DaveL17 wrote:With Z-Wave locks, encryption can also be an issue. By that, I mean that the locks need to be included into the Z-Stick with encryption and there must be a path between the Z-Stick and the lock that honors this encryption.
Since you are starting from scratch, I'd suggest getting a new Z-Stick (there are different brands) that supports the latest standard (Z-Wave series 700 as of now). See https://aeotec.com/z-wave-usb-stick/z-stick-7.html and https://aeotec.com/z-wave-home-automation/z-wave-gen7.html as examples.
jalves wrote:A simple solution to range issues is to buy a couple of plug-in Z-wave devices and locate them between your locks and the z-stick. Something simple and useful like a Aeotec Multi sensor would work as long as it is plugged in (not run on batteries) where you install it. That device will also provide you potentially useful information about movement, light and humidity levels.
