Preamble FWIW: Earlier, I got the following error because I had switched to a new admin user for managing Indigo 2021.1.
OError: (13, 'Permission denied', u'/Library/Application Support/Perceptive Automation/Indigo 2021.1/Logs/indigoplugin.alexa/plugin.log')
I removed/reinstalled Indigo with the new user.
Then I noticed this morning that Alea commands were not working and the Events log files revealed the following:
_________________________
[End of 2021-07-07 Events.txt]
2021-07-07 22:10:39.233 Received X10 "Hall Lights" off
2021-07-07 22:10:39.233 Received X10 "Hall Sconces" off
2021-07-07 22:10:39.235 Alexa Debug deviceUpdated: Hall Lights
2021-07-07 22:10:39.235 Alexa Debug original device type: DimmerDevice, updated device type: DimmerDevice
2021-07-07 22:10:39.235 Alexa Debug IndigoDeviceEndpoint.__init__ called with device: 1946141867 (Hall Lights)
[EOF of 2021-07-07 Events.txt]
__________
[Start of 2021-07-08 Events.txt]
2021-07-08 00:00:10.909 Application Created new log file (Indigo Server version 2021.1.0)
2021-07-08 00:09:22.708 Error XML Parse Error: not well-formed (invalid token)
2021-07-08 00:09:22.708 Error On character 0 of line number 1.
2021-07-08 00:09:24.350 Application Client authentication failed - bad XML received (91.220.163.61)
2021-07-08 00:09:24.975 Application Client disconnected (91.220.163.61)
2021-07-08 00:09:24.975 Error XML Parse Error: not well-formed (invalid token)
2021-07-08 00:09:24.976 Error On character 0 of line number 1.
2021-07-08 00:09:24.976 Error XML Parse Error: syntax error
2021-07-08 00:09:24.976 Error XML Parse Error: not well-formed (invalid token)
2021-07-08 00:09:24.977 Error On character 0 of line number 1.
2021-07-08 05:52:10.009 Schedule Lav Bowls - OFF
2021-07-08 05:52:11.297 Sent X10 "Lav Bowl Lights (2)" off
2021-07-08 06:02:01.536 Application Disabling plugin "Alexa 2021.1.0"
2021-07-08 06:02:01.536 Application Stopping plugin "Alexa 2021.1.0" (pid 35727)
2021-07-08 06:02:01.556 Alexa Debug shutdown called
2021-07-08 06:02:02.662 Application Stopped plugin "Alexa 2021.1.0"
2021-07-08 06:02:13.558 Application Enabling plugin "Alexa 2021.1.0"
2021-07-08 06:02:13.559 Application Starting plugin "Alexa 2021.1.0" (pid 90527)
2021-07-08 06:02:13.938 Alexa Debug Debugging enabled
2021-07-08 06:02:13.943 Application Started plugin "Alexa 2021.1.0"
2021-07-08 06:02:13.943 Alexa Debug startup called
2021-07-08 06:02:13.943 Alexa Finding devices to publish to Alexa...
