So, I right click on the package, click Open. Click on Continue, to go to `Destination Select'. Installer hangs up. Left it to churn overnight. Nothing. Tried this 3 times now. Any ideas?
I'm only going to 7.4 as my version (7.04) won't start properly (it says Indigo server not running at startup), since I upgraded the mac to Catalina. Running the startup script as advised to another user in another thread, in Terminal, this is what I get
TrevorsiMac:IndigoWebServer trevorsmith$ ./IndigoWebServer.py -i1176 -w8190 -cfn
File "./IndigoWebServer.py", line 432, in <module>
cherrypy.engine.start()
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/process/wspbus.py", line 184, in start
self.publish('start')
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/process/wspbus.py", line 147, in publish
output.append(listener(*args, **kwargs))
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/_cpserver.py", line 90, in start
ServerAdapter.start(self)
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/process/servers.py", line 53, in start
wait_for_free_port(*self.bind_addr)
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/process/servers.py", line 251, in wait_for_free_port
raise IOError("Port %r not free on %r" % (port, host))
IOError: Port 8190 not free on '0.0.0.0'
So, its a port contention issue I guess. How should I know which port to use? I'm just a home user, not a shell or OS expert
In short, I'd rather my current version ran, but if I need to upgrade to 7.4 then help me get that installed please.
