Indigo 7.3.0 restarting server every 2-3 minutes
Tue Apr 30, 2019 7:41 pm
sparker offline
I just installed 7.3.0 on a Mac Mini running 10.13.6. It updated my database, started up, runs for 2 minutes then the server dies. If I restart it, it dies again.
I see nothing unusual in the Indigo logs, but some strange things in the console logs:
I'm attaching a log of the console filtered for Indigo, but I have no idea where to go from here. Is there a better crash log I can send for assistance with getting it running again? Now that it's migrated/converted the DB, I'm kinda stuck with failing forward. I can restore my latest whole-disk image of the server if it comes down to that.
Steve
IndigoConsoleOutput.txt
(27.55 KiB) Downloaded 23 times
Steve Parker
X10 user from the early 80's
Fully converted to Insteon in 2013
Proud Indigo owner since the beginning... :)
Wed May 01, 2019 10:42 am
Re: Indigo 7.3.0 restarting server every 2-3 minutes
Hi Steve,
Email us (indigo-support AT indigodomo.com) the most recent couple of Indigo related crash report files from:
/Library/Logs/CrashReporter/
/Library/Logs/DiagnosticReports/
Also email us the most recent couple of Event Log files from Indigo itself:
/Library/Application Support/Perceptive Automation/Indigo 7.3/Logs/
Wed May 01, 2019 5:03 pm
sparker offline
matt (support) wrote:
Hi Steve,
Done! And Thanks for your help!
Steve
Steve Parker
Mon May 06, 2019 8:33 pm
sparker offline
So. Playing around a little more.
- If I start Indigo, then turn on "Check email every 10 minutes", Indigo doesn't crash like it does when I had that checked on startup.
- If I leave the option checked, quit indigo, and restart the server, it will crash every time within about 5-10 minutes
- If I start Indigo and uncheck the "Check email every 10 minutes" option, Indigo will run indefinitely.
- If I change the Indigo Preferences | Email settings, reset all settings, quit and restart the app, and reset them back to what they were before, Indigo still crashes
I still can't get or send mail.
I'm seeing the following in the logs:
May 6, 2019 at 8:29:22 PM
   Trigger                         Bench Seat Opened - Send email
   Error                           SSL handshake with SMTP email server failed (-2)
   Error                           email re-send scheduled in 10 minutes
Is there some kind of debug mode I can turn on to help try to figure this out?
Steve
Steve Parker
Mon May 06, 2019 8:51 pm
sparker offline
lanbrown wrote:
Have you looked at the Better email plugin? It is far superior to the built-in email. Matt or Jay even said it was better in a post elsewhere.
Nope. Never heard of that at all. I'll take a look at it now to see if I can get through this.
Thanks for the tip.
Steve Parker
Tue May 07, 2019 8:31 am
I think maybe you didn't get my reply email. I sent a reply on 5/3 with some suggestions (including the Better email plugin). I'll re-send that to you now.
Fri May 10, 2019 9:51 pm
sparker offline
You are correct. I didn't get the 5/3 email. I will install and reconfigure to use that plugin over this coming weekend.
And thanks to you, support, and the community for such a fantastic product, help, plugins, and sharing opinions and ideas. It's amazing how much I've come to rely on the ecosystem that I've built out over all these years,... :)
Steve
Steve Parker
Thu May 23, 2019 7:12 pm
sparker offline
I converted to the "Better Email Plugin" and disabled all the embedded email messages (man, I created a lot of cruft over the last 10 years). Thinks are working flawlessly again!
Thanks to all for the tip/suggestion to switch. I guess it's time to go look through the Plugin library again. It's been awhile... :)
Steve
Steve
Steve Parker
