Application Support/Perceptive Automation from my home documents folder. I wonder if that has something to do with it? The plugin and associated files seem to be in the default location.
Lastly, is IndigoPluginHost3.app a valid plugin for Indigo? I thought I had it blocked in the firewall as it seemed related to another HomeKit plugin I decided not to use as the old one.worked, but now it seems I can't connect to Indigo touch without it being allowed.
Started plugin "HomeKit Bridge 1.0.2"
HomeKit Bridge Warning
# HOMEKIT BRIDGE HIDDEN ITEMS WARNING #
# You have 82 Indigo items being hidden, you can manage these #
# from the plugin menu. #
HomeKit Bridge Attempting to start 'Homekit Server'
Waiting for external plugins to initialize
HomeKit Bridge HomeKit Bridge is running the latest version, no update needed
HomeKit Bridge Server 'Homekit Server' has successfully started, you can use your HomeKit apps or Siri for this accessory
HomeKit Bridge HomeKit Bridge is loaded and ready to use
