Since macOS Catalina will remove Python and 2.7 will be deprecated on 1.1.2020, I guess we will need to upgrade to the latest version.
What do we have to do?
Will 7.4 support Python3?
Any concerns?
Deprecations
- Scripting language runtimes such as Python, Ruby, and Perl are included in macOS for compatibility with legacy software. Future versions of macOS won’t include scripting language runtimes by default, and might require you to install additional packages. If your software depends on scripting languages, it’s recommended that you bundle the runtime within the app. (49764202)
- Use of Python 2.7 isn’t recommended as this version is included in macOS for compatibility with legacy software. Future versions of macOS won’t include Python 2.7. Instead, it’s recommended that you run python3 from within Terminal. (51097165)
davinci wrote:Why is it so "difficult" to just use Python3 now?
This is only used for Indigo scripts, right? The syntax should remain the same anyway.
I mean on 1.1.2020 Python 2.7 is history - aka not supported anymore.
Look here:
https://pythonclock.org
Look here:
neilk wrote:The implications of “out of support” are not anything like that of an OS..
FlyingDiver wrote:Because Python2 is included in MacOS X. Python3 is not.
papamac wrote:Would it be possible to allow the indigo server to select the Python runtime environment at startup? This would allow legacy plugins to run and give developers the opportunity to test Python 3 upgrades as well. It seems like a good transition plan. I'm sure that you have considered this, but I'd appreciate your thoughts.
davinci wrote:How can I install Python3 without issues with Indigo?
How can I run Python3 scripts from Indigo? Run a Terminal command?
