Replaced PowerLink USB 2413U, V1.7 to 2.5
Mon Sep 21, 2020 5:21 pm
AlaskaDave offline
Recently I lost all lights (on PowerLink) and communication to my PowerLink. When changing these out is there a process to follow or just plug and and you're off and running? Thanks for any help one can give.
Mon Sep 21, 2020 5:55 pm
AlaskaDave offline
Re: Replaced PowerLink USB 2413U, V1.7 to 2.5
Looks like I found my answer:
Questions: Does this mean that I need to wake up all my motion sensors by removing them and having them close at hand so I can press the set button on the inside with the batteries?
Replacing Your PowerLinc
Tue Sep 29, 2020 12:26 pm
AlaskaDave offline
Well, not responses to my post so will follow-up myself. I found that many if not most of my battery devices required re-sycing so required some footwork to update their communication with the new PowerLink. The previous PowerLink needed to be reset during power outages, not sure if this one will require the same thing... not easy when you're away from the house. I noticed that some of my plug-in devices also required being reset and were not responding to timers and or the iPhone application. All in all I got everything working again, hope this PowerLink lasts at least as long as the previous one. I've read that overheating is the culprit according to Insteon, not sure how accurate that is as it's the only thing in the outlet and is in a cooler room of the house.
Mon Dec 07, 2020 11:07 am
t-star offline
Just wanted to provide a note here for others. I just replaced my 2413U that was a v1.0 with a v2.5. I was regularly getting errors from my keypad links (especially if I did a status request on them) and they have all pretty much gone away. Am seeing much less red in the logs so it appears that the upgrade has certainly resolved some bugs.
If you are having issues that you can't seem to resolve and you have an old version, may want to consider the upgrade.
Mon Dec 07, 2020 11:42 am
Good information, thanks. That newer version also seems to (somewhat?) mitigate the FTDI driver issue as well. Anyone planning on continuing the use of Insteon and has a version older than 2.5 might want to consider upgrading for what appears to be a couple of good reasons.
Mon Dec 07, 2020 11:53 am
t-star offline
Yes. That was the other reason I upgraded. I did the clean install of 10.15 and had no issues with the FTDI driver on a 2014 Mac mini.
