New Mac (Big Sur), Indigo 2021, Powerlinc Issues
Sat Jul 24, 2021 12:51 pm
ketchup318 offline
Hi All
I just upgraded my Mac and moved my license over to the Big Sur OS, from my Catalina setup. I can't seem to figure out why Indigo won't connect to my Powerlinc. I've tried unplugging and replugging, restarting, factory resetting the powerlinc... nothing seems to work. Wondering if anyone has any ideas...
Marco
Jul 24, 2021 at 11:45:21 AM
Connected to PowerLinc 2413U interface on port usbserial-A906XN7L
PowerLinc address 49.F8.8B, firmware version 9.14
PowerLinc Unexpected command 02 73 (flushing)
Error resending previous command (failure response)
Error unknown command bytes received 00 00 (ignoring)
Error resending previous command (busy or unexpected command)
Interface Failure failed to establish connection with serial interface PowerLinc 2413U on port usbserial-A906XN7L
Sat Jul 24, 2021 1:03 pm
Re: New Mac (Big Sur), Indigo 2021, Powerlinc Issues
Check to make sure you have the right serial port selected. The OS upgrade might have changed the names.
Also, you might need a serial driver. I'm not sure which interfaces require an additional driver.
Sat Jul 24, 2021 1:19 pm
ketchup318 offline
Hi
This is the USB version of the powerlinc...
Although the config screen does have the usb port labeled as serial...there's only one option for me, and that's "usbserial-A906XN7L". I transferred the license and loaded up my old mac (catalina) and it seems to work fine. I'm wondering if maybe the powerlinc is too old?
Marco
Sat Jul 24, 2021 1:39 pm
Power cycle the device sometimes does it.
Sun Jul 25, 2021 1:01 pm
Does the version sticker on the PowerLinc say 2.5 or something older? We've had reports that v2.5 works better on some Macs because of an upgraded FTDI chip (used for serial to USB conversion internally).
Some things to try:
• Power cycle it (as Karl suggested)
• Factory reset it.
• Try different USB ports, including ports on any USB hubs you have.
• Try plugging it into an extension cord and trying multiple outlets on different circuits. This will help rule out a power line noise issue as the culprit, which has been known to confuse the PowerLinc enough that it starts to fail to properly communicate with Indigo.
