Indigo 7.3
Thu Apr 18, 2019 10:40 am
Re: Indigo 7.3
You’re welcome Jay.
Fri Apr 19, 2019 9:26 pm
t-star offline
Re: Indigo 7.3
Upgraded today to 7.3. getting the following error with the HomeSeer 200+ switches. Setting LED mode into either normal or custom mode. Get the same error.
2019-04-19 22:49:08.250 Action Group LED: FIR-KIT-SNK LED = Normal
2019-04-19 22:49:08.255 Action Collection Error Unexpected action typeId value of 'setLedMode2'.
2019-04-19 22:49:08.255 Action Collection Error failed to set LED mode for device id '546522499'
Had to go back to 7.2. Was doing this for all HomeSeer devices.
Screen shot attached on the action configuration.
Running macOS 10.10.5
Screen Shot 2019-04-19 at 11.14.42 PM.png (279.98 KiB) Viewed 1049 times
Fri Apr 19, 2019 9:27 pm
Re: Indigo 7.3
I actually ran into this same bug earlier today. We'll get a 7.3.1 released in the next couple of days to take care of it. Thanks for the report.
Fri Apr 19, 2019 11:21 pm
dduff617 offline
Re: Indigo 7.3
I'm testing the new scene brightening, dimming commands. I'm using a scene consisting of two lamplinc's.
The commands seem to work, but each time I execute one of the commands, I see some errors in the logs. For example, when I try the "dim by 3% command" from a control page, I see this in the logs:
   WebServer                       request to execute "_preview_control page" control #6 from 192.168.1.253
   Sent INSTEON                    "PowerLinc Interface" dim by 3 (scene 19 - FR Lights slow ramp)
   Error                           should never send dim direct command
   Sent INSTEON                    " group Family Room Torchiere Lamp North" dim by 0 (scene 19 cleanup)
   Sent INSTEON                    " group Family Room Torchiere Lamp South" dim by 0 (scene 19 cleanup)
I see similar error messages when using "start brightening", and "start dimming" commands as well.
Tue Apr 23, 2019 8:32 pm
Re: Indigo 7.3
Thanks for the bug report. We'll get this fixed in 7.3.1.
Tue May 07, 2019 8:07 am
stewkenly offline
Re: Indigo 7.3
I am seeing a couple of issues, some of which I believe you are already aware of.
1. Weathersnoop doesn't work. I have also filed a bug report with Boisy, no response yet. Appears to be an XML problem?
   Error                           device "Weather Station" state key dayRain_- not defined (ignoring update request)
   Error                           device "Weather Station" state key monthEvapotranspiration_- not defined (ignoring update request)
   Error                           device "Weather Station" state key stormRain_- not defined (ignoring update request)
   Error                           device "Weather Station" state key last24HourRain_- not defined (ignoring update request)
   Error                           device "Weather Station" state key dayEvapotranspiration_- not defined (ignoring update request)
   Error                           device "Weather Station" state key rainRate_- not defined (ignoring update request)
   Error                           device "Weather Station" state key windSpeed_f/s not defined (ignoring update request)
   Error                           device "Weather Station" state key twoMinuteAverageWindSpeed_f/s not defined (ignoring update request)
   Error                           device "Weather Station" state key yearRain_- not defined (ignoring update request)
   Error                           device "Weather Station" state key tenMinuteWindGust_f/s not defined (ignoring update request)
   Error                           device "Weather Station" state key tenMinuteAverageWindSpeed_f/s not defined (ignoring update request)
   Error                           device "Weather Station" state key yearEvapotranspiration_- not defined (ignoring update request)
   Error                           device "Weather Station" state key monthRain_- not defined (ignoring update request)
2. Action Collection does not work. I am unable to configure new action collection actions, such as inserting a device state into a variable. Existing AC's just don't work
Error Action has not been completely configured
Any word on an update to Indigo to fix?
thanks!
Tue May 07, 2019 8:39 am
Re: Indigo 7.3
1) Yes, they know about this issue. The WeatherSnoop plugin is now being maintained by them.
2) This is the first we've heard of this so it's not a widespread issue. Can you give us Event Log entries (copy/paste) with any applicable errors?
Fri May 10, 2019 8:44 pm
stewkenly offline
Re: Indigo 7.3
Hi Jay, Thanks for the quick reply to my post. I didn't get notified of the update to the thread... need to figure out what I disabled.
Anyway, I have a ticked filed with Boisy about weathersnoop and no word yet... UPDATE. Immediately after posting this I see an update to Weathersnoop (4.1.9) and the XML error is gone.
The Action Collection issue was that it failed to start. I missed that during the migration. It seems INDIGOplotD has been taking a long time to start. Disabling that plugin and everything comes up roses during a server restart.
I'll debug that some more.
Thanks again,
Fri May 10, 2019 9:15 pm
Re: Indigo 7.3
Indigoplotd reads the sql database when starting. You can set it to only read the last 2 days. Then it is MUCH FASTER
Sun May 12, 2019 2:15 pm
Re: Indigo 7.3
Indigo 7.3.1 is now available and should fix this problem.
Sun May 12, 2019 2:17 pm
Re: Indigo 7.3
dduff617 wrote:
I'm testing the new scene brightening, dimming commands. ... The commands seem to work, but each time I execute one of the commands, I see some errors in the logs.
This one is also fixed in Indigo 7.3.1.
Mon May 20, 2019 1:02 pm
TwitchCaptain offline
Re: Indigo 7.3
hi guys! I just upgraded to Indigo 7.3.1 from 7.2; apart from having to reload a few plugins, it seems good. I have 17 wadwaz-1 window sensors and all of them say "needs re-sync" in ugly red letters under State. When I click the State column, they are not properly ordered by this value making troubleshooting even more frustrating. I tried to re-sync a couple: timeout errors. That's expected since they're battery operated. So I click sync and open/close the window a few times. It still doesn't sync.
Any idea how I fix this? I'm not real sure what the best way to re-sync a window sensor is. Do I have to unscrew them all and press the button?
Can I put in a feature request that the State column allows ordering of the "error" value (being displayed) instead of the hidden value?
-captain
PS. Is this happening because the secondary sensor in the wadwaz-1 has been added as a device in 7.3? If yes, yay! <3
EDIT: I unscrewed one and pressed the button. It synced. Two more sensors appeared. Amazing! Any way to do this without pushing the buttons? haha thanks again!
Tue May 21, 2019 12:37 am
Re: Indigo 7.3
You’ve answered your own question there; sync needs doing by whatever method the manufacturer implemented - which is usually a button, particularly if its battery powered.
Re sorting the column, that’s one for Matt/Jay to look at. As plugin devs we can set two values for state, one for calculations and one for visual - say “10” and “10° C” - I don’t know if they’re using the uiValue to display the sync message, or some other way.
Wed May 22, 2019 10:06 am
Re: Indigo 7.3
This has been discussed many times over the years. We may someday revisit how that sorting is done, but suffice it to say that there are opinions on how that sorting should work and not a good general consensus when they don't work as you might expect... :lol:
Wed May 22, 2019 4:27 pm
Re: Indigo 7.3
It would be nice to have a defined format for units of measurement in the indigo preferences that all plugins would follow.. ability to set °C or °F, how that unit is displayed in the device list, and alternate options for it that’d automatically show when doing things like control pages. And then just having two values to work with in indigo, a float and integer version. Everything else done by indigos preferences on the fly!
