I use the following plugins:
- Homebridge
Ecobee 2 (this will be new as I can't use it yet due to the OS I am currently running)
Airfoil Pro
Z-Wave lock manager
iTunes
MyQ
NOAA. Weather Plus
Dual wrote:Thanks Ian. Good to know. I had seen in the documentation that a USB extension cable is not recommended.
Dual wrote:I am fine standing the Mac mini on it’s face. It will be placed high up in a cupboard out of sight. Hopefully it cools itself sufficiently. I may put a temperature sensor in the cupboard to monitor it so it doesn’t overheat in the enclosed space.
CraigM wrote:On the previous mini's the air INTAKE is on the bottom front, so unless the 2018's airflow path is designed different that would be a very bad way to orient the mini. Especially in an enclosed cupboard.
siclark wrote:This post is great timing... I am considering an upgrade from my 2014 i3 4GB unit that is struggling running Indigo and SS. I am wondering about getting another used 2014 model, but a i5 or i7 with maybe 16GB memory, or spend over double, and get a 2018 new model of similar spec? Guessing by the number of people on here with old boxes running Indigo with no problems, then the used model should be ok, especially if a lot of RAM?
