Hi folks,
We recently had to blow away the config of our working Indigo 6.x system. On the same MacMini, we installed a fresh Big Sur system and installed Indigo 2021.2 on it, along with a new database.
We had to register the powerlinc module to the new 2021 db, which was successful, and started to re-introduce our eight 2744D light switches. The registration of the 2744D modules were all successful. Communication to/from the modules and the powerlink/Indigo is clean and quick.
Commands and status/acknowledgements to the various modules are all successful, according not only on the event log, but on the switch status LEDs. Everything looks great BUT...the actual physical manifestation of the commands from Indigo are not applied!!! Meaning, the lights don't actual turn off/on/dim via Indigo. However, if I adjust/turn off/on the lights via the physical toggle on the switch, the lights adjust and actually send the status to Indigo. This result can be duplicated on all eight 2744D switches.
Any ideas on what's going on here?
Thanks in advance!
