Replace INSTEON device with z-Wave device
Wed Mar 02, 2022 10:33 am
norcoscia offline
Is it possible to swap in a Z-Wave open / close sensor to replace an open / close INSTEON sensor and have everything automatically move over to the new device (stuff on control pages, triggers and schedules etc.)
I looked at the docs and could find a process to replace a failed z wave device with another z-wave device but could not find anything about swapping an INSTEON device with a z-wave device - if docs exist for that process could someone point me to them (assuming it is possible). Thanks…
_______
Norm
Thu Mar 03, 2022 2:14 pm
Re: Replace INSTEON device with z-Wave device
In general, it should just work. You'll want to just edit the existing device type to Z-Wave then include/re-sync it all within the context of the old device. For most Z-Wave open/close sensors the first device Indigo creates should be the open/close sensor and it'll just be a normal on/off binary state sensor like the Insteon version. It might also create some additional devices as well (if for example it has a temperature sensor). Problems arise if one is trying to replace 1 complex module (say a multi-sensor that supports Motion + Temperature + Humidity + LUX) with another multi-sensor that doesn't support the same number of sensors or they are inserted in a different order into Indigo's device group.
All that said, it wouldn't hurt to make a backup of your Indigo Database file just in case things do "line up" correctly and your existing Triggers, Schedules, Control Pages point to the wrong device. If that is the case you'll probably end up just having to manually fix them, but it never hurts to have an old copy of the Database file in case you want to revert.
Thu Mar 03, 2022 2:16 pm
norcoscia offline
OK, thanks!
_______
Norm
