Indigo 64bit version in the pipe line?
Wed Mar 06, 2019 1:22 pm
msageryd offline
I got a message in Mojave when starting Indigo after a system update. See attached screen capture.
It seems that Indigo is still a 32 bit app. Are there any plans for making a 64 bit version? Apple will stop supporting 32 bit apps at some stage (no date is set yet).
Thu Mar 07, 2019 3:02 am
msageryd offline
Re: Indigo 64bit version in the pipe line?
Thanks.
Stupid me, should have done a better search before posting.
Thu Mar 07, 2019 4:40 am
siclark offline
To be fair I knew it had been, tried to search for any and couldn't find them. Tried searching on 64 bit and didn't get any joy.
Thu Mar 07, 2019 7:30 am
I’d rather 65 bit support. It’s clearly 1 better than 64 bit.
Thu Mar 07, 2019 10:58 am
Unfortunately, one of the biggest failings of phpbb is that there are some words/letter combinations which are not indexed well (or at all) so they don't show up in searches. This one falls in that category. I did tweak the post that is linked to above to include "64bit" to help with the searching.
Thu Mar 07, 2019 12:48 pm
Just a note that you can often find Google will help get around the limitations of phpbb indexing and I can often get useful results not available through the forum's built-in search function.
Thu Mar 07, 2019 12:55 pm
siclark offline
I'll have one meeeeelion bits.
Thu Mar 07, 2019 4:54 pm
Dual offline
Agreed. I add site:forums.indigodomo.com to the search line in google to get results from the forums only.
Thu Mar 07, 2019 5:03 pm
+1
I should have added that, too. I do the same thing.
Thu Mar 28, 2019 11:25 am
masterblaster offline
Support for X86-64 would be enough for me. Among other improvements, the X86-64 architecture provides twice the number of CPU memory registers over the X86 architecture, which usually yields a significant increase in speed. Twice the registers means slow writes/reads to main memory occur less often. In other words, the move to "64-bits" isn't just about the increased precision available. Some applications work just fine within 32-bits native precision but would still benefit from using the "new"* hardware and software architecture.
*X86-64 is almost 20 years old.
Thu Mar 28, 2019 12:45 pm
Did you think I was being serious?
Mon Sep 30, 2019 3:58 pm
Fri Oct 11, 2019 11:05 am
dprlemon offline
Hey Matt, I installed the 64 bit version and it’s working great. I was a little concerned about it breaking my Apple scripts but found all the functions they performed were built into Indigo. I don’t know if they were new or I missed them originally, but thanks for that.
My question. I’m preparing g my Mac for Catalina and I found a number of Indigo folders in Library-Application Support-Perceptive Automation, starting with Indigo 4. Do I need to keep these or can the be trashed?
As always, thanks for your support.
Fri Oct 11, 2019 1:10 pm
Most likely you don't need any of those anymore. That said, I'd probably back them all up somewhere just in case there is a script or something in there you might need.
Fri Oct 11, 2019 4:26 pm
Just be careful.. I found a plugin that for some reason still had references back to the old Indigo 7.2 directory in its preferences (In this case it was the HomeKit Bridge one but I imagine it could happen with others) so perhaps before removing them shut down your indigo server, backup, rename the folders then start everything back up again to make sure that everything works!
