Minoston Z-Wave Dimmer Switch
Mon Mar 22, 2021 3:59 pm
PETStech offline
Has anyone tried/succeeded installing a Minoston Z-Wave Dimmer Switch?
https://minoston.com/product/z-wave-plus-smart-dimmer-switch-%EF%BC%88ms11z%EF%BC%89
- Tom
Tue Mar 23, 2021 9:54 am
Re: Minoston Z-Wave Dimmer Switch
It looks a lot like the generic dimmers made by Jasco and sold by Honeywell and others. In any event, it will most likely work as a standard dimmer. If it has any advanced features you might have to configure those using the Modify Config Param menu item rather than through built-in UI on the device edit dialog. No promises of course, but it's very likely to just work.
Fri May 21, 2021 10:50 am
PETStech offline
Belated thanks. Will let you know how well it works if/when I get Aeotec Z-Stick Gen5 Plus and dimmer installed…
Tue Nov 30, 2021 4:01 pm
K3LAG offline
I've not used the wall switch but I have used their Mini Smart Plug Dimmer (MP21ZD). They work fine. Indigo doesn't have a profile for them yet but I did submit the information.
Tue Nov 30, 2021 4:25 pm
PETStech offline
Haven't had time yet to install/test the Minoston, bur if/when I do I'll post a report, here.
- Tom
