Monterey
Tue Nov 09, 2021 6:01 am
davinci offline
Re: Monterey
I use the homebridge plugin for Indigo, this is mandatory. But I have installed it manually without homebridge buddy. You can just download NodeJS installer LTS and install it. This will replace the latest version.
Mon Nov 22, 2021 10:58 pm
jltnol offline
Re: Monterey
As far as the pre-release candidate goes, I'm only using it on my laptop running Monterey and just the Indigo Client, not the server. Not that you need me to tell you, but the UI bug seems to have been fixed with this version.
Mon Dec 20, 2021 10:35 am
7rdr7 offline
Re: Monterey
Has anyone using HomeKit Bridge successfully upgraded to Monterey? I see that Indigo 2021.2 is out and has addressed the current Monterey issues, but with HomeKit Bridge being unsupported, I've not yet upgraded to Monterey.
Mon Dec 20, 2021 11:01 am
patrick0brien offline
Re: Monterey
I do, quite happily. Be sure you get your Node.js Version to 16.13.0 before though
- Never Settle
Mon Dec 20, 2021 11:13 am
7rdr7 offline
Re: Monterey
Awesome, thanks! I'm at 16.13.1 Node.js for Homebridge on the same machine, so I'll give it a go!
Wed Dec 22, 2021 2:48 pm
jltnol offline
Re: Monterey
So I just updated to 16.3.1, so am willing to give this a shot. Do I need to update the Npm version? I'm at 8.1.2.
Wed Dec 22, 2021 4:49 pm
Re: Monterey
Actually, I'm on 8.1.0, so give it a shot. Can you report back? Curious about NPM 8.1.2
- Never Settle
Wed Dec 22, 2021 5:31 pm
7rdr7 offline
Re: Monterey
All working well. I'm on NPM 8.3.0 and Node.js 16.13.1
Wed Dec 22, 2021 10:45 pm
jltnol offline
Re: Monterey
So for the moment, I'm running both HomeKit Bridge and Homebridge.
I did 'bite the bullet' and did the upgrade to Monterey, and from the Apple side of things, it went fairly easily. No real hiccups. A few System Prefs got changed, but those were easy to fix.
On the Indigo side, no real hiccups to mention either. I ended up with a few extra databases, mainly because I upgraded to 2021.2 at the same time, so no real surprise there.
Honestly, after I read that upgrading the Homebridge Node.js version worked on Monterey, I was ready to jump off the cliff.
Really, it was a smooth transition, and equally as important, everytihng seems to be working just as before. Hats off to Matt and Jay for making this really seamless on the Indigo side.
Wed Dec 22, 2021 10:48 pm
jltnol offline
Re: Monterey
Homebridge seems to be running perfectly with Node.js v16.13.1 on a M1 iMac running Monterey as previously reported, and I'm on Npm Version 8.1.2, and so far, things seem to be working just fine.
Thu Dec 23, 2021 12:06 pm
Re: Monterey
Ok then! Thank you!
- Never Settle
