Aeotec Multisensor 6 V1.07 - Config Parameter
Sat Feb 16, 2019 5:15 am
Busta999 offline
I am probably doing this wrong.....
I want to set an offset for the multi sensor temp.
It consistently reads about 1.5C above actual - I use a reference Thermometer to calibrate digital temp sensors.
All the Hue Temp Sensors each to do but the Aeotec requires a parameter setting.
The Device
Mulisensor - Device.jpeg (19.35 KiB) Viewed 1205 times
The Manual
Multisensor - Manual.jpeg (127.87 KiB) Viewed 1205 times
Setting the Parameter
Multisensor - Save New Value.jpeg (62.46 KiB) Viewed 1205 times
Then Read back the Parameter
Multisensor - read set value.jpeg (62.81 KiB) Viewed 1205 times
What stupid thing am I doing that is stopping g this from working - any ideas anyone?
Sat Feb 16, 2019 6:16 am
Re: Aeotec Multisensor 6 V1.07 - Config Parameter
Have a look at this explanation -- there is a specific section to setting parameter 201 on v1.07. Once you wrap your head around it, it's not that bad.
Sat Feb 16, 2019 2:08 pm
Busta999 offline
Thanks, both......
Dave - it worked.
Will research how to update fw.
