Hi from Germany,
migration done today to my new MacMini (16GB, 13.0 Ventura). Problems with the web-server (solution in this forum)solved. But now, i have no idea how to solve my problem:
Some Plugins don't work. The most important for me, the HUE plugin.
In the menu there is no Config entry. And if i try to enable the plugin i got a strange message in log. It seem to by a python problem with the new M2 architecture.
- Code: Select all
Reloading plugin "Hue Lights 2022.12.41" using API v3.0
Starting plugin "Hue Lights 2022.12.41" (pid 9624)
Hue Lights Error Error in plugin execution InitializeMain:
File "plugin.py", line 47, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Hue Lights.indigoPlugin/Contents/Server Plugin/colormath/color_objects.py", line 4, in <module>
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/numpy/__init__.py", line 144, in <module>
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/numpy/core/__init__.py", line 49, in <module>
type:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.10 from "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/MacOS/IndigoPluginHost3"
* The NumPy version is: "1.22.3"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: dlopen(/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/numpy/core/_multiarray_umath.cpython-310-darwin.so, 0x0002): tried:
'/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/numpy/core/_multiarray_umath.cpython-310-darwin.so' (mach-o file, but is an incompatible architecture
(have 'x86_64', need 'arm64')), '/System/Volumes/Preboot/Cryptexes/OS/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-
packages/numpy/core/_multiarray_umath.cpython-310-darwin.so' (no such file), '/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-
packages/numpy/core/_multiarray_umath.cpython-310-darwin.so' (mach-o file, but is an incompatible architecture (have 'x86_64', need 'arm64'))
Im sure, i have python3 installed.
- Code: Select all
XXXXXX@Mac-mini ~ % pip3 --version
pip 21.2.4 from /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/pip (python 3.10)
Any ideas ? Somebody ?
Dirk
