Moving DB file to new folder
Posted: Fri Aug 17, 2018 8:16 am
For some reason a long time ago I created my database file under ~/Documents.
I'd like it to now live under /Library/Application SupportPerceptive Automation/Indigo 7/Databases so the backup utility captures the database along with my plugins and all my other settings for backup purposes.
So I stopped Indigo, made a copy of my DB file for safe keeping, and moved it to that folder. Started Indigo. Opened that file and things worked. But on reboot I got an error:
So I'm now back the way I started (with the file in ~/Documents) after fixing an error with fingscan and my Mac password (error did not happen before).
How can I move this file to that folder? Is it a file permissions issue or something else?
If I select "existing" and open the file in the /Library... folder it works fine until the next time Indigo is stopped/started.Indigo could not find your database file or the file has become corrupt. You can either create a new database file or select an existing database file.
