2021-07-20 06:37:00.758 Application Starting Indigo Server version 2021.1.0 on macOS Version 11.4 (Build 20F71)
2021-07-20 06:37:00.994 Application Loading database "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Databases/Haus.indiDb"
2021-07-20 06:37:01.412 Application Stopped plugin process (pid 412)
2021-07-20 06:37:01.443 Application Loading disabled plugins
davinci wrote:I am pretty sure this issue is wide spread - but not known.
Look for "Starting Indigo Server" in the logs.
davinci wrote:If I disable Email+ it reenables after every restart. I think this is a bug of Indigo, right?
davinci wrote:The crash could be caused by GhostXML ( I didn't realize that I just installed this around the same time the crashed happened the first time).
It is disabled for now - all other plugins remain active. I hope this is it - even though that means I can't use the plugin and there is an issue in Indigo that needs to be resolved.
davinci wrote:Looks good - or bad - GhostXML was disabled but it still crashed.
Going on with other plugins...
