Can't get local server running correctly after migrating
Wed Jan 19, 2022 4:43 pm
mwarner offline
I recently moved my Indigo 7.5 setup over to a new 2018 MacMini. I wanted to run everything through its paces on the new mini before upgrading to the latest version of Indigo and dealing with all of the Alexa modifications etc.
All seems to be working fine, except the local server so I cannot make connections via Indigo Touch on my iPhone. All of the right boxes seemed to be checked in the Start Local Server window and the Firewall is turned off on the Mini. The mini is connected to my Verizon router via an ethernet switch. Wondering where I should start to trouble shoot?
Thu Jan 20, 2022 5:16 pm
Re: Can't get local server running correctly after migrating
Unplug your home router and DSL/cable modem, then wait 10 minutes (for everything to come back online) and stop/restart the Indigo Server.
Try then connecting via Indigo Touch. Does it show your Indigo Server on the settings screen?
If it doesn't work, then open the Event Log window and copy/paste its contents into a reply for us.
Sat Jan 22, 2022 9:19 am
mwarner offline
Followed your directions, but still not working. On the phone under the settings screen, I get the could not connect to server error pop up.
Here is what my event log looks like after attempting to re-enter my log in info and start the server once more: Note: I've removed my user name on the reflector login line below. String at the end tells me reflector connection is not working, but have no idea what to do next.
Jan 22, 2022 at 10:12:06 AM
Starting Indigo Server version 7.5.0 (Mac OS X 10.16)
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7.5/Databases/My House.indiDb"
Waiting for client to connect
Bonjour registered "Indigo - My House"
Indigo Cocoa client connected
Reflector starting reflector connection to https://.indigodomo.net
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
WebServer disconnecting from Indigo server
WebServer client disconnected
Waiting for client to sync
Loading disabled plugins
Found disabled plugin "DIRECTV DVR Control 1.1.0"
Found disabled interface "Virtual Devices 7.4.1"
Found disabled plugin "Global Property Manager 7.4.1"
Found disabled plugin "Vera Bridge 1.0.8"
Found disabled plugin "Timers and Pesters 7.4.1"
Found disabled plugin "Google Voice SMS 1.2.0"
Found disabled plugin "Airfoil Pro 7.5.0"
Found disabled interface "INSTEON Commands 7.5.0"
Found disabled plugin "SQL Logger 7.5.0"
Found disabled plugin "EasyDAQ Relay Card 7.5.0"
Found disabled plugin "Airfoil 1.1.11"
Found disabled plugin "iTunes 7.5.0"
Found disabled plugin "iCal Alarm Processor 7.4.1"
Loading internal plugins
Loading interface "Z-Wave 7.5.0"
Starting interface "Z-Wave 7.5.0" (pid 5528)
Loading plugin "Action Collection 7.5.0"
Starting plugin "Action Collection 7.5.0" (pid 5529)
Loading plugin "Growl 7.4.1"
Starting plugin "Growl 7.4.1" (pid 5530)
Loading plugin "NOAA Weather 7.4.1"
Starting plugin "NOAA Weather 7.4.1" (pid 5531)
Started plugin "Growl 7.4.1"
Started plugin "NOAA Weather 7.4.1"
Started plugin "Action Collection 7.5.0"
Started interface "Z-Wave 7.5.0"
Z-Wave connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem14301 (firmware 1.00, SDK unknown)
Z-Wave Error device "back deck" should be re-synced using the "Define and Sync..." button in the device edit dialog (the internal device definition has been revised)
Waiting for internal plugins to initialize
Loading external plugins
Loading plugin "Ecobee 1.1.1"
Starting plugin "Ecobee 1.1.1" (pid 5540)
Loading plugin "Pushover 1.1.5"
Starting plugin "Pushover 1.1.5" (pid 5541)
Loading plugin "Alexa-Hue Bridge 3.0.35"
Starting plugin "Alexa-Hue Bridge 3.0.35" (pid 5542)
Started plugin "Pushover 1.1.5"
Pushover Debug startup called
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address is discovered as: '192.168.1.32'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
Started plugin "Alexa-Hue Bridge 3.0.35"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'Echo' has no Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Echo' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Echo' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Echo' started: Host: 192.168.1.32 Port: 8179
Alexa-Hue Bridge 'floor lamp' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'floor lamp' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'floor lamp' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'floor lamp' started: Host: 192.168.1.32 Port: 8181
Alexa-Hue Bridge 'new device 2' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'new device 2' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'new device 2' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'new device 2' started: Host: 192.168.1.32 Port: 8182
Alexa-Hue Bridge 'new device 3' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'new device 3' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'new device 3' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'new device 3' started: Host: 192.168.1.32 Port: 8183
Alexa-Hue Bridge 'new device 5' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'new device 5' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'new device 5' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'new device 5' started: Host: 192.168.1.32 Port: 8184
Alexa-Hue Bridge 'outside christmas lights' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'outside christmas lights' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'outside christmas lights' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'outside christmas lights' started: Host: 192.168.1.32 Port: 8180
Alexa-Hue Bridge 'xmas tree lights' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'xmas tree lights' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'xmas tree lights' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'xmas tree lights' started: Host: 192.168.1.32 Port: 8178
Ecobee Error pyecobee: not authenticated to Ecobee servers
Ecobee Error request status code: 500
Ecobee Error Ecobee device requires authentication; open plugin configuration page for info
Started plugin "Ecobee 1.1.1"
Waiting for external plugins to initialize
Ecobee added smart thermostat 311075830954
Ecobee added remote sensor MJF3
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to http://www.google.com successfully completed.
Starting triggers and schedules
Jan 22, 2022 at 10:13:06 AM
Error reflector connection test failed: local server unreachable
Warning reflector reconnection scheduled in 5 seconds
Error failed to create reflector connection: local server unreachable
Error check your Firewall and Network configurations and try restarting the server
Warning reflector reconnection scheduled in 15 minutes
Sat Jan 22, 2022 4:59 pm
The Indigo Web server is crashing immediately after it launches:
Did you re-run the Indigo installer on your 2018 Mac Mini (versus just copying over the files)? If not, download and re-run the 7.5 installer. You might also want to try the most recent version of Indigo. While 7.5 should work under 10.16 we have made significant improvements because of macOS changes since then.
Sun Jan 23, 2022 1:13 pm
mwarner offline
Here is what I did. I suppose I should have asked for clarification, as these directions were not 100% clear to me:
I followed the directions under the support site for Moving an Indigo Installation to another Mac. So, I first deactivated the license on my iMac and then copied this folder on my iMac (/Library/Application Support/Perceptive Automation/Indigo 7.5/) over to my mini. Note*, I moved this folder onto the desktop of my Mini, as I had not run the 7.5 installer on the Mini yet. I then ran the 7.5 installer on the Mini. I opened Indigo and as expected all of my custom settings etc. were missing in action since it was like a clean install. I then quit Indigo and replaced the Indigo 7.5 folder in the Library with my old folder from my iMac that was sitting on the Mini desktop. I started Indigo once more, and all of my settings etc. showed up so I figured I was up and running.
If you go back to these directions, I hope you can see where my confusion lies as they are not written very clearly. My installation on the Mini did not "open the correct folder" I.e., the "Perceptive Automation" folder, so I had no chance to copy anything over as it is described in the online support. This left me guessing on how to get my previous customizations into the install and I guess I messed things up.
I took your advice and re-ran the 7.5 installer, but this has not helped. I was hoping to make sure 7.5 was working correctly all around before I made the jump to the latest version, as I have limited time to deal with the Alexa issues, but hope to attack that next weekend and hope this server issue will sort itself out with the next install.
Sun Jan 23, 2022 2:03 pm
We'll make it more clear, but those steps are for finding the Perceptive Automation folder on your original Mac. That folder of course won't exist on the new Mac, but you'll copy it over to the same location (which is the /Library/Application Support/ folder). After that you run the installer and it installs all the essential files but will leave your database and settings files untouched so they are used on first launch.
I'd suggest you go ahead and try using the latest version of Indigo. You can always stop that version (via the Indigo->Stop Server menu item, then Indigo->Quit menu item) and relaunch Indigo 7.5.
