MacOS 13 / Ventura Compatability ?
Tue Jun 07, 2022 8:45 am
SearchCz offline
Any idea if Indigo 2022.1 is going to run under Monterey?
Oops, I meant Ventura. I'm already running under Monterey.
Tue Jun 07, 2022 9:11 am
dduff617 offline
Re: MacOS 13 / Ventura Compatability ?
I'm running it under Monterey and it is working fairly well for me. I recently (~1 month ago) migrated from an older mac that would not support anything beyond Catalina.
Tue Jun 07, 2022 9:27 am
I'm a bit confused. The title says "Ventura" but the post says "Monterey". Indigo runs fine on Monterey.
Users SHOULD NOT upgrade to Ventura until Indigo Corporate says it's okay.
Tue Jun 07, 2022 10:18 am
Which won't be until sometime after the official release later this year. If you want to try it out on a "spare" system, go ahead. But don't bother reporting issues. ;)
Tue Jun 07, 2022 10:40 am
Assuming you mean Ventura, it will (once macOS Ventura FINAL ships from Apple later this year). We support all macOS releases and this one will be no different (the firedrill earlier this year is an example - it took us by surprise and it took longer, but we did update to support 12.3).
HOWEVER - you should not expect it to run on beta macOS releases. It may, it may not, but we don't support beta releases.
Wed Jun 08, 2022 7:27 am
SearchCz offline
My mistake, corrected. Any admins who would like to implement the [s] BBCode?
Fri Aug 05, 2022 8:58 am
boisy offline
I went ahead and took the risk of upgrading my Mac mini M1 to Ventura Developer Beta 4. Everything "seemed" to be running fine, but then I noticed multiple entries in my Indigo log:
Aug 5, 2022 at 9:50:32 AM
   Z-Wave                          received "030 - Temperature" sensor update to 47.3 °F
   Trigger                         Westgate - Process MQTT Shop Message
   Z-Wave                          received "030 - Humidity" sensor update to 55%
   Z-Wave                          received "030 - Temperature" status update battery level 40%
This is for a brand new Zoom ZSE44 Temperature and Humidity sensor that I deployed only two days ago, and already the battery is at 40%. I deployed a second one yesterday and the battery is at 5%.
It's not just this device. Other Z-Wave devices are coming in with multiple rapid log entries:
Aug 5, 2022 at 9:29:46 AM
   Z-Wave                          received "Westgate - Shop Illuminance" sensor update to 250 lux
I'm not sure if this signals some type of issue with Z-Wave devices as a whole with Indigo 2022.1.2 and my Aeotech Z-Wave USB adapter, but something is definitely wrong.
Fri Aug 05, 2022 1:21 pm
Did you have any of those deployed before the upgrade? I can't see any reason why an OS upgrade would cause this, but I suppose anything is possible.
Fri Aug 05, 2022 4:41 pm
Try unplugging your Z-Wave controller from the Mac for a bit, and also try a Mac reboot to see if that changes the behavior.
Tue Aug 09, 2022 7:59 am
boisy offline
Thanks for the suggestions. I've done those things, and also updated to developer beta 5 yesterday. The issue has abated somewhat, but in certain cases I'm seeing multiple Z-Wave messages of the same type in series in a short time.
I'll keep an eye on this.
Tue Aug 09, 2022 9:36 am
I don't believe you answered my question: did you have any of those in use before you updated to Ventura? And did they exhibit the same behavior before the upgrade?
Tue Aug 09, 2022 1:42 pm
boisy offline
Apologies, Jay.
No, I didn't see this behavior prior to updating to Ventura beta. I did deploy the Zoom temperature sensor a few days before upgrading and it was working without issue or duplication before the upgrade.
Tue Oct 25, 2022 10:09 am
sumocomputers offline
Now that macOS 13 is officially out, what is the status of compatibility with Indigo 2022.1.2?
I will hold off until I hear official word.
Tue Oct 25, 2022 3:02 pm
Tue Oct 25, 2022 5:28 pm
roquej offline
I tried the RC. Just know that I am not even updating my main work MacBook Pro until at least the first update.
Looks promising, but needs a bit more time to bake.
JP
