Kernel panic - Panicked task: IndigoPluginHost
Tue Sep 14, 2021 1:13 pm
NicholFD offline
New M1 Mac mini (8GB/512GB), purchased a few weeks ago, expressly to run Indigo. It was configured, on & running on the test bench for a few weeks - no issues.
A little over a week ago, I moved it into place & copied over my config from the previous Mac mini.
Things ran smoothly (both Indigo & HomeBridge for Indigo), Uptime: Tue Sep 7 14:48 - Tue Sep 14 02:10, and then it panicked (2:10AM).
Indigo version: 2021.1.1
Plugins in use:
Airfoil Pro
Cynical Cache (not configured)
Cynical SecuritySpy (not configured)
Email+
NEST Home
utilities (not configured)
Attached devices:
Power (connected to a UPS)
Ethernet - 1Gb Cisco switch stack
WiFi - ASUS RT-AX89X (configured in AP mode, no routing, FW, DHCP, etc.)
Aeotec Z-Stick Gen5
NewerTech HDMI Headless 4K Display Emulator (makes the mini think a display is attached, and allows me many more resolutions for Screen Sharing)
Things worked Monday evening. Things didn't work Tuesday morning. The machine had rebooted at 2:10AM and had the typical "a kernel panic occurred" dialog on the screen. I find it interesting that Indigo did not start or work until I clicked the button to report the kernel panic, around 12:19PM. Note that Indigo started running/working while I was still completing the contents of the panic report to send to Apple, as soon as I clicked the button to provide details (before I actually sent the report). Anyone know if this is common/normal - startup items don't run after a panic, until the dialog is touched?
Indigo logs around 2:10AM when it panicked:
2021-09-14 02:07:38.896   Z-Wave   received "Deck Porch Luminance" sensor update to 0 lux
2021-09-14 02:07:40.215   Z-Wave   received "Deck Porch Temperature" sensor update to 71.9 °F
2021-09-14 02:07:40.645   Z-Wave   received "Deck Porch Humidity" sensor update to 77%
2021-09-14 02:07:43.259   Z-Wave   received "Cabinet Light" power load to 3.688 W
2021-09-14 02:08:13.297   Z-Wave   received "Cabinet Light" power load to 3.710 W
2021-09-14 02:08:32.119   NEST Home   Upstairs Nest Protect last_connection updated to 2021-09-14t06:07:41.514z
2021-09-14 02:08:43.173   Z-Wave   received "Cabinet Light" power load to 3.682 W
2021-09-14 02:09:25.067   Z-Wave   received "Upstairs Luminance" sensor update to 6 lux
2021-09-14 02:09:25.089   Z-Wave   received "Upstairs Humidity" sensor update to 35%
2021-09-14 02:09:25.118   Z-Wave   received "Upstairs Temperature" sensor update to 75.0 °F
2021-09-14 02:09:35.112   Z-Wave   received "Game Room Luminance" sensor update to 1 lux
2021-09-14 02:09:35.114   Z-Wave   received "Game Room Humidity" sensor update to 48%
2021-09-14 02:09:35.406   Z-Wave   received "Game Room Temperature" sensor update to 69.9 °F
2021-09-14 02:09:35.407   Trigger   Set GameRoomTemp Variable + 2
2021-09-14 02:09:38.932   Z-Wave   received "Small Garage Luminance" sensor update to 0 lux
2021-09-14 02:09:38.960   Z-Wave   received "Small Garage Humidity" sensor update to 55%
2021-09-14 02:09:39.025   Z-Wave   received "Small Garage Temperature" sensor update to 73.1 °F
2021-09-14 02:09:40.259   Schedule   Set GameRoomTemp Variable + 2 (delayed action)
2021-09-14 02:09:40.260   Schedule   Set GameRoomTemp Variable + 2 (delayed action)
2021-09-14 02:09:40.612   Z-Wave   received "Entry Room Luminance" sensor update to 7 lux
2021-09-14 02:09:40.645   Z-Wave   received "Entry Room Humidity" sensor update to 47%
2021-09-14 02:09:40.673   Z-Wave   received "Entry Room Temperature" sensor update to 70.0 °F
2021-09-14 02:09:40.711   Z-Wave   received "Big Garage Luminance" sensor update to 2 lux
2021-09-14 02:09:40.766   Z-Wave   received "Big Garage Humidity" sensor update to 39%
2021-09-14 02:09:40.934   Z-Wave   received "Big Garage Temperature" sensor update to 69.5 °F
2021-09-14 02:09:43.211   Z-Wave   received "Cabinet Light" power load to 3.710 W
2021-09-14 02:09:50.551   Z-Wave   received "Small Bathroom Luminance" sensor update to 0 lux
2021-09-14 02:09:50.580   Z-Wave   received "Small Bathroom Humidity" sensor update to 38%
2021-09-14 02:09:50.626   Z-Wave   received "Small Bathroom Temperature" sensor update to 67.8 °F
2021-09-14 12:19:45.601   Application   Starting Indigo Server version 2021.1.1 on macOS Version 11.5.2 (Build 20G95)
2021-09-14 12:19:46.554   Application   Loading database "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Databases/Grammer Property.indiDb"
2021-09-14 12:19:46.746   Application   Loading disabled plugins
2021-09-14 12:19:46.746   Application   Found disabled plugin "DIRECTV DVR Control 1.1.1"
2021-09-14 12:19:46.746   Application   Found disabled plugin "Growl 7.4.1"
2021-09-14 12:19:46.746   Application   Found disabled plugin "Global Property Manager 2021.1.0"
2021-09-14 12:19:46.746   Application   Found disabled plugin "Vera Bridge 1.0.10"
2021-09-14 12:19:46.746   Application   Found disabled plugin "Timers and Pesters 2021.1.0"
2021-09-14 12:19:46.747   Application   Found disabled plugin "Alexa 2021.1.1"
2021-09-14 12:19:46.747   Application   Found disabled plugin "NOAA Weather 2021.1.0"
2021-09-14 12:19:46.747   Application   Found disabled interface "INSTEON Commands 2021.1.0"
2021-09-14 12:19:46.747   Application   Found disabled plugin "SQL Logger 2021.1.0"
2021-09-14 12:19:46.747   Application   Found disabled plugin "EasyDAQ Relay Card 2021.1.1"
2021-09-14 12:19:46.747   Application   Found disabled plugin "Airfoil 1.1.14"
2021-09-14 12:19:46.747   Application   Found disabled plugin "WeatherSnoop 3.0.0"
2021-09-14 12:19:46.748   Application   Found disabled plugin "iTunes 2021.1.0"
2021-09-14 12:19:46.748   Application   Found disabled plugin "iCal Alarm Processor 7.4.1"
2021-09-14 12:19:46.748   Application   Loading internal plugins
2021-09-14 12:19:46.749   Application   Loading interface "Z-Wave 2021.1.1"
2021-09-14 12:19:46.750   Application   Starting interface "Z-Wave 2021.1.1" (pid 21172)
2021-09-14 12:19:46.750   Application   Loading interface "Virtual Devices 2021.1.0"
2021-09-14 12:19:46.751   Application   Starting interface "Virtual Devices 2021.1.0" (pid 21173)
2021-09-14 12:19:46.751   Application   Loading plugin "Web Server 2021.1.1"
2021-09-14 12:19:46.751   Application   Starting plugin "Web Server 2021.1.1" (pid 21174)
2021-09-14 12:19:46.753   Application   Loading plugin "Action Collection 2021.1.0"
2021-09-14 12:19:46.753   Application   Starting plugin "Action Collection 2021.1.0" (pid 21175)
2021-09-14 12:19:46.756   Application   Loading plugin "Email+ 2021.1.1"
2021-09-14 12:19:46.756   Application   Starting plugin "Email+ 2021.1.1" (pid 21177)
2021-09-14 12:19:46.757   Application   Loading plugin "Airfoil Pro 2021.1.0"
2021-09-14 12:19:46.757   Application   Starting plugin "Airfoil Pro 2021.1.0" (pid 21178)
2021-09-14 12:19:47.801   Application   Started plugin "Email+ 2021.1.1"
2021-09-14 12:19:48.098   Application   Started interface "Virtual Devices 2021.1.0"
2021-09-14 12:19:48.567   Application   Started plugin "Web Server 2021.1.1"
2021-09-14 12:19:48.568   Web Server   Starting Indigo Web Server...
2021-09-14 12:19:48.575   Application   Started plugin "Airfoil Pro 2021.1.0"
2021-09-14 12:19:48.725   Application   Started plugin "Action Collection 2021.1.0"
2021-09-14 12:19:48.763   Application   Web Server client connected
2021-09-14 12:19:48.764   Web Server   started on port 8176 -- authentication enabled: oauth, digest
2021-09-14 12:19:48.765   Application   Bonjour registered "Indigo - Grammer Property"
2021-09-14 12:19:51.942   Application   Started interface "Z-Wave 2021.1.1"
2021-09-14 12:19:52.831   Application   Waiting for internal plugins to initialize
2021-09-14 12:19:53.219   Z-Wave   connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem2201 (firmware 1.00, SDK unknown)
2021-09-14 12:19:53.368   Z-Wave   found module included in controller with no matching device (missing or disabled): 004 - Dimmable Power Switch
2021-09-14 12:19:55.012   Z-Wave   found module included in controller with no matching device (missing or disabled): 057 - Relay Power Switch
2021-09-14 12:19:55.806   Application   Loading external plugins
2021-09-14 12:19:55.809   Application   Loading plugin "Cynical SecuritySpy 2.4.3"
2021-09-14 12:19:55.812   Application   Starting plugin "Cynical SecuritySpy 2.4.3" (pid 21242)
2021-09-14 12:19:55.813   Application   Loading plugin "Cynical Caché 1.9.0"
2021-09-14 12:19:55.815   Application   Starting plugin "Cynical Caché 1.9.0" (pid 21243)
2021-09-14 12:19:55.816   Application   Loading plugin "NEST Home 2.0.53"
2021-09-14 12:19:55.819   Application   Starting plugin "NEST Home 2.0.53" (pid 21244)
2021-09-14 12:19:55.821   Application   Loading plugin "utilities 1.18.32"
2021-09-14 12:19:55.822   Application   Starting plugin "utilities 1.18.32" (pid 21245)
2021-09-14 12:19:55.990   Cynical Caché   API version 2.5
2021-09-14 12:19:55.990   Cynical Caché   Python version 2.7.16.final.0
2021-09-14 12:19:55.993   Application   Started plugin "Cynical Caché 1.9.0"
2021-09-14 12:19:56.011   Application   Started plugin "NEST Home 2.0.53"
2021-09-14 12:19:56.012   NEST Home   ** Data Tracking Online **
2021-09-14 12:19:56.025   Cynical SecuritySpy   API version 2.5
2021-09-14 12:19:56.025   Cynical SecuritySpy   Python version 2.7.16.final.0
2021-09-14 12:19:56.028   Application   Started plugin "Cynical SecuritySpy 2.4.3"
2021-09-14 12:19:56.057   Application   Started plugin "utilities 1.18.32"
2021-09-14 12:19:56.058   utilities   no fname:/Library/Application Support/Perceptive Automation/Indigo 2021.1/Preferences/Plugins/com.karlwachs.utilities/PLUGINSusedForCPUlimts.json
2021-09-14 12:19:56.059   utilities   testing if variable enableTimeTracking_utilities is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
2021-09-14 12:19:56.059   utilities   myLogSet setting parameters -- logFileActive= standard; logFile= ;  debugLevel= []; maxFileSize= 5000000
2021-09-14 12:19:56.059   utilities   initialized
2021-09-14 12:19:56.059   utilities   Utilities plugin initialized, ==> select  action from plugin menu
2021-09-14 12:19:56.787   Application   Waiting for external plugins to initialize
Syslog around 2:10AM when it panicked:
Lots of these lines before this, and in every log, every day:  Sep 14 01:48:38 selma com.apple.xpc.launchd[1] (com.apple.mdworker.shared.07000000-0000-0000-0000-000000000000[45233]): Service exited due to SIGKILL | sent by mds[102]
Sep 14 01:48:39 selma com.apple.xpc.launchd[1] (com.apple.mdworker.shared.0B000000-0000-0000-0000-000000000000[45434]): Service exited due to SIGKILL | sent by mds[102]
Sep 14 01:48:39 selma com.apple.xpc.launchd[1] (com.apple.mdworker.shared.01000000-0400-0000-0000-000000000000[45435]): Service exited due to SIGKILL | sent by mds[102]
Sep 14 01:48:41 selma com.apple.xpc.launchd[1] (com.apple.mdworker.shared.09000000-0600-0000-0000-000000000000[45410]): Service exited due to SIGKILL | sent by mds[102]
Sep 14 01:49:05 selma systemstats[83]: assertion failed: 20G95: systemstats + 413748 [F3867909-0B62-389F-8F1D-33E6671E7A01]: 0x0
Sep 14 01:49:05 selma syslogd[75]: ASL Sender Statistics
Sep 14 01:49:05 selma systemstats[83]: assertion failed: 20G95: systemstats + 615252 [F3867909-0B62-389F-8F1D-33E6671E7A01]: 0x2
Sep 14 01:50:50 selma com.apple.xpc.launchd[1] (com.apple.mdworker.shared.0D000000-0300-0000-0000-000000000000[45609]): Service exited due to SIGKILL | sent by mds[102]
Sep 14 01:51:24 selma com.apple.xpc.launchd[1] (com.apple.mdworker.shared.0F000000-0500-0000-0000-000000000000[45625]): Service exited due to SIGKILL | sent by mds[102]
Sep 14 01:59:05 selma systemstats[83]: assertion failed: 20G95: systemstats + 413748 [F3867909-0B62-389F-8F1D-33E6671E7A01]: 0x0
Sep 14 01:59:05 selma syslogd[75]: ASL Sender Statistics
Sep 14 01:59:05 selma systemstats[83]: assertion failed: 20G95: systemstats + 615252 [F3867909-0B62-389F-8F1D-33E6671E7A01]: 0x2
Sep 14 02:07:10 selma com.apple.xpc.launchd[1] (com.apple.mdworker.shared.01000000-0700-0000-0000-000000000000[46124]): Service exited due to SIGKILL | sent by mds[102]
Sep 14 02:09:05 selma systemstats[83]: assertion failed: 20G95: systemstats + 413748 [F3867909-0B62-389F-8F1D-33E6671E7A01]: 0x0
Sep 14 02:09:05 selma syslogd[75]: ASL Sender Statistics
Sep 14 02:09:05 selma systemstats[83]: assertion failed: 20G95: systemstats + 615252 [F3867909-0B62-389F-8F1D-33E6671E7A01]: 0x2
Sep 14 02:10:16 localhost bootlog[0]: BOOT_TIME 1631599816 6103
Sep 14 02:10:22 localhost syslogd[75]: Configuration Notice:
        ASL Module "com.apple.cdscheduler" claims selected messages.
        Those messages may not appear in standard system log files or in the ASL database.
        ASL Module "com.apple.install" claims selected messages.
        ASL Module "com.apple.authd" sharing output destination "/var/log/asl" with ASL Module "com.apple.asl".
        Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
        ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
        ASL Module "com.apple.authd" claims selected messages.
        ASL Module "com.apple.eventmonitor" claims selected messages.
        ASL Module "com.apple.mail" claims selected messages.
        ASL Module "com.apple.performance" claims selected messages.
        ASL Module "com.apple.iokit.power" claims selected messages.
Sep 14
After the reboot, and things are working again, here are all the tasks running:
indigo@selma ~ % ps -ax
  PID TTY           TIME CMD
    1 ??         0:13.95 /sbin/launchd
  471 ??         0:00.83 /usr/sbin/syslogd
  472 ??         0:00.99 /usr/libexec/UserEventAgent (System)
  474 ??         0:00.12 /System/Library/PrivateFrameworks/Uninstall.framework/
  475 ??         0:05.61 /System/Library/Frameworks/CoreServices.framework/Vers
  476 ??         0:00.10 /System/Library/PrivateFrameworks/MediaRemote.framewor
  479 ??         0:00.88 /usr/sbin/systemstats --daemon
  481 ??         0:02.61 /usr/libexec/configd
  482 ??         0:00.00 endpointsecurityd
  483 ??         0:02.00 /System/Library/CoreServices/powerd.bundle/powerd
  486 ??         0:00.03 /usr/libexec/remoted
  488 ??         0:05.68 /usr/libexec/logd
  489 ??         0:00.08 /usr/libexec/keybagd -t 15
  492 ??         0:00.16 /System/Library/PrivateFrameworks/MobileSoftwareUpdate
  494 ??         0:00.16 /usr/libexec/watchdogd
  498 ??         6:10.92 /System/Library/Frameworks/CoreServices.framework/Fram
  499 ??         0:01.18 /System/Library/CoreServices/iconservicesd
  500 ??         0:01.39 /usr/libexec/kernelmanagerd
  501 ??         0:07.08 /usr/libexec/diskarbitrationd
  503 ??         0:12.67 hb-service
  505 ??         0:00.34 /usr/libexec/coreduetd
  508 ??         0:00.59 /usr/libexec/thermalmonitord
  509 ??         0:02.15 /System/Library/PrivateFrameworks/CoreDuetContext.fram
  510 ??         0:08.17 /usr/libexec/opendirectoryd
  511 ??         0:04.80 /System/Library/PrivateFrameworks/ApplePushService.fra
  512 ??         0:00.78 /System/Library/CoreServices/launchservicesd
  513 ??         0:00.07 /usr/libexec/timed
  515 ??         0:00.31 /System/Library/PrivateFrameworks/MobileDevice.framewo
  516 ??         0:00.59 /usr/sbin/securityd -i
  517 ??         0:00.00 auditd -l
  519 ??         0:01.54 /usr/libexec/locationd
  521 ??         0:00.04 autofsd
  522 ??         0:02.66 /usr/libexec/dasd
  526 ??         0:00.95 /usr/sbin/distnoted daemon
  527 ??         0:00.03 /System/Library/PrivateFrameworks/AppleCredentialManag
  528 ??         0:03.38 /usr/libexec/PerfPowerServices
  530 ??         0:00.07 /System/Library/CoreServices/logind
  531 ??         0:00.16 /System/Library/PrivateFrameworks/GenerationalStorage.
  532 ??         0:00.07 /usr/sbin/KernelEventAgent
  534 ??         0:06.28 /usr/sbin/bluetoothd
  535 ??         0:02.90 /usr/sbin/notifyd
  536 ??         0:00.12 /usr/libexec/sandboxd
  537 ??         0:00.10 /usr/libexec/corebrightnessd --launchd
  538 ??         0:02.35 /usr/libexec/AirPlayXPCHelper
  539 ??         0:02.97 /usr/sbin/cfprefsd daemon
  540 ??         0:02.92 /usr/libexec/logd_helper
  541 ??         0:00.62 /System/Library/CoreServices/coreservicesd
  542 ??         0:44.61 /System/Library/PrivateFrameworks/SkyLight.framework/R
  543 ??         0:01.63 /System/Library/PrivateFrameworks/TCC.framework/Resour
  544 ??         0:01.78 /System/Library/CoreServices/loginwindow.app/Contents/
  545 ??         0:00.02 aslmanager
  555 ??         0:00.73 /System/Library/Frameworks/Security.framework/Versions
  556 ??         0:00.04 /usr/libexec/PowerUIAgent
  563 ??         0:00.98 /usr/libexec/runningboardd
  569 ??         0:00.07 /usr/sbin/distnoted agent
  572 ??         0:05.70 /usr/libexec/airportd
  582 ??         0:06.42 /usr/libexec/trustd
  585 ??         0:01.67 /System/Library/PrivateFrameworks/CoreAnalytics.framew
  586 ??         0:01.30 /usr/sbin/coreaudiod
  594 ??         0:05.95 /usr/sbin/mDNSResponder
  595 ??         0:00.02 /System/Library/CryptoTokenKit/com.apple.ifdreader.slo
  596 ??         0:00.08 /usr/libexec/apfsd
  597 ??         0:00.01 /System/Library/PrivateFrameworks/CoreKDL.framework/Su
  599 ??         0:02.67 /usr/libexec/mobileassetd
  600 ??         0:02.52 /usr/libexec/nehelper
  601 ??         0:00.01 /usr/libexec/tzd
  602 ??         0:01.03 /usr/libexec/nsurlsessiond --privileged
  607 ??         0:00.24 /usr/sbin/netbiosd
  608 ??         0:00.06 /usr/sbin/distnoted agent
  609 ??         0:03.45 /System/Library/Frameworks/Metal.framework/Versions/A/
  610 ??         0:00.03 /System/Library/Frameworks/NetFS.framework/Versions/A/
  611 ??         0:00.08 /usr/libexec/usbd
  612 ??         0:00.03 /usr/libexec/firmwarecheckers/ethcheck/ethcheck --inte
  613 ??         0:00.06 /usr/libexec/biometrickitd --launchd
  614 ??         0:00.76 /System/Library/Frameworks/Metal.framework/Versions/A/
  616 ??         0:25.80 /usr/libexec/lsd runAsRoot
  618 ??         0:00.06 /usr/libexec/findmydeviced
  619 ??         0:01.42 /usr/libexec/symptomsd
  620 ??         0:00.71 /System/Library/PrivateFrameworks/WirelessDiagnostics.
  621 ??         0:00.21 /usr/libexec/searchpartyd
  624 ??         0:06.94 /usr/libexec/syspolicyd
  627 ??         0:00.06 /System/Library/Frameworks/AudioToolbox.framework/Audi
  628 ??         0:00.01 /usr/libexec/hidd
  630 ??         0:00.68 /usr/libexec/amfid
  631 ??         0:00.00 /System/Library/Frameworks/AudioToolbox.framework/XPCS
  632 ??         0:00.05 /usr/sbin/distnoted agent
  634 ??         0:01.02 /usr/libexec/secinitd
  644 ??         0:01.68 /usr/libexec/diskmanagementd
  647 ??         0:00.12 /System/Library/Frameworks/Security.framework/Versions
  648 ??         0:10.84 /System/Library/CoreServices/Software Update.app/Conte
  649 ??         0:00.09 /usr/libexec/containermanagerd --runmode=agent --bundl
  650 ??         0:00.06 /usr/sbin/distnoted agent
  651 ??         0:00.25 /System/Library/PrivateFrameworks/GeoServices.framewor
  652 ??         0:00.17 /usr/sbin/mDNSResponderHelper
  653 ??         0:00.23 /usr/libexec/secinitd
  654 ??         0:00.01 /usr/sbin/cfprefsd agent
  655 ??         0:00.10 /usr/libexec/trustd --agent
  656 ??         0:00.06 /usr/libexec/containermanagerd --runmode=agent --bundl
  657 ??         0:00.02 /usr/libexec/colorsync.displayservices
  659 ??         0:00.04 /usr/libexec/colorsyncd
  660 ??         0:00.03 /System/Library/Frameworks/LocalAuthentication.framewo
  661 ??         0:00.05 /usr/sbin/distnoted agent
  662 ??         0:00.03 /System/Library/CoreServices/Software Update.app/Conte
  663 ??         0:00.03 /System/Library/CoreServices/ReportCrash daemon
  664 ??         0:00.02 /usr/libexec/biokitaggdd
  667 ??         0:00.33 /usr/libexec/rtcreportingd
  669 ??         0:00.05 /usr/libexec/captiveagent
  675 ??         0:00.01 /usr/libexec/smd
  678 ??         0:00.02 /System/Library/Frameworks/CoreAudio.framework/Version
  681 ??         0:00.10 /usr/libexec/wifianalyticsd
  682 ??         0:00.04 aceagent
  691 ??         0:03.97 /System/Library/CoreServices/RemoteManagement/screensh
  698 ??         0:00.02 /System/Library/DriverExtensions/com.apple.AppleUserHI
  703 ??         0:00.03 /System/Library/PrivateFrameworks/SystemAdministration
  712 ??         0:00.04 /System/Library/Frameworks/OpenGL.framework/Versions/A
  715 ??         0:00.05 /usr/sbin/distnoted agent
  752 ??         0:00.88 /usr/sbin/distnoted agent
  754 ??         0:21.23 /usr/libexec/lsd
  757 ??         0:02.27 /usr/sbin/cfprefsd agent
  794 ??         2:43.15 /System/Library/CoreServices/backupd.bundle/Contents/R
  795 ??         0:07.26 /usr/libexec/trustd --agent
  796 ??         0:00.53 /System/Library/PrivateFrameworks/MobileSoftwareUpdate
  797 ??         0:00.16 /usr/libexec/aned
  798 ??         0:00.10 /System/Library/CoreServices/appleeventsd --server
  799 ??         0:00.29 /System/Library/Frameworks/ApplicationServices.framewo
  800 ??         0:00.41 /System/Library/Frameworks/ApplicationServices.framewo
  801 ??         0:00.05 /System/Library/PrivateFrameworks/ViewBridge.framework
  802 ??         0:00.77 /System/Library/CoreServices/iconservicesagent runAsRo
  803 ??         0:00.11 /usr/libexec/bootinstalld
  805 ??         0:00.17 /System/Library/CoreServices/sharedfilelistd
  806 ??         0:00.05 /usr/sbin/distnoted agent
  807 ??         0:00.24 /System/Library/PrivateFrameworks/PackageKit.framework
  808 ??         4:29.12 /System/Library/Frameworks/CoreServices.framework/Fram
  811 ??         0:00.05 /System/Library/PrivateFrameworks/SiriInference.framew
  816 ??         0:00.07 /usr/sbin/distnoted agent
  820 ??         0:00.18 /usr/libexec/rosetta/oahd
  836 ??         0:00.02 /System/Library/Frameworks/ApplicationServices.framewo
  846 ??         0:07.93 /usr/libexec/secd
  850 ??         0:00.02 /System/Library/PrivateFrameworks/AccountPolicy.framew
  854 ??         0:00.04 /usr/libexec/securityd_service
  855 ??         0:00.02 /System/Library/Frameworks/PreferencePanes.framework/V
  861 ??         0:00.12 /System/Library/PrivateFrameworks/Heimdal.framework/He
  866 ??         0:00.38 /System/Library/Frameworks/Security.framework/Versions
  868 ??         0:01.60 /usr/libexec/UserEventAgent (Aqua)
  870 ??         0:00.13 /usr/sbin/universalaccessd launchd -s
  872 ??         0:00.18 /usr/libexec/knowledge-agent
  873 ??         0:00.34 /System/Library/PrivateFrameworks/CloudServices.framew
  874 ??         0:00.32 /System/Library/Frameworks/CoreTelephony.framework/Sup
  875 ??         0:00.01 /System/Library/CoreServices/APFSUserAgent
  876 ??         0:00.09 /usr/libexec/networkserviceproxy
  877 ??         0:00.92 /usr/libexec/nsurlsessiond
  880 ??         0:01.50 /System/Library/PrivateFrameworks/CalendarAgent.framew
  881 ??         0:00.31 /usr/sbin/usernoted
  882 ??         0:01.48 /usr/libexec/routined LAUNCHED_BY_LAUNCHD
  883 ??         0:01.33 /usr/libexec/rapportd
  884 ??         0:00.11 /usr/libexec/pboard
  885 ??         0:00.53 /System/Library/PrivateFrameworks/CoreDuetContext.fram
  886 ??         0:08.18 /System/Library/PrivateFrameworks/CloudKitDaemon.frame
  887 ??         0:00.75 /System/Library/CoreServices/WiFiAgent.app/Contents/Ma
  888 ??         2:03.24 /usr/libexec/secinitd
  889 ??         1:17.50 /System/Library/PrivateFrameworks/HomeKitDaemon.framew
  890 ??         0:00.55 /System/Library/PrivateFrameworks/TelephonyUtilities.f
  891 ??         0:00.04 /usr/sbin/WirelessRadioManagerd
  893 ??         0:04.30 /System/Library/Frameworks/Accounts.framework/Versions
  894 ??         0:07.04 /System/Library/PrivateFrameworks/IDS.framework/identi
  895 ??         0:00.69 /System/Library/PrivateFrameworks/TCC.framework/Resour
  900 ??         0:00.04 /System/Library/PrivateFrameworks/AmbientDisplay.frame
  901 ??         0:00.51 /System/Library/PrivateFrameworks/iTunesCloud.framewor
  905 ??         0:00.88 /System/Library/CoreServices/NotificationCenter.app/Co
  906 ??         0:04.10 /usr/libexec/containermanagerd --runmode=agent --bundl
  907 ??         0:00.25 /System/Library/PrivateFrameworks/PhotoLibraryServices
  908 ??         0:15.08 /System/Library/CoreServices/RemoteManagement/Screensh
  909 ??         0:00.35 /System/Library/PrivateFrameworks/AuthKit.framework/Ve
  910 ??         0:00.28 /System/Library/PrivateFrameworks/AppSSO.framework/Sup
  911 ??         0:01.00 /usr/libexec/pkd
  912 ??         0:00.21 /System/Library/PrivateFrameworks/CoreADI.framework/ad
  914 ??         0:00.35 /System/Library/PrivateFrameworks/IMCore.framework/ima
  915 ??         0:00.18 /usr/libexec/dmd
  916 ??         0:00.15 /System/Library/PrivateFrameworks/IMDPersistence.frame
  917 ??         0:00.06 /System/Library/PrivateFrameworks/ViewBridge.framework
  918 ??         0:00.15 /System/Library/CoreServices/talagent
  919 ??         0:00.45 /System/Library/PrivateFrameworks/CalendarNotification
  920 ??         0:00.59 /System/Library/Frameworks/ApplicationServices.framewo
  921 ??         0:00.30 /System/Library/Frameworks/AddressBook.framework/Execu
  922 ??         0:00.51 /System/Library/Frameworks/ApplicationServices.framewo
  923 ??         0:00.13 /System/Library/CoreServices/CoreServicesUIAgent.app/C
  924 ??         1:00.28 /System/Library/CoreServices/iconservicesagent
  925 ??         0:00.11 /usr/sbin/filecoordinationd
  926 ??         0:00.26 /System/Library/Frameworks/CryptoTokenKit.framework/ct
  927 ??         0:01.07 /System/Library/Frameworks/Metal.framework/Versions/A/
  928 ??         0:00.04 /System/Library/Frameworks/Metal.framework/Versions/A/
  931 ??         0:00.18 /usr/libexec/diagnosticextensionsd
  932 ??         0:02.41 /System/Library/PrivateFrameworks/AssistantServices.fr
  934 ??         0:00.04 /System/Library/PrivateFrameworks/CoreEmbeddedSpeechRe
  935 ??         0:01.33 /System/Library/PrivateFrameworks/CacheDelete.framewor
  936 ??         0:00.65 /System/Library/CoreServices/RemoteManagement/SSMenuAg
  937 ??         0:00.38 /System/Library/PrivateFrameworks/UserActivity.framewo
  938 ??         0:03.85 /usr/libexec/sharingd
  940 ??         0:00.22 /System/Library/CoreServices/sharedfilelistd
  942 ??         0:00.37 /System/Library/CoreServices/backupd.bundle/Contents/R
  943 ??         0:00.10 /System/Library/PrivateFrameworks/AssistantServices.fr
  945 ??         0:00.74 /System/Library/PrivateFrameworks/GeoServices.framewor
  946 ??         0:00.06 /usr/sbin/systemsoundserverd
  948 ??         0:00.22 /System/Library/PrivateFrameworks/AMPLibrary.framework
  949 ??         0:22.57 /usr/libexec/searchpartyuseragent
  950 ??         0:00.47 /usr/libexec/adprivacyd
  951 ??         0:00.40 /System/iOSSupport/System/Library/PrivateFrameworks/Av
  952 ??         0:00.34 /usr/libexec/fmfd
  954 ??         0:00.05 /System/Library/PrivateFrameworks/FamilyCircle.framewo
  957 ??         0:00.05 /usr/sbin/distnoted agent
  958 ??         0:00.48 /usr/libexec/sysmond
  959 ??         0:00.14 /System/Library/CoreServices/Keychain Circle Notificat
  961 ??         0:00.05 /System/Library/PrivateFrameworks/CoreCDP.framework/Ve
  962 ??         0:00.05 /System/Library/PrivateFrameworks/ProtectedCloudStorag
  963 ??         0:00.07 /System/Library/Frameworks/Security.framework/Versions
  965 ??         0:00.09 /System/Library/Frameworks/Metal.framework/Versions/A/
  966 ??         0:00.07 /System/Library/Frameworks/Metal.framework/Versions/A/
  967 ??         0:00.06 /System/Library/PrivateFrameworks/CoreFP.framework/Ver
  968 ??         0:00.04 /usr/sbin/systemstats --logger-helper /private/var/db/
  969 ??         0:00.19 /System/Library/CoreServices/pbs
  975 ??         0:00.16 /System/Library/PrivateFrameworks/ScreenTimeCore.frame
  976 ??         0:00.09 /usr/libexec/WiFiVelocityAgent
  977 ??         0:00.17 /usr/libexec/wifivelocityd
  979 ??         0:00.02 /usr/libexec/morphunassetsupdaterd
  982 ??         0:00.03 /System/Library/PrivateFrameworks/CommunicationsFilter
  985 ??         0:00.32 /System/Library/Frameworks/CoreServices.framework/Fram
  986 ??         0:00.90 /System/Library/PrivateFrameworks/CoreSuggestions.fram
  996 ??         0:00.01 /System/Library/PrivateFrameworks/IMFoundation.framewo
  997 ??         0:00.08 /System/Library/PrivateFrameworks/ContextKit.framework
  998 ??         0:00.05 /usr/sbin/distnoted agent
  999 ??         0:00.18 /usr/libexec/neagent
 1000 ??         0:00.07 /usr/libexec/mobileactivationd
 1001 ??         0:00.01 /System/Library/Frameworks/CoreServices.framework/Vers
 1002 ??         0:00.06 /usr/libexec/keyboardservicesd
 1012 ??         0:00.03 /System/Library/CoreServices/ReportCrash agent
 1013 ??         0:00.29 /System/Library/PrivateFrameworks/MobileInstallation.f
 1014 ??         0:00.03 /System/Library/CoreServices/backgroundtaskmanagementa
 1016 ??         0:00.02 /System/Library/PrivateFrameworks/MobileInstallation.f
 1017 ??         0:00.05 /usr/sbin/distnoted agent
 1019 ??         0:00.02 /System/Library/PrivateFrameworks/CacheDelete.framewor
 1021 ??         0:00.60 /System/Library/PrivateFrameworks/CloudDocsDaemon.fram
 1022 ??         0:00.31 /usr/libexec/swcd
 1031 ??         0:00.19 /System/Library/Frameworks/CryptoTokenKit.framework/ct
 1032 ??         0:00.10 /usr/libexec/AssetCache/AssetCache
 1033 ??         0:00.07 /usr/libexec/replayd
 1034 ??         0:00.54 /System/Library/PrivateFrameworks/AppStoreDaemon.frame
 1035 ??         0:00.08 /usr/libexec/symptomsd-diag
 1036 ??         0:00.02 /System/Library/PrivateFrameworks/PackageKit.framework
 1037 ??         0:00.09 /System/Library/CoreServices/diagnostics_agent
 1038 ??         0:00.34 /System/Library/PrivateFrameworks/FileProvider.framewo
 1039 ??         0:00.13 /System/Library/PrivateFrameworks/CoreSymbolication.fr
 1040 ??         0:00.04 /System/Library/Frameworks/CryptoTokenKit.framework/ct
 1041 ??         0:00.17 /System/Library/Frameworks/QuickLookThumbnailing.frame
 1042 ??         0:00.09 /System/Library/PrivateFrameworks/CommerceKit.framewor
 1047 ??         0:00.38 /System/Library/PrivateFrameworks/PassKitCore.framewor
 1048 ??         0:00.26 /usr/libexec/nfcd
 1049 ??         0:00.09 /System/Library/PrivateFrameworks/IMFoundation.framewo
 1050 ??         0:00.26 /System/Library/CoreServices/CoreLocationAgent.app/Con
 1051 ??         0:00.01 /System/Library/PrivateFrameworks/MediaRemote.framewor
 1052 ??         0:00.01 /System/Library/Frameworks/NetFS.framework/Versions/A/
 1058 ??         0:00.14 /System/Library/PrivateFrameworks/AssetCacheServices.f
 1059 ??         0:00.07 /System/Library/PrivateFrameworks/AssetCacheServicesEx
 1060 ??         0:00.77 /Library/Apple/System/Library/CoreServices/SafariSuppo
 1061 ??         0:00.18 /System/Library/Frameworks/ClassKit.framework/Versions
 1065 ??         0:00.05 /usr/sbin/distnoted agent
 1067 ??         0:00.06 /System/Library/PrivateFrameworks/InstallCoordination.
 1068 ??         0:00.04 /System/Library/PrivateFrameworks/AppStoreDaemon.frame
 1069 ??         0:00.05 /usr/libexec/nesessionmanager
 1070 ??         0:00.07 /usr/libexec/seld
 1071 ??         0:00.06 /System/Library/Frameworks/SystemExtensions.framework/
 1073 ??         0:00.01 /System/Library/Frameworks/ColorSync.framework/Support
 1077 ??         0:00.05 /System/Library/Frameworks/LocalAuthentication.framewo
 1078 ??         0:00.18 /System/Library/PrivateFrameworks/AppleMediaServicesUI
 1079 ??         0:00.15 /System/Library/PrivateFrameworks/CloudDocsDaemon.fram
 1080 ??         0:00.05 /usr/sbin/distnoted agent
 1081 ??         0:00.15 /System/Library/PrivateFrameworks/SoftwareUpdate.frame
 1082 ??         0:00.09 /System/Library/PrivateFrameworks/CloudPhotoServices.f
 1083 ??         0:00.01 /System/Library/CoreServices/CrashReporterSupportHelpe
 1084 ??         0:00.03 /System/Library/CoreServices/ScopedBookmarkAgent
 1085 ??         0:00.13 /System/Library/CoreServices/SubmitDiagInfo server-ini
 1089 ??         0:00.37 /System/Library/PrivateFrameworks/PhotoAnalysis.framew
 1093 ??         0:00.13 /System/Library/PrivateFrameworks/CoreSpeech.framework
 1094 ??         0:00.06 /System/Library/Frameworks/AudioToolbox.framework/Audi
 1095 ??         0:00.71 /System/Library/Frameworks/Metal.framework/Versions/A/
 1096 ??         0:00.26 /System/Library/Frameworks/Metal.framework/Versions/A/
 1100 ??         0:08.49 /System/Library/PrivateFrameworks/AssistantServices.fr
 1101 ??         0:01.07 (CarbonComponentS)
 1115 ??         0:00.01 /System/Library/Frameworks/AudioToolbox.framework/XPCS
 1116 ??         0:00.02 /System/Library/PrivateFrameworks/CoreFollowUp.framewo
 1119 ??         0:00.16 cloudphotod
 1147 ??         0:01.73 /System/Library/Frameworks/CoreServices.framework/Fram
 1148 ??         0:01.69 /System/Library/Frameworks/CoreServices.framework/Fram
 1149 ??         0:00.25 /usr/libexec/pkd
 1150 ??         0:02.19 /usr/libexec/trustd --agent
 1163 ??         0:10.71 /System/Library/Frameworks/CoreServices.framework/Fram
 1190 ??         0:00.08 /usr/sbin/distnoted agent
 1321 ??         0:00.02 /usr/libexec/online-authd
 1439 ??         0:01.58 /System/Library/Frameworks/CoreServices.framework/Fram
 1440 ??         0:00.07 /usr/sbin/cfprefsd agent
 1441 ??         0:00.41 /usr/libexec/pkd
 1442 ??         0:27.29 /usr/libexec/lsd
 1448 ??         0:02.89 /usr/libexec/trustd --agent
 1449 ??         0:00.11 /usr/libexec/secd
 1480 ??         0:00.01 /System/Library/Frameworks/NetFS.framework/Versions/A/
 1501 ??         0:04.94 /usr/sbin/spindump
 1502 ??         0:00.03 /usr/libexec/spindump_agent
 1513 ??         0:00.03 /System/Library/PrivateFrameworks/NewDeviceOutreach.fr
 1514 ??         0:00.08 /usr/sbin/distnoted agent
 1527 ??         0:00.02 /usr/sbin/cfprefsd agent
 1541 ??         0:00.08 /usr/sbin/distnoted agent
 1547 ??         0:00.02 /usr/sbin/cfprefsd agent
 1608 ??         0:00.24 /System/Library/PrivateFrameworks/iCloudNotification.f
 1609 ??         0:00.16 /usr/libexec/triald
 1613 ??         0:01.31 /System/Library/Frameworks/CoreServices.framework/Fram
 1614 ??         0:00.44 /usr/libexec/pkd
 1615 ??         0:26.09 /usr/libexec/lsd
 1616 ??         0:02.87 /usr/libexec/trustd --agent
 1617 ??         0:01.47 /System/Library/Frameworks/CoreServices.framework/Fram
 1618 ??         0:00.41 /usr/libexec/pkd
 1619 ??         0:25.08 /usr/libexec/lsd
 1620 ??         0:03.96 /usr/libexec/trustd --agent
 1621 ??         0:00.11 /usr/libexec/secd
 1622 ??         0:00.11 /usr/libexec/secd
 1648 ??         0:00.05 /usr/libexec/ASPCarryLog
 1652 ??         0:00.01 /System/Library/Frameworks/NetFS.framework/Versions/A/
 1653 ??         0:00.01 /System/Library/Frameworks/NetFS.framework/Versions/A/
 1705 ??         0:00.56 /Library/Apple/System/Library/CoreServices/SafariSuppo
 1706 ??         0:00.09 /System/Library/PrivateFrameworks/CoreLSKD.framework/V
 2014 ??         0:00.06 /System/Library/PrivateFrameworks/CloudDocs.framework/
 2059 ??         0:01.42 /System/Applications/Utilities/Terminal.app/Contents/M
 2060 ??         0:01.18 /System/Library/CoreServices/Dock.app/Contents/MacOS/D
 2061 ??         0:00.81 /System/Library/CoreServices/ControlCenter.app/Content
 2062 ??         0:00.40 /System/Library/CoreServices/SystemUIServer.app/Conten
 2063 ??         0:09.95 /System/Library/CoreServices/Finder.app/Contents/MacOS
 2066 ??         0:00.04 /System/Library/Frameworks/Quartz.framework/Versions/A
 2067 ??         0:00.33 /System/Library/CoreServices/Spotlight.app/Contents/Ma
 2069 ??         0:00.06 /System/Library/PrivateFrameworks/AMPDevices.framework
 2070 ??         0:00.02 /System/Library/Frameworks/Metal.framework/Versions/A/
 2073 ??         0:00.02 /System/Library/Frameworks/Metal.framework/Versions/A/
 2074 ??         0:00.36 /System/Library/PrivateFrameworks/CoreParsec.framework
 2076 ??         0:00.07 /System/Library/Frameworks/VideoToolbox.framework/Vers
 2078 ??         0:00.01 /System/Library/PrivateFrameworks/login.framework/Vers
 2079 ??         0:00.02 /System/Library/Frameworks/Metal.framework/Versions/A/
 2080 ??         0:00.02 /System/Library/Frameworks/Metal.framework/Versions/A/
 2093 ??         0:00.48 /usr/libexec/studentd
 2095 ??         0:00.01 /System/Library/Frameworks/AudioToolbox.framework/XPCS
 2100 ??         0:00.08 /System/Library/Frameworks/InputMethodKit.framework/Re
 2101 ??         0:00.25 /System/Library/CoreServices/Siri.app/Contents/MacOS/S
 2102 ??         0:00.09 /System/Library/Image Capture/Support/icdd
 2103 ??         0:00.16 /System/Library/PrivateFrameworks/AskPermission.framew
 2105 ??         0:00.04 /System/Library/CoreServices/AirPlayUIAgent.app/Conten
 2106 ??         0:08.21 /Library/Application Support/Perceptive Automation/Ind
 2107 ??         0:00.52 /System/Library/CoreServices/cloudpaird
 2108 ??         0:00.19 /System/Library/CoreServices/TextInputMenuAgent.app/Co
 2109 ??         0:00.41 /System/Library/PrivateFrameworks/AppleMediaServices.f
 2110 ??         0:00.05 /System/Library/Frameworks/CryptoTokenKit.framework/ct
 2112 ??         0:00.04 /System/Library/Frameworks/ApplicationServices.framewo
 2114 ??         0:00.05 /System/Library/Frameworks/CryptoTokenKit.framework/ct
 2115 ??         0:00.54 /System/Library/PrivateFrameworks/CommerceKit.framewor
 2118 ??         0:00.14 /System/Library/CoreServices/TextInputSwitcher.app/Con
 2125 ??         0:00.11 /System/Library/CoreServices/Dock.app/Contents/XPCServ
 2126 ??         0:00.03 /System/Library/PrivateFrameworks/CallHistory.framewor
 2128 ??         0:00.06 /System/Library/Frameworks/Metal.framework/Versions/A/
 2129 ??         0:00.04 /System/Library/Frameworks/Metal.framework/Versions/A/
 2130 ??         0:00.01 /System/Library/Frameworks/CoreServices.framework/Fram
 2134 ??         0:00.04 /System/Library/Frameworks/Metal.framework/Versions/A/
 2135 ??         0:00.02 /System/Library/Frameworks/Metal.framework/Versions/A/
 2136 ??         0:00.52 /System/Library/Frameworks/ApplicationServices.framewo
 2137 ??         0:08.29 /Library/Application Support/Perceptive Automation/Ind
 2138 ??         0:01.46 /Library/Application Support/Perceptive Automation/Ind
 2139 ??         0:05.25 /Library/Application Support/Perceptive Automation/Ind
 2140 ??         0:01.73 /Library/Application Support/Perceptive Automation/Ind
 2141 ??         0:01.94 /Library/Application Support/Perceptive Automation/Ind
 2142 ??         0:01.71 /Library/Application Support/Perceptive Automation/Ind
 2143 ??         0:00.21 /System/Library/CoreServices/LocationMenu.app/Contents
 2150 ??         0:01.49 /Library/Application Support/Perceptive Automation/Ind
 2151 ??         0:01.60 /Library/Application Support/Perceptive Automation/Ind
 2152 ??         0:12.79 /Library/Application Support/Perceptive Automation/Ind
 2153 ??         0:01.67 /Library/Application Support/Perceptive Automation/Ind
 2181 ??         0:00.11 /System/Library/CoreServices/Siri.app/Contents/XPCServ
 2272 ??         0:00.04 /System/Library/Frameworks/Metal.framework/Versions/A/
 2273 ??         0:00.02 /System/Library/Frameworks/Metal.framework/Versions/A/
 2340 ??         0:00.03 /System/Library/CoreServices/RemoteManagement/Screensh
 2377 ??         0:11.07 homebridge
 2690 ??         0:00.09 /System/Library/Frameworks/GSS.framework/Helpers/GSSCr
 2691 ??         0:00.03 /System/Library/Filesystems/AppleShare/check_afp.app/C
 2702 ??         0:00.11 /System/Library/PrivateFrameworks/KerberosHelper/Helpe
 2757 ??         0:00.01 /System/Library/Frameworks/NetFS.framework/Versions/A/
 2758 ??         0:00.26 /System/Library/Frameworks/NetFS.framework/Versions/A/
 2848 ??         0:00.02 /System/Library/Frameworks/NetFS.framework/Versions/A/
 3547 ??         0:00.27 /System/Library/Services/AppleSpell.service/Contents/M
 3934 ??         0:00.08 /System/Library/PrivateFrameworks/AOSKit.framework/Ver
 2088 ttys000    0:00.02 login -pf indigo
 2111 ttys000    0:00.04 -zsh
 4105 ttys000    0:00.00 ps -ax
Full kernel panic message:
panic(cpu 1 caller 0xfffffe0015055320): Kernel data abort. at pc 0xfffffe00148b5e18, lr 0xc38c7e00148b5dcc (saved state: 0xfffffe3f639038c0)
     x0: 0xfffffe1682214000  x1:  0x0000000000000000  x2:  0xfffffffffffffff0  x3:  0xfffffe1682217fc0
     x4: 0xfffffe1682214050  x5:  0x00000000ffffffff  x6:  0x0000000000000001  x7:  0x0000000000000009
     x8: 0x0000000000000000  x9:  0xfffffe0018692558  x10: 0x000000000003e7fd  x11: 0x000000000003e7fd
     x12: 0x00000000000029a1 x13: 0x0000000000000000  x14: 0xfffffe563a8fd22c  x15: 0x00000000f85a0885
     x16: 0x00000000000029a1 x17: 0x0000000000004001  x18: 0x0000000000000000  x19: 0xfffffe0018692548
     x20: 0xfffffe0018692590 x21: 0xfffffe1682214000  x22: 0xfffffe300ed91000  x23: 0xfffffe0018692548
     x24: 0xfffffe0018692000 x25: 0xfffffe001cd61a68  x26: 0xfffffe0018609228  x27: 0xfffffe001cd61a68
     x28: 0x0000000000000001 fp:  0xfffffe3f63903c50  lr:  0xc38c7e00148b5dcc  sp:  0xfffffe3f63903c10
     pc:  0xfffffe00148b5e18 cpsr: 0x20401208         esr: 0x96000046          far: 0x000000000000000c
Debugger message: panic
Memory ID: 0x6
OS release type: User
OS version: 20G95
Kernel version: Darwin Kernel Version 20.6.0: Wed Jun 23 00:26:27 PDT 2021; root:xnu-7195.141.2~5/RELEASE_ARM64_T8101
Fileset Kernelcache UUID: 15F4DFDFA9E0154FED96EA8997E65429
Kernel UUID: AC4A14A7-8A8E-3AE6-85A6-55E6B2502BF9
iBoot version: iBoot-6723.140.2
secure boot?: YES
Paniclog version: 13
KernelCache slide: 0x000000000cc38000
KernelCache base:  0xfffffe0013c3c000
Kernel slide:      0x000000000d780000
Kernel text base:  0xfffffe0014784000
Kernel text exec base:  0xfffffe0014850000
mach_absolute_time: 0xc353c87422f
Epoch Time:        sec       usec
  Boot    : 0x6137b414 0x0001ada2
  Sleep   : 0x00000000 0x00000000
  Wake    : 0x00000000 0x00000000
  Calendar: 0x61403cba 0x000ae271
CORE 0 recently retired instr at 0xfffffe00149c2d6c
CORE 1 recently retired instr at 0xfffffe00149c16a4
CORE 2 recently retired instr at 0xfffffe00149c2d6c
CORE 3 recently retired instr at 0xfffffe00149c2d6c
CORE 4 recently retired instr at 0xfffffe00149c2d70
CORE 5 recently retired instr at 0xfffffe00149c2d70
CORE 6 recently retired instr at 0xfffffe00149c2d70
CORE 7 recently retired instr at 0xfffffe00149c2d70
CORE 0 PVH locks held: None
CORE 1 PVH locks held: None
CORE 2 PVH locks held: None
CORE 3 PVH locks held: None
CORE 4 PVH locks held: None
CORE 5 PVH locks held: None
CORE 6 PVH locks held: None
CORE 7 PVH locks held: None
CORE 0: PC=0xfffffe00148b63dc, LR=0xfffffe00148f1b10, FP=0xfffffe3f66fb3830
CORE 1 is the one that panicked. Check the full backtrace for details.
CORE 2: PC=0xfffffe00149b82e8, LR=0xfffffe00149b8308, FP=0xfffffe3f67013c00
CORE 3: PC=0xfffffe00149b82e8, LR=0xfffffe00149b8308, FP=0xfffffe306acfbc00
CORE 4: PC=0xfffffe00148b3808, LR=0xfffffe00148b3770, FP=0xfffffe3f419ab920
CORE 5: PC=0xfffffe00148b3808, LR=0xfffffe00148b3770, FP=0xfffffe306fa03c20
CORE 6: PC=0xfffffe00148c9a64, LR=0xfffffe00148c9a5c, FP=0xfffffe306fdabee0
CORE 7: PC=0xfffffe00148c9a64, LR=0xfffffe00148c9a5c, FP=0xfffffe3f66cabee0
Panicked task 0xfffffe1670fc2730: 1328 pages, 6 threads: pid 639: IndigoPluginHost
Panicked thread: 0xfffffe166fdf5980, backtrace: 0xfffffe3f63903030, tid: 7232
        lr: 0xfffffe001489eb68  fp: 0xfffffe3f639030a0
        lr: 0xfffffe001489e94c  fp: 0xfffffe3f63903110
        lr: 0xfffffe00149c81c8  fp: 0xfffffe3f63903130
        lr: 0xfffffe00149b9674  fp: 0xfffffe3f639031e0
        lr: 0xfffffe00148577e8  fp: 0xfffffe3f639031f0
        lr: 0xfffffe001489e5dc  fp: 0xfffffe3f63903580
        lr: 0xfffffe001489e5dc  fp: 0xfffffe3f639035f0
        lr: 0xfffffe0015050e80  fp: 0xfffffe3f63903610
        lr: 0xfffffe0015055320  fp: 0xfffffe3f63903780
        lr: 0xfffffe00149bb650  fp: 0xfffffe3f639037f0
        lr: 0xfffffe00149b959c  fp: 0xfffffe3f639038a0
        lr: 0xfffffe00148577e8  fp: 0xfffffe3f639038b0
        lr: 0xfffffe00148b5dcc  fp: 0xfffffe3f63903c50
        lr: 0xfffffe00148f5f40  fp: 0xfffffe3f63903cd0
        lr: 0xfffffe00148968e4  fp: 0xfffffe3f63903d50
        lr: 0xfffffe0014892df8  fp: 0xfffffe3f63903d70
        lr: 0xfffffe00149adffc  fp: 0xfffffe3f63903e40
        lr: 0xfffffe00149b96f0  fp: 0xfffffe3f63903ef0
        lr: 0xfffffe00148577e8  fp: 0xfffffe3f63903f00
last started kext at 40601295806: com.apple.filesystems.afpfs   11.3 (addr 0xfffffe00146ac000, size 49152)
loaded kexts:
com.apple.nke.asp_tcp   8.2
com.apple.filesystems.smbfs   3.6
com.apple.fileutil   20.036.15
com.apple.filesystems.autofs   3.0
com.apple.iokit.IOBluetoothSerialManager   8.0.5d7
com.apple.driver.AppleBiometricServices   1
com.apple.driver.BCMWLANFirmware4378.Hashstore   1
com.apple.driver.AppleAOPVoiceTrigger   11.5
com.apple.driver.AppleThunderboltIP   4.0.3
com.apple.iokit.AppleBCM5701Ethernet   11.0.0
com.apple.driver.CoreKDL   1
com.apple.driver.SEPHibernation   1
com.apple.driver.AppleUSBDeviceNCM   5.0.0
com.apple.driver.DiskImages.ReadWriteDiskImage   493.0.0
com.apple.driver.DiskImages.UDIFDiskImage   493.0.0
com.apple.driver.DiskImages.RAMBackingStore   493.0.0
com.apple.driver.DiskImages.FileBackingStore   493.0.0
com.apple.driver.AppleSmartBatteryManager   161.0.0
com.apple.filesystems.apfs   1677.141.1
com.apple.driver.AppleFileSystemDriver   3.0.1
com.apple.nke.l2tp   1.9
com.apple.filesystems.tmpfs   1
com.apple.driver.AppleSmartIO2   1
com.apple.IOTextEncryptionFamily   1.0.0
com.apple.filesystems.hfs.kext   556.100.11
com.apple.security.BootPolicy   1
com.apple.BootCache   40
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib   1.0.0
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless   1.0.0d1
com.apple.driver.AppleTAS5770LAmp   442.26
com.apple.driver.ApplePMP   1
com.apple.driver.AppleCS42L83Audio   442.26
com.apple.AppleEmbeddedSimpleSPINORFlasher   1
com.apple.driver.ApplePMPFirmware   1
com.apple.driver.AppleSPMIPMU   1.0.1
com.apple.driver.AppleT8103CLPCv3   1
com.apple.driver.AppleT8020SOCTuner   1
com.apple.AGXG13G   173.28.7
com.apple.driver.AppleAVD   385
com.apple.driver.AppleAVE2   401.73.4
com.apple.driver.AppleJPEGDriver   4.6.0
com.apple.driver.AppleMobileDispH13G-DCP   140.0
com.apple.driver.usb.AppleUSBHostT8103   1
com.apple.driver.AudioDMAController-T8103   1.60.5
com.apple.driver.AppleSPIMC   1
com.apple.driver.AppleS5L8960XNCO   1
com.apple.driver.AppleT8103PMGR   1
com.apple.driver.AppleS8000AES   1
com.apple.driver.AppleS5L8920XPWM   1.0.0d1
com.apple.driver.AppleS8000DWI   1.0.0d1
com.apple.driver.AppleS5L8960XWatchDogTimer   1
com.apple.driver.AppleInterruptController   1.0.0d1
com.apple.driver.AppleBluetoothModule   1
com.apple.driver.AppleSamsungSerial   1.0.0d1
com.apple.driver.AppleBCMWLANBusInterfacePCIe   1
com.apple.driver.AppleMCDP29XXUpdateSupport   1
com.apple.driver.AppleT8020DART   1
com.apple.driver.AppleS5L8940XI2C   1.0.0d2
com.apple.driver.AppleT8101   1
com.apple.driver.AppleM68Buttons   1.0.0d1
com.apple.iokit.IOUserEthernet   1.0.1
com.apple.driver.usb.AppleUSBUserHCI   1
com.apple.iokit.IOKitRegistryCompatibility   1
com.apple.iokit.EndpointSecurity   1
com.apple.driver.AppleDiskImages2   1
com.apple.AppleSystemPolicy   2.0.0
com.apple.nke.applicationfirewall   311
com.apple.kec.InvalidateHmac   1
com.apple.security.SecureRemotePassword   1.0
com.apple.plugin.IOAVBDiscoveryPlugin   940.4
com.apple.kext.triggers   1.0
com.apple.driver.usb.cdc.ecm   5.0.0
com.apple.driver.usb.cdc.acm   5.0.0
com.apple.driver.usb.serial   6.0.0
com.apple.iokit.IOAVBFamily   940.4
com.apple.plugin.IOgPTPPlugin   985.2
com.apple.iokit.IOEthernetAVBController   1.1.0
com.apple.driver.AppleMesaSEPDriver   100.99
com.apple.iokit.IOBiometricFamily   1
com.apple.driver.usb.cdc   5.0.0
com.apple.driver.AppleAOPAudio   16.2
com.apple.driver.IOBluetoothHostControllerPCIeTransport   8.0.5d7
com.apple.iokit.IOBluetoothHostControllerTransport   8.0.5d7
com.apple.driver.usb.AppleEmbeddedUSBXHCIPCI   1
com.apple.driver.usb.AppleUSBXHCIPCI   1.2
com.apple.driver.AppleEmbeddedUSB   1
com.apple.driver.AppleConvergedIPCOLYBTControl   1
com.apple.driver.AppleConvergedPCI   1
com.apple.driver.AppleBluetoothDebug   1
com.apple.driver.AppleSEPHDCPManager   1.0.1
com.apple.driver.AppleTrustedAccessory   1
com.apple.iokit.AppleSEPGenericTransfer   1
com.apple.driver.usb.networking   5.0.0
com.apple.driver.AppleThunderboltPCIDownAdapter   4.1.1
com.apple.driver.AppleThunderboltUSBDownAdapter   1.0.4
com.apple.driver.AppleThunderboltDPInAdapter   8.1.4
com.apple.driver.AppleThunderboltDPAdapterFamily   8.1.4
com.apple.driver.DiskImages.KernelBacked   493.0.0
com.apple.driver.AppleBTM   1.0.1
com.apple.driver.AppleXsanScheme   3
com.apple.driver.AppleDCPDPTXProxy   1.0.0
com.apple.driver.DCPDPFamilyProxy   1
com.apple.nke.ppp   1.9
com.apple.driver.AppleBSDKextStarter   3
com.apple.filesystems.hfs.encodings.kext   1
com.apple.AGXFirmwareKextG13GRTBuddy   173.28.7
com.apple.AGXFirmwareKextRTBuddy64   173.28.7
com.apple.iokit.IONVMeFamily   2.1.0
com.apple.driver.AppleDiagnosticDataAccessReadOnly   1.0.0
com.apple.driver.AppleNANDConfigAccess   1.0.0
com.apple.driver.AppleSPU   1
com.apple.driver.AppleHPM   3.4.4
com.apple.driver.AppleCSEmbeddedAudio   442.26
com.apple.driver.AppleEmbeddedAudio   442.26
com.apple.iokit.AppleARMIISAudio   80.34.1
com.apple.driver.AppleStockholmControl   1.0.0
com.apple.driver.AppleDialogPMU   1.0.1
com.apple.driver.AppleMCA2-T8103   540.10
com.apple.driver.ApplePassthroughPPM   3.0
com.apple.iokit.IOGPUFamily   21.11
com.apple.driver.AppleH11ANEInterface   4.75.0
com.apple.driver.DCPAVFamilyProxy   1
com.apple.iokit.IOMobileGraphicsFamily-DCP   343.0.0
com.apple.driver.AppleDCP   1
com.apple.driver.AppleFirmwareKit   1
com.apple.iokit.IOMobileGraphicsFamily   343.0.0
com.apple.driver.AppleSPMI   1.0.1
com.apple.driver.AppleT8103TypeCPhy   1
com.apple.driver.AppleUSBXDCIARM   1.0
com.apple.driver.AppleUSBXDCI   1.0
com.apple.iokit.IOUSBDeviceFamily   2.0.0
com.apple.driver.usb.AppleUSBXHCIARM   1
com.apple.driver.usb.AppleUSBXHCI   1.2
com.apple.driver.AppleEmbeddedUSBHost   1
com.apple.driver.usb.AppleUSBHub   1.2
com.apple.driver.usb.AppleUSBHostCompositeDevice   1.2
com.apple.driver.AppleSART   1
com.apple.driver.ApplePMGR   1
com.apple.driver.watchdog   1
com.apple.driver.usb.AppleUSBHostPacketFilter   1.0
com.apple.driver.AppleDisplayCrossbar   1.0.0
com.apple.driver.AppleTypeCPhy   1
com.apple.driver.AppleThunderboltNHI   7.2.8
com.apple.driver.AppleT8103PCIeC   1
com.apple.iokit.IOThunderboltFamily   9.3.2
com.apple.driver.ApplePIODMA   1
com.apple.driver.AppleT8103PCIe   1
com.apple.driver.AppleMultiFunctionManager   1
com.apple.driver.AppleEmbeddedPCIE   1
com.apple.driver.AppleBluetoothDebugService   1
com.apple.driver.AppleBCMWLANCore   1.0.0
com.apple.iokit.IO80211FamilyV2   1200.12.2b1
com.apple.driver.IOImageLoader   1.0.0
com.apple.driver.corecapture   1.0.4
com.apple.iokit.IODisplayPortFamily   1.0.0
com.apple.driver.AppleGPIOICController   1.0.2
com.apple.driver.AppleFireStormErrorHandler   1
com.apple.driver.AppleMobileApNonce   1
com.apple.iokit.IOTimeSyncFamily   985.2
com.apple.driver.DiskImages   493.0.0
com.apple.iokit.IOGraphicsFamily   585.1
com.apple.iokit.IOBluetoothFamily   8.0.5d7
com.apple.iokit.IOBluetoothPacketLogger   8.0.5d7
com.apple.driver.FairPlayIOKit   68.7.1
com.apple.iokit.CoreAnalyticsFamily   1
com.apple.driver.AppleSSE   1.0
com.apple.driver.AppleSEPKeyStore   2
com.apple.driver.AppleUSBTDM   511.141.1
com.apple.iokit.IOUSBMassStorageDriver   184.140.2
com.apple.iokit.IOPCIFamily   2.9
com.apple.iokit.IOSCSIBlockCommandsDevice   436.140.1
com.apple.iokit.IOSCSIArchitectureModelFamily   436.140.1
com.apple.driver.AppleIPAppender   1.0
com.apple.driver.AppleFDEKeyStore   28.30
com.apple.driver.AppleEffaceableStorage   1.0
com.apple.driver.AppleCredentialManager   1.0
com.apple.driver.KernelRelayHost   1
com.apple.iokit.IOUSBHostFamily   1.2
com.apple.driver.AppleUSBHostMergeProperties   1.2
com.apple.driver.usb.AppleUSBCommon   1.0
com.apple.driver.AppleSMC   3.1.9
com.apple.driver.RTBuddy   1.0.0
com.apple.driver.AppleEmbeddedTempSensor   1.0.0
com.apple.driver.AppleARMPMU   1.0
com.apple.iokit.IOAccessoryManager   1.0.0
com.apple.driver.AppleOnboardSerial   1.0
com.apple.iokit.IOSkywalkFamily   1
com.apple.driver.mDNSOffloadUserClient   1.0.1b8
com.apple.iokit.IONetworkingFamily   3.4
com.apple.iokit.IOSerialFamily   11
com.apple.driver.AppleSEPManager   1.0.1
com.apple.driver.AppleA7IOP   1.0.2
com.apple.driver.IOSlaveProcessor   1
com.apple.driver.AppleBiometricSensor   2
com.apple.iokit.IOHIDFamily   2.0.0
com.apple.AUC   1.0
com.apple.iokit.IOAVFamily   1.0.0
com.apple.iokit.IOHDCPFamily   1.0.0
com.apple.iokit.IOCECFamily   1
com.apple.iokit.IOAudio2Family   1.0
com.apple.driver.AppleEmbeddedAudioLibs   1.17
com.apple.driver.AppleFirmwareUpdateKext   1
com.apple.driver.AppleM2ScalerCSCDriver   265.0.0
com.apple.iokit.IOSurface   290.8.1
com.apple.driver.IODARTFamily   1
com.apple.security.quarantine   4
com.apple.security.sandbox   300.0
com.apple.kext.AppleMatch   1.0.0d1
com.apple.driver.AppleMobileFileIntegrity   1.0.5
com.apple.kext.CoreTrust   1
com.apple.security.AppleImage4   3.0.0
com.apple.iokit.IOCryptoAcceleratorFamily   1.0.1
com.apple.driver.AppleARMPlatform   1.0.2
com.apple.iokit.IOStorageFamily   2.1
com.apple.iokit.IOSlowAdaptiveClockingFamily   1.0.0
com.apple.iokit.IOReportFamily   47
com.apple.kec.pthread   1
com.apple.kec.corecrypto   11.1
com.apple.kec.Libm   1
** Stackshot Succeeded ** Bytes Traced 307000 (Uncompressed 759600) **
Tue Sep 14, 2021 4:07 pm
Re: Kernel panic - Panicked task: IndigoPluginHost
Not sure the answer on this one, mainly because my main home server Mac so rarely has a kernel panic. I'm running Indigo at home on an M1 Mac also with the Gen5 Z-Stick. Just about all Indigo related kernel panics I can remember have come down to bad memory, bad CPU, bad USB hardware, or a driver related bug.
Let us know if you see the problem again, as this is the first report of a kernel panic we've had in a long time.
I'd also suggest running Apple Diagnostics test on your Mac.
Sun Sep 19, 2021 7:17 am
NicholFD offline
Another kernel panic this morning, 7:10AM.
Again, pointing to:
Panicked task 0xfffffe167ac9af08: 3021 pages, 6 threads: pid 2152: IndigoPluginHost
I'll shut it down & run Apple diagnostics on it.
Sun Sep 19, 2021 7:52 am
NicholFD offline
Apple's diagnostics can't be doing much. I've run it 4 x times - twice online & twice offline.
Bar comes up & says testing, and an estimated 1 minute remaining. It runs for about 15 seconds, the bar makes it about 20% through, and then it completes and says no issues found, Diagnostics Code: ADP000.
From this page, https://support.apple.com/en-us/HT203747, ADP000 = No issues found.
Because it points to IndigoPluginHost, I'll start turning off plugins to see if it stays reliable.
Sun Sep 19, 2021 8:30 am
NicholFD offline
And Apple support (I have AppleCare+) was worthless. Support representative was nice, courteous, understood, and tried to help, but L2 told her what to do.
The Mac mini was purchased August 21, 2021. The first kernel panic occurred with the latest macOS, it was delivered with. The second kernel panic, in less than a week, occurred on the latest macOS - 11.6.
Support's answer - reload macOS! Or take it to an Apple Store (1h30m away) and they'll reload macOS! They're preferred method is from the recovery disk image.
I have time machine backups. I hope the reload & restore from TimeMachine works... I do NOT want to set this up from scratch again.
Sun Sep 19, 2021 11:22 am
Does it seem to be getting hot to the touch? I haven't heard of heat issues with M1 minis, but I know that my 2019 Intel mini is super sensitive to heat and must be on a stand with lots of airflow around it or it'll kernel panic.
Mon Sep 20, 2021 11:24 am
NicholFD offline
Hello Jay,
Nope - I've never had any of my M1 systems (3 x mini & 1 x MacBook Air) even get warm.
This one sits on a glass AV shelf, about 2.5' in the air, with nothing within 12". Never feels warm on the top. And it currently being warm/summer, there's an AC vent at the back of the AV shelf that would be blowing cool air it's way.
Now my Intel Mac minis... That's another story!
I've reloaded Big Sur 11.6 (without a wipe) form the image/recovery partition (per Apple's instructions), and put it back in service. I have not turned off any services yet.
We'll see what happens in another week or two.
Mon Sep 20, 2021 12:39 pm
It would be interesting to see if it is the same Plugin that caused both Kernel Panics. Note inside the panic report it shows the PID:
(639 in this case)
You can then try to match that up with the PID shown in Indigo's Event Log file. For example, here is the PID of the Z-Wave plugin I just started here:
Starting interface "Z-Wave 2021.1.1" (pid 83774)
Mon Sep 20, 2021 4:03 pm
NicholFD offline
Tue Sep 14 02:10 panic:
2021-09-07 14:49:51.056   Application   Starting plugin "Cynical SecuritySpy 2.4.3" (pid 639)
Sun Sep 19 7:10 panic:
2021-09-14 13:00:22.086   Application   Starting plugin "NEST Home 2.0.53" (pid 2152)
Mon Sep 20, 2021 5:57 pm
Bummer. I was somewhat hoping they would both be Z-Wave since that plugin relies on a driver, and I've seen drivers cause Kernel Panics before. So I'm back to thinking it is either: faulty memory, CPU, or corrupt OS. Hopefully the Big Sur reload will fix it.
Tue Oct 19, 2021 12:22 pm
NicholFD offline
Resolved..., Re: Kernel panic - Panicked task: IndigoPlugin
Just a quick update - seems the OS reinstall did resolve the kernel panics. No panics since September 19th (one month). I did have a power outage on October 10th that outlasted the UPS, so a little under a month.
I'm both pleasantly surprised & disappointed. Glad to have the issue resolved. Disappointed that a new/updated OS install would have issues like this.
Frank
Tue Oct 19, 2021 3:20 pm
Thanks for the follow-up Frank.
