Help with Indigo Database Name and Location Confusion
Fri Aug 23, 2019 4:00 pm
gadgetnut offline
Hello, after copying the Indigo 7.3.x folder to /Library/Application Support/Perceptive Automation/ on the new computer, our move to a new Mac Mini appears to be working well. However, the database name in Indigo title bar reads like this:
Smith HA 1a (v7.1.1) (v7.1.1)(v7.1.1)(v7.1.1)
I believe at one time in the service history the database had been purposefully relocated to a different location or the client had difficulty locating the current database...
Two questions, please.
1.) is there a way to locate (including the filepath) the currently open and active Indigo database? Just to make sure there's no confusion that we are copying/moving/backing up the most current/active database?
2.) what steps should I take to rename this database to something simpler and more helpful?
Fri Aug 23, 2019 8:35 pm
Re: Help with Indigo Database Name and Location Confusion
I can't answer your questions about why the filename is appearing the way it is, but if you Command Click the banner of the Indigo Home Window, it will show you the entire path to the active database:
Screen Shot 2019-08-23 at 9.33.54 PM.png (120.22 KiB) Viewed 1236 times
Fri Aug 23, 2019 8:47 pm
gadgetnut offline
Hi, Dave, thanks very much for reminding me.. I had tried a couple such tricks earlier, but missed this. This “correctly identifying the working file” workflow has important ramifications (recent chaos in a client’s QuickBooks data file)- ha, ha, thanks again!
Fri Aug 23, 2019 9:12 pm
You bet.
Sat Aug 24, 2019 11:10 am
If you continue to see the version number added to the filename, then you might have a problem with multiple versions of Indigo installed (and different versions getting started up at different times) or you might have a folder permissions problem and Indigo isn't able to update its preference file. For the former I'd suggest removing older versions of Indigo you aren't using. To see if it is the latter check for errors in the Event Log.
Mon Aug 26, 2019 12:28 pm
gadgetnut offline
Thank you, Matt. I will remove any old versions of Indigo and see if that helps. If not, I'll look to the Event Log. Meanwhile, are there any specific tips or concerns re: quitting Indigo/Indigo Server and renaming the current data file to something simpler like Smith HA 2?
Mon Aug 26, 2019 3:30 pm
You can rename it to whatever you please. Just stop the Indigo Server first, rename, then restart it. If Indigo doesn't find the renamed file upon restart just double-click it in the Finder.
