Indigo can't communicate with USB Insteon 2413U
Sat Dec 15, 2018 6:26 pm
dlleon offline
I keep getting interface errors with the USB 2413U modem. I haven't changed much. I've tried power cycling, different cables, and moving Indigo to another computer. No dice.
Any ideas?
Here's the log:
onnected to PowerLinc 2413U interface on port usbserial-AL02YCV8
PowerLinc address 48.F0.E0, firmware version 9.14
PowerLinc Unexpected command 02 73 (flushing)
Error resending previous command (failure response)
Error unknown command bytes received BD 00 (ignoring)
Error resending previous command (busy or unexpected command)
Error unknown command bytes received FF 40 (ignoring)
Error unknown command bytes received F5 04 (ignoring)
Interface Failure failed to establish connection with serial interface PowerLinc 2413U on port usbserial-AL02YCV8
Trigger Error
Trigger Interface error
Error unable to execute action -- device plugin Messages not enabled
Error email reply to address not specified: see Email tab in the Preferences Dialog
Action Collection interface error
Sat Dec 15, 2018 8:04 pm
Re: Indigo can't communicate with USB Insteon 2413U
Are you sure you have the right serial port selected?
Sat Dec 15, 2018 9:52 pm
dlleon offline
The only serial port available is usbserial-AL92YCV8.
Sun Dec 16, 2018 9:47 am
Are you running macOS High Sierra or Mojave? If so, you may be running into this Apple bug.
Mon Dec 17, 2018 8:23 pm
dlleon offline
I think that's it. the problem is the server is headless, no keyboard, and lives in a closet. I use Remote Desktop to access it. Is there a script or something I can run to do the fix?
Tue Dec 18, 2018 10:42 am
Unfortunately, no. Part of the problem is Apple's SIP, which keeps you from doing some of the necessary bits unless you reboot into recovery mode. So a script wouldn't work.
Note: you can install the FTDI driver and see if that fixes the problem. The only issue if that's all you do is that you'll have to unplug/replug the PowerLinc whenever you reboot the Mac (because of the second bug which keeps the right driver from loading at boot time).
Wed Dec 19, 2018 9:50 pm
dlleon offline
interestingly enough, the problem also occurs on a El Capitan laptop.
Thu Dec 20, 2018 10:29 am
So, that means that it's not the driver bug issue at all. That particular failure scenario can also happen in some other scenarios: 1) when some other misbehaving USB device is plugged in (just unplug all other USB devices to see if that helps) 2) the PowerLinc is failing, and 3) when there is a lot of signal noise and the PowerLinc gets confused.
The latter is the most likely so you'll want to work through the signal troubleshooting page to see if you can get to the bottom of it. First try running a long outdoor extension cord from your PowerLinc to an outlet in another room. If you stop seeing the issue then it's likely that the circuit the PowerLinc is plugged into has some significant noise.
