lanbrown wrote:The major issue with Sierra and below is that as TLS 1.0 is turned off on various sites, then plugins will stop working. A good example is the Ecobee plugin; it requires TLS 1.2 and as such, needs High Sierra or later. If you're doing a fresh install, it might make sense to try High Sierra or Mojave. If you run into issues you cannot solve, then you can always go back to the original plan. It doesn't take that long to install High Sierra or later, install Indigo, copy everything back, activate Indigo and start seeing if you are going to have issues.
Silly me, I expected this to be a simple HD swap and be back in business.
I thought that the Indigo recommendation was to not go newer than Sierra unless you want to deal with possible issues that even the 'hacks' won't guarantee they work or reoccur.
What the heck is TLS and how does it factor into the OS decision? So if I stay on Sierra, future plug-ins or devices that I add might not work? I don't believe I have ever heard this mentioned in this forum.
My 2012 Mac Mini has one job, to run Indigo 24/7 reliably without having to patch, fix, troubleshoot problems. It also has to run iTunes and Home Sharing.
I feel like I've taken a step backward in replacing my HD, as I now have no clue what OS I should be on, or the pro's/con's of that decision.
HELP, my hard drive is dying.
