Replacement or upgrade from Insteon Powerlinc controller
Tue Feb 05, 2019 6:57 pm
greenhornet offline
Hey everyone,
I've been running Indigo for roughly a decade. I have a Mac mini connected to a Powerlinc 2413U and I'm looking to replace the Powerlinc. It seems that the quality of the Insteon devices has really declined in recent years. Every few years, my PowerLinc starts acting flaky and not controlling devices. If I unplug it, wait a bit and then plug back in things will work normally for a few days/weeks but eventually the problem will get worse and the controller will need to be replaced. This has been true for most of the newer Insteon devices I buy. The old stuff (some of it over 10 years old) just keeps working. I'm tired of buying a new controller every year or two and would rather not buy another SmartHome (or whatever they're calling themselves these days) product and continue to reward them for shoddy products.
I know that Indigo is more than capable of working with multiple platforms and interfaces but I have limited experience with devices outside the Insteon protocol. I have A LOT of Insteon devices. Probably over 100.
So.... can I get some recommendations on a new controller? I'm willing to look at other protocols but still need to use all the Insteon devices I have.
Thanks in advance guys!
Wed Feb 06, 2019 9:46 am
peszko offline
Re: Replacement or upgrade from Insteon Powerlinc controller
I'm in simmilar situation. I have run insteon for a long time, but could never get it to be anywhere close to decent reliability. At this point, I have installed a z-wave interface, and am slowly moving to using that. I'm starting my changes with any sensors (starting with motion) especially ones with the I2 engine (have some all on issues with those). I'm also getting rid of all kypadlinks, as they were no end of trouble for me. Both in terms of getting the buttons properly synchronized and also not responding and/or sending corupted signals.
So at this point, I'm not buying any insteon devices at all. If anything fails or starts going squirly it gets replaced by z-wave equivalent. The only problem would be the controller as it needs to work till the last insteon device is present. And Yes, I already had to replace it several times in the life of my system. AND every time it was a royal pain. Even though indigo will re-write all the links, but... Battery devices needed to be woken up, sometimes more then once (a huge job). Many devices still had old links in their tables and needed to be factory reset. So in my case with over 130 insteon devices, this was a double royal pain.
Thu Feb 07, 2019 6:16 pm
greenhornet offline
What's a good z-wave controller that will work simultaneously with my Insteon one?
Fri Feb 08, 2019 1:25 pm
greenhornet offline
lanbrown wrote:
Any will work that is listed as compatible with Indigo. One has nothing to do with with the other controller.
Yes, I understand that. I'm asking for recommendations from people that have used z-wave.
Sun Feb 10, 2019 6:43 pm
greenhornet offline
bump - any suggestions for a z-wave controller?
Sun Feb 10, 2019 6:51 pm
peszko offline
I use the Aeon Labs Aeotec Z-Wave Z-Stick, Gen5 Z-Wave Plus - ZW090 and it works for me. I'm just starting out, so don't have that long an experience with it.
Mon Feb 11, 2019 11:12 am
The ones that we have direct experience with are the ones outlined in the Connecting Z-Wave Interfaces section of the docs. We are using or have used those ourselves so we are confident that they work well.
I think if it were me, I'd probably get the GoControl QuickStick Combo - the Z-Wave part works well (that's what I use for development and testing), and it has the extra advantage of having a Zigbee radio in it as well. While there currently isn't any direct way to use that yet, at some point we hope to have an interface or plugin that will, which would then give Indigo users direct access to Zigbee devices as well. The only downside is that it requires the 3rd party SILabs driver - but I don't think this is a big risk given that SILabs owns Z-Wave and is also a primary Zigbee chip provider.
Tue Feb 12, 2019 9:30 am
peszko offline
That's a very good idea. Now a question comes in to mind for now and for the future, how easy it is to switch a z-wave controller. Currently, I only have five z-wave devices so not a big deal, but how would I go about replacing the z-wave controller with a different one? Would I have to remove then re-add all the z-wave devices?
I'm asking this for two reasons. In this case since I'm just starting out, I think I may change my controller to the GoControll combo. The second is in the future if for some reason my controller fails, and I have over hundred devices how can I change it without removing (which might be problematic if original controller failed) and adding all of the devices to the new one?
Tue Feb 12, 2019 10:35 am
Dual offline
I am brand new to Indigo. Day 7 here. I have the Aeotec Z-Stick Gen5. All good so far. Seems like a good device. I will be looking into the Windows backup ability for sure. Except who do I know that has Windows. Hmmmm.
Wed Feb 13, 2019 8:52 am
peszko offline
I only have windows in VM, probably should work. Can you send the link to the backup utility?
Sun Feb 17, 2019 11:06 am
greenhornet offline
Jay & peszko - thanks for your help. This is exactly the info I was looking for!
Mon Feb 18, 2019 3:40 am
berkinet offline
Dual wrote:
... who do I know that has Windows. Hmmmm...
Think VirtualBox. Works well and the price is right.
Mon Feb 18, 2019 4:24 am
berkinet offline
... if it were me, I'd probably get the GoControl QuickStick Combo -...
A couple of comments...
  1. Based on a report on the OpenHAB forums moving from the Aeotec Z-Stick Gen5 or the Z-Wave.me UZB1 should be doable...
      The zwave chip is the same as a zstick, but the firmware versions are slightly different. However, they have the same libraries, as reported by Zensys Tools. The Aeon backup software can be used with it, and I have done backups and restores across the two.
  2. The price in Europe is nuts. 105€ in France and £82 in the U.K.
  3. Zigbee support would definitely be a nice to have, someday.
