- Posted on
Tue Dec 15, 2020 6:14 pm
matt (support)
offline
- Site Admin
A trial license could have been grabbed by a different Mac Server, but since you are seeing it start to work once you access from the Mac client this is something different. It sounds like the macOS is sending Indigo a sleep notification message, which causes it to disconnect the interfaces cleanly before the sleep occurs. In some cases (especially if a macOS install is in a funky state), the actual sleep never occurs. Check your Event Log for and sleep related messages. If you see any then check your Energy Saver macOS settings and make sure your mac is set to never sleep.
