Plugin errors due to new Indigo 7.2 directory
Mon Oct 01, 2018 1:16 pm
DVDDave offline
Jay or Matt,
The 7.2 installer created a new Indigo 7.2 directory in Application Support. This generally worked but has created problems with certain plugins as well as some AppleScript code I have that refers to the Indigo 7 directory.
The EventLog and FindMyDevices plugins both refer to Indigo 7 in their python code and changing it to 7.2 worked.
The Nest Home plugin python code makes a call to myIndigoVersion and is apparently receiving 7 instead of 7.2 as the server version. Changing this to a constant "7.2" fixed it.
I don't know if changing the directory name to Indigo 7 would have worked but I suspect it would have created even more problems.
Was the installer intended to create Indigo 7.2 or was this a glitch in my upgrade process?
--Dave
Mon Oct 01, 2018 2:02 pm
Re: Plugin errors due to new Indigo 7.2 directory
This is an intentional change which makes switching between versions better/more reliable. We beta tested with all of our 3rd party developers and we let them know this change was coming to allow them time to release updates to their plugins. There is a call that Python scripts and plugins can use to get the install directory (indigo.server.getInstallFolderPath()) which should be used to get the install folder directory. Using this avoids any issues.
Trying to rename the 7.2 directory to 7 would have failed and shouldn't be tried.
In terms of your AppleScripts, you'll need to rewrite them anyway given that AppleScript will be deprecated in an upcoming release. We have a forum dedicated to helping users convert their AppleScripts so I highly recommend that you use that to get started.
Mon Oct 01, 2018 2:18 pm
DVDDave offline
Thanks as always, Jay. My workarounds should be ok until the plugins are updated.
—Dave
Mon Oct 01, 2018 2:30 pm
DVDDave offline
lanbrown wrote:
The Nest plugin and all of the plugins that I have worked after the 7.2 upgrade. without any modifications.
Weird I thought I was up to date but I’ll check. Doesn’t seem like findmydevices or eventlog could work and the version call in Nest is returning 7 not 7.2.
Mon Oct 01, 2018 5:34 pm
DVDDave offline
Maybe my errors are because I'm using it with a Nest Protect. Even with the latest version, I get constant errors of the sort:
  File "plugin.py", line 1886, in runConcurrentThread
IOError: (2, 'No such file or directory', u'/Library/Application Support/Perceptive Automation/Indigo 7/Logs/NESTHome1Errors.log')
   NEST Home Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   NEST Home Error                 Error in plugin execution runConcurrentThread:
Until I change the plugin.py like this:
#myIndigoVersion = indigo.server.version[0]
myIndigoVersion = "7.2"
No big deal though. I'll also post this in the Nest Home forum.
--Dave
Mon Oct 01, 2018 8:02 pm
I've published a new version of that plugin which should be compatible with 7.2 (and beyond).
Mon Oct 01, 2018 8:05 pm
DVDDave offline
Thanks! again :)
Wed Oct 03, 2018 2:35 am
McJohn offline
Thanks for all the nice and great work Matt and Jay.
Question about the 7.2 Installer and the new 7.2 directory.
We saw that all the extra (custom made) control page images from the old 7 directory were nice copied to the new 7.2 directory, perfect.
But why are the external AppleScripts not copied to the new directory?
We know that the internal Indigo AppleScripts are soon E.O.L. but this has nothing to do with the Scripts to command other programs.
Now we have to move all the AppleScripts manually and choose the right path again for every Trigger or Schedule.
(or work with 2 different Indigo directories and that's confusing)
Kind regards,
John
Wed Oct 03, 2018 8:48 am
Yeah, we made the installer smarter about migrating over the custom images and Web server plugins. Unfortunately the scripts are more complicated because they require a database change so that all the internal references point to the new location and the installer isn't that smart.
I'd recommend moving the scripts all up and over to the root perceptive automation folder, so create a folder "Scripts" like:
/Library/Application Support/Perceptive Automation/Scripts
Then they won't be in the wrong/old directory when Indigo 7.3+ is released.
Wed Oct 03, 2018 9:03 am
McJohn offline
Thanks for the explanation and the nice tip for all the future upgrades!
(Never change the name Perceptive Automation for the next 50 years please :wink: )
Thu Oct 04, 2018 1:31 am
McJohn offline
Matt; Indigo 7.2 automatically opens always the "choose file" window in the Indigo 7.2 Script directory.
Even when the Scripts were saved earlier elsewhere.
So, when the new location is chosen into the root "perceptive automation" folder for an Action, the next time (for an edit or so) the window opens again in the Indigo 7.2 directory.
Thu Oct 04, 2018 8:31 am
Yep. We've had to tweak several thing regarding where the file dialogs open unfortunately due to OS bugs (like always wanting to open to the Documents folder). We'll look to see if we can improve this behavior in future releases.
