indigo_7_4_1.dmg image not recognized error
Wed Feb 12, 2020 12:00 pm
Butch2427 offline
I have Indigo 7.4 running well and attempting to upgrade to 7.4.1. After downloading the file and attempting to open it, I receive the following error message:
I re-dowloaded the file thinking maybe it became corrupted but with the same result. Is my machine just to old now?
I'm running Indigo on an iMac (21.5-inch, Mid 2010) with macOS Sierra version 10.12.6
Thanks, Butch
Wed Feb 12, 2020 12:23 pm
Re: indigo_7_4_1.dmg image not recognized error
Can you take a screenshot of what you're seeing?
Wed Feb 12, 2020 12:42 pm
Butch2427 offline
here ya go.... also, no luck right clicking and then open
Screen Shot 2020-02-12 at 10.38.58 AM.png (49.68 KiB) Viewed 1051 times
Wed Feb 12, 2020 4:32 pm
We tested 7.4.1 and have several users using it on macOS Sierra, so I don't believe your macOS version is related. This can happen if there is a corrupt download. I know you downloaded it twice, but I'd suggest doing it again from a different browser (use Chrome if you used Safari before, for ex).
Wed Feb 12, 2020 4:39 pm
Also make sure you don't have any third-party archive applications attempting to open that disk image. Maybe try running Disk Utility.app and see if it can open it.
Wed Feb 12, 2020 6:09 pm
Butch2427 offline
Re: indigo_7_4_1.dmg image not recognized error [SOLVED]
The problem was google chrome. When downloaded with Google Chrome version 79.0.3945 (64 bit) the file indigo_7_4_1.dmg the file was not usable. I tried several different downloads but all had the same result. I even accounted for my crappy satellite (HughesNet)connection by using a hot spot. Downloading the file with Safari solved the problem. It installed with zero errors and appears to be functioning as it should.
Thanks all for your support.
