Mac Mini or Macbook
Sun May 08, 2022 8:34 am
pnm offline
Mac Mini or Macbook
I have a late 2014 Mac Mini running Catalina, which has been running Indigo since it was new. I'm getting to the point of not wanting to perform any upgrades in case it doesn't come back. It's also running headless so I have to access it via VNC, which is not the best.
What would be the best new/second hand hardware to run the latest version of Indigo on?
Sun May 08, 2022 9:34 am
racarter offline
Re: Mac Mini or Macbook
I’m running Indigo on a M1 Mac Mini. Works fine. :)
That was the cheapest ‘new’ solution when the MacBook I was using for Indigo gave up the ghost.
Sun May 08, 2022 6:46 pm
ryanbuckner offline
i'm running on a 2012 Mac Mini running Catalina on 16GB RAM. I've considered upgrading as well but performance of my Indigo server has no problems .
Mon May 09, 2022 5:55 am
jalves offline
No particular suggestion but I think the MacBook has a very slight edge. In the case of a brief power interruption it has essentially a built in UPS. Those occasional flickers on the power line won't cause a reboot.
Jeff
Mon May 09, 2022 9:27 am
norcoscia offline
I have a small UPS on my indigo mini, I have my mini set up to auto power down if the power is off for more than a min or so - I find that much cheaper than buying a laptop and paying for a screen I don’t need (since I run it remote). Either way works great, it just depends on how much stuff you need to hook up to indigo and how much money you want to spend. - for me the mini worked best for my Indigo setup and budget….
_______
Norm
Mon May 09, 2022 11:07 am
eme jota ce offline
+1 for laptop
As I've been transitioning from Indigo toward Z-wave and other protocols, a laptop became more useful than a Mini.
For example, including / excluding Z-Wave devices that are far from the Indigo server's usual location is much easier when brining the laptop close to the device. That combined with the fact that new Z-wave sticks lack the old inclusion / exclusion button and need to be plugged into the Indigo server, a mini wouldn't work well in some situations.
Mon May 09, 2022 1:18 pm
pnm offline
If I get another Mac Mini, I was considering the Astropad Luna, so I can use my iPad as a display when needed, though I'm not sure indigo requires all the power of a new Mac.
I've also got the Mini on a UPS and was going to swap to the latest Z-Stick. I hadn't realised that inclusion used a different method.
Mon May 09, 2022 1:50 pm
Z-Wave's NWI feature no longer requires carrying your stick around, which is why the Gen 7 stick doesn't have a physical button. If you have range issues doing an network include, then you may have sporadic issues with the device once included anyway since there isn't a good/reliable signal. I would highly recommend dealing with the range/signal issue rather than trying to carry a stick/Mac around trying to get an include to work...
Mon May 09, 2022 4:25 pm
norcoscia offline
For me, remoting into my Indigo mini using my IPAD has worked great - I just take the IPAD to where I’m installing my new device and do all the inclusion work on the IPAD - I don’t use my Indigo machine for anything that requires moving it around or a laptop would have been my go-to set up. My first indigo setup was on a small Mac laptop and it was great, but when that machine became obsolete my retiree budget and all the stuff I needed hooked up drove me to an intel based Mac mini with lots of ports….
_______
Norm
