IndigoServer Crash 2021.1.0
Sat Jul 03, 2021 6:49 am
davinci offline
Server just crashed, but luckily also restarted:
Process:               IndigoServer [367]
Path:                  /Library/Application Support/Perceptive Automation/*/IndigoServer.app/Contents/MacOS/IndigoServer
Identifier:            com.perceptiveautomation.indigo-server
Version:               2021.1.0 (2021.1.0)
Code Type:             ARM-64 (Native)
Parent Process:        ??? [1]
Responsible:           IndigoServer [367]
User ID:               501
Date/Time:             2021-07-03 13:53:21.019 +0200
OS Version:            macOS 11.4 (20F71)
Report Version:        12
Anonymous UUID:        7D192588-D20C-4625-BD56-49E2A538145D
Time Awake Since Boot: 1400 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
IndigoServer(367,0x10563fd40) malloc: *** error for object 0x14773b500: pointer being freed was not allocated
Sat Jul 03, 2021 8:17 am
davinci offline
Re: IndigoServer Crash 2021.1.0
Seems to be reproducible after every reboot.
Sat Jul 03, 2021 10:47 am
At what point does the Indigo Server crash after a reboot (Event Log file might have a clue)?
Are there any specific steps you are doing before it crashes?
Sat Jul 03, 2021 1:53 pm
davinci offline
I will check the log. It just crashed again.
Sat Jul 03, 2021 2:25 pm
davinci offline
The log just shows the restart of the server. Nothing specific about the crash. I looked for "Indigo Server".
It crashed three times today.
Time Awake Since Boot: 23000 seconds
Time Awake Since Boot: 3200 seconds
The time of the crashes seems to be very specific.
I updated Fantastic Weather today, so that *might* be related. I disabled it for now - just to be sure.
Sat Jul 03, 2021 4:04 pm
I doubt that the plugin is the cause -- plugins run in their own independent thread to protect against this very thing. That said, please let me know if you find it's somehow related.
Sun Jul 04, 2021 5:14 am
davinci offline
I agree, but the crashes all happened since the update and since I disabled it yesterday, I haven't had any additional crash.
Sun Jul 04, 2021 5:19 am
If the plugin is indeed the cause (or a contributing factor) we need to figure that out asap. A plugin shouldn't be able to bring down the server, but that doesn't mean it's not happening. That said, yours is the only report of this nature I've seen.
Sun Jul 04, 2021 5:36 am
davinci offline
Well I am running on an M1 Mac mini. Also I am monitoring the restart of the server by sending me a push message. Otherwise I wouldn't even know it.
I will report here if it happens again after I uninstalled the plugin.
Sun Jul 04, 2021 12:06 pm
From looking at the stack trace Indigo Server is crashing while it is trying to process an incoming command/request. I don't know where the request is coming from, but likely a plugin, the Indigo client or Web server, or a script. Definitely looks like a bug in that the server shouldn't crash regardless of the format/arguments in the commands/requests it receives, but it is. If re-enabling the plugin causes it to crash again consistently, then we should investigate it more to try to figure out how.
Sun Jul 04, 2021 12:38 pm
@Matt - as an FYI, the Fantastic Weather plugin is not taking advantage of any of the new additions to the Indigo API or new web server functions.
Sun Jul 04, 2021 2:12 pm
davinci offline
I should also mention that with the previous version of the plugin there were no such crashes. After the update I had three in a row. Now since one day not a single crash.
I can try reinstalling the plugin when I have more time to monitor.
As far as I know there were no other changes to the Mac.
I do use Python scripts extensively though. :lol:
Sat Jul 10, 2021 2:16 am
davinci offline
Not one crash happened since.
Sun Jul 18, 2021 10:35 am
davinci offline
Crashed again, without Fantastic Weather:
Process:               IndigoServer [362]
Responsible:           IndigoServer [362]
User ID:               501
Date/Time:             2021-07-18 17:06:04.820 +0200
Report Version:        12
Time Awake Since Boot: 13000 seconds
abort() called
IndigoServer(362,0x1030d3d40) malloc: *** error for object 0x12dc15680: pointer being freed was not allocated
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
Sun Jul 18, 2021 12:38 pm
It's interesting (and possibly coincidence) that the Time Awake Since Boot is precisely 13000 seconds.
