MODERATOR NOTE: Indigo 2022.1 has solved the compatibility issue with macOS Monterey 12.3+.
Just moved my entire Indigo 2021.2 folder in Application Support to my new machine.
But when I try to start Indigo, it won't connect to the Indigo server to authenticate my license. Eventually I get "Failed to connect to Indigo Server. The Indigo Server is either unreachable over the network or it is not running."
So, I can't get my home automation up and running. How do I get around this? My network is working fine, I just can't get to Indigo's server to authenticate.
If I try to go to File -> Select Database, I can't. It's grayed out.
If I try to go to Indigo -> License Details, that's also grayed out.
