Convert Server to Client?
Thu Sep 24, 2020 3:32 pm
lwhitten offline
I can't be the first, but can't find an answer, so... I moved Indigo to a different computer, and now use what used to be the server installation as a client. That is working just fine, but whenever I start Indigo on the client machine for the first time, it also starts a server, which just burns CPU in the background until I remember to stop it.
I cannot figure out how to keep the server from starting - do I need to uninstall, and then install just the client?
thanks
Thu Sep 24, 2020 3:48 pm
Re: Convert Server to Client?
If you choose the Indigo 7.4->Stop Server menu item, then choose Indigo 7.4->Connect to Remote Server it should upon next launch remember to just connect to the remote server (and not start the local server). You can also archive/delete the folder:
/Library/Application Support/Perceptive Automation/Indigo 7.4
Tue Sep 29, 2020 3:04 pm
lwhitten offline
Thanks - I did try that first, but every time I reboot the server starts. I'll bump that folder out and install as client.
