Seeing an Error Not sure from where.
Posted:
Sun Dec 30, 2018 9:55 am
by Sharek326
Every few minutes I am seeing an error populate in my event log but I can't seem to narrow down what could be causing it. Any ideas where to begin to look?
Dec 30, 2018, 10:53:32 AM
Connection executeCMDOnController in Line '3767' has error='[SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:590)'
Re: Seeing an Error Not sure from where.
Posted:
Sun Dec 30, 2018 11:12 am
by matt (support)
I'm not sure where that one is coming from. I'd probably try by disabling half of your plugins for a few minutes. If the problem stops you know it is one of the "other" plugins and you can disable half of that half and keep following that search until you find it. If it isn't any of your plugins, then I'd do the same procedure but with your Schedules (disable half, etc.).
Posted:
Sun Dec 30, 2018 11:27 am
by Sharek326
Thanks Matt that is what I have been doing I shut them all down and one by one I am turning them back on so far haven't isolated it yet. I'll let you know what I find out.
Posted:
Sun Dec 30, 2018 7:30 pm
by kw123
This is from unifi
In config: Switch from request to curl. Request does not work properly w ssl in older OS X
