2018-07-24 17:35:24.861 Z-Wave received "2. OG Temperatur" sensor update to 28.2 °C
2018-07-24 17:41:28.242 Z-Wave received "Helligkeit Küche" sensor update to 10 lux
2018-07-24 17:43:12.777 Z-Wave received "Helligkeit 1.OG" sensor update to 5 lux
2018-07-24 17:43:12.950 Z-Wave received "1. OG Temperatur" sensor update to 26.4 °C
2018-07-24 17:43:15.226 Z-Wave received "Helligkeit 2.OG" sensor update to 0 lux
2018-07-24 17:45:03.570 Z-Wave received "Sirene Temperature" sensor update to 49.6 °C
2018-07-24 17:45:18.498 Z-Wave received "Fenster W. re. Temperature" sensor update to 29.81 °C
2018-07-24 17:45:24.040 Z-Wave received "2. OG Temperatur" sensor update to 28.2 °C
2018-07-24 17:45:24.454 WebServer Indigo Touch client connected from 192.168.1.84
2018-07-24 17:46:17.542 EPS - Control Page Keypad Error Incorrect code of 9969 entered on Keypad, attempt 1
2018-07-24 17:46:17.553 Action Group Sound ComputerInputFailed
2018-07-24 17:46:21.535 EPS - Control Page Keypad Error Incorrect code of 9969 entered on Keypad, attempt 2
2018-07-24 17:46:21.551 Action Group Sound ComputerInputFailed
2018-07-24 17:48:14.470 Schedule SireneCheck
2018-07-24 17:48:16.610 EPS - Control Page Keypad Error Incorrect code of 9969 entered on Keypad, attempt 1
2018-07-24 17:48:16.623 Action Group Sound ComputerInputFailed
2018-07-24 17:48:31.064 Z-Wave Error send setRelayValue failed after 9 attempts
2018-07-24 17:48:31.065 Z-Wave Error restarting serial connection in 5.0 seconds
2018-07-24 17:48:34.469 Interface Failure lost connection with interface
2018-07-24 17:49:22.140 Z-Wave Error send getVersion failed after 9 attempts
2018-07-24 17:49:22.142 Z-Wave Error restarting serial connection in 5.0 seconds
2018-07-24 17:49:25.466 Interface Failure lost connection with interface
2018-07-24 17:50:13.208 Z-Wave Error send getVersion failed after 9 attempts
2018-07-24 17:50:13.210 Z-Wave Error restarting serial connection in 5.0 seconds
2018-07-24 17:50:16.463 Interface Failure lost connection with interface
2018-07-24 17:51:04.273 Z-Wave Error send getVersion failed after 9 attempts
2018-07-24 17:51:04.274 Z-Wave Error restarting serial connection in 5.0 seconds
2018-07-24 17:51:07.458 Interface Failure lost connection with interface
2018-07-24 17:51:55.332 Z-Wave Error send getVersion failed after 9 attempts
2018-07-24 17:51:55.333 Z-Wave Error restarting serial connection in 5.0 seconds
2018-07-24 17:51:58.458 Interface Failure lost connection with interface
2018-07-24 17:52:25.691 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1d1341 (firmware 1.00)
2018-07-24 17:52:25.858 Z-Wave found module included in controller with no matching device (missing or disabled): 009 - Dimmable Power Switch
2018-07-24 17:52:25.864 Z-Wave Error module 010 included in controller no longer matches device "Deckenlampe" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 1))
2018-07-24 17:52:25.878 Z-Wave Error module 012 included in controller no longer matches device "Arbeitsplatte" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:25.908 Z-Wave Error module 039 included in controller no longer matches device "Rolladen Dach rechts" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 3))
2018-07-24 17:52:25.920 Z-Wave found module included in controller with no matching device (missing or disabled): 048 - Relay Power Switch
2018-07-24 17:52:25.932 Z-Wave Error module 054 included in controller no longer matches device "Stehlampe Schlafzimmer" type (controller module type: zwCustomType/zwCustomType (1, 1, 1), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:25.948 Z-Wave Error module 056 included in controller no longer matches device "056 - Relay Switch" type (controller module type: zwRelayType/zwRelayType (4, 17, 3), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:26.011 Z-Wave Error module 070 included in controller no longer matches device "Terrassentür" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.035 Z-Wave found module included in controller with no matching device (missing or disabled): 073 - Relay Power Switch
2018-07-24 17:52:26.042 Z-Wave Error module 074 included in controller no longer matches device "Ventilator" type (controller module type: zwRelayType/zwRelayType (4, 32, 1), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:26.062 Z-Wave Error module 076 included in controller no longer matches device "Tischlampe" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:26.077 Z-Wave Error module 077 included in controller no longer matches device "Küchenfenster" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.109 Z-Wave Error module 079 included in controller no longer matches device "Bewegungsmelder Küche" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.140 Z-Wave Error module 080 included in controller no longer matches device "Boxenlampen" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwRelayType (4, 16, 0))
2018-07-24 17:52:26.156 Z-Wave Error module 082 included in controller no longer matches device "Dachfenster links" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.188 Z-Wave Error module 084 included in controller no longer matches device "Bewegungsmelder 2. OG" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 0), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.216 Z-Wave found module included in controller with no matching device (missing or disabled): 085 - Binary Sensor (routing)
2018-07-24 17:52:26.223 Z-Wave Error module 086 included in controller no longer matches device "Deckenlampe Dimmer" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwDimmerType (4, 17, 1))
2018-07-24 17:52:26.256 Z-Wave Error module 097 included in controller no longer matches device "Schreibtischlampe" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 0))
2018-07-24 17:52:26.289 Z-Wave Error module 102 included in controller no longer matches device "Fenster Ruth " type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 0), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.313 Z-Wave Error module 103 included in controller no longer matches device "Wassersensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwOnOffSensorType (4, 161, 2))
2018-07-24 17:52:26.352 Z-Wave Error module 107 included in controller no longer matches device "107 - Relay Power Switch" type (controller module type: zwCustomType/zwCustomType (4, 161, 2), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:26.362 Z-Wave found module included in controller with no matching device (missing or disabled): 108 - Binary Sensor (routing)
2018-07-24 17:52:26.367 Z-Wave Error module 113 included in controller no longer matches device "Weihnachtsbaum alt" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:26.391 Z-Wave Error module 122 included in controller no longer matches device "Arbeitsplatte links" type (controller module type: zwRelayType/zwRelayType (1, 1, 1), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:26.412 Z-Wave Error module 124 included in controller no longer matches device "Sirene" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwRelayType (4, 16, 5))
2018-07-24 17:52:26.435 Z-Wave Error module 127 included in controller no longer matches device "Keyfob (FGKF601)" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
2018-07-24 17:52:26.450 Z-Wave Error module 130 included in controller no longer matches device "Bewegungsmelder Gästeklo" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.475 Z-Wave Error module 131 included in controller no longer matches device "Außenlampe Eingang" type (controller module type: zwRelayType/zwRelayType (4, 16, 5), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:26.491 Z-Wave found module included in controller with no matching device (missing or disabled): 132 - Siren
2018-07-24 17:52:26.497 Z-Wave Error module 133 included in controller no longer matches device "133 - Wall Plug Relay (FGWP102)" type (controller module type: zwCustomType/zwCustomType (4, 24, 1), indigo device type: zwRelayType (4, 16, 1))
2018-07-24 17:52:26.509 Z-Wave found module included in controller with no matching device (missing or disabled): 134 - Binary Sensor (routing)
2018-07-24 17:52:26.515 Z-Wave Error module 135 included in controller no longer matches device "Eingangstür" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.544 Z-Wave Error module 137 included in controller no longer matches device "Fenstersensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 32, 1))
2018-07-24 17:52:26.568 Z-Wave Error to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
2018-07-24 17:52:26.588 Z-Wave Error could not find module/node for action
2018-07-24 17:53:12.417 Z-Wave received "Helligkeit 1.OG" sensor update to 5 lux
2018-07-24 17:53:12.588 Z-Wave received "1. OG Temperatur" sensor update to 26.4 °C
2018-07-24 17:53:45.002 Z-Wave received "104 - Fenster Studio" status update battery level 100%
2018-07-24 17:54:11.515 Z-Wave received "101 - Fenster W. li." status update battery level 83%
2018-07-24 17:55:33.801 Z-Wave received "094 - Dachfenster rechts" status update battery level 60%
2018-07-24 17:58:29.075 Z-Wave received "099 - Kellerfenster Süd" status update battery level 98%
2018-07-24 18:00:00.434 Schedule Sonnenschutz aus
24.07.2018 21:37:23
Starting Indigo Server version 7.1.1 (Mac OS X 10.9.5)
Loading attachments
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7/Databases/Hutzelhaus.indiDb"
Loading plugin "Action Collection 2.0.4"
Starting plugin "Action Collection 2.0.4" (pid 41835)
Loading interface "Z-Wave 2.0.111"
Starting interface "Z-Wave 2.0.111" (pid 41836)
Loading plugin "Adapters 1.0.0"
Starting plugin "Adapters 1.0.0" (pid 41837)
Loading plugin "Airfoil Pro 1.0.9"
Starting plugin "Airfoil Pro 1.0.9" (pid 41838)
Loading plugin "Beacon 1.5.3"
Starting plugin "Beacon 1.5.3" (pid 41839)
Loading plugin "EPS - Control Page Keypad 1.2.1"
Starting plugin "EPS - Control Page Keypad 1.2.1" (pid 41840)
Loading plugin "GhostXML 0.4.09"
Starting plugin "GhostXML 0.4.09" (pid 41841)
Loading plugin "Growl 2.0.2"
Starting plugin "Growl 2.0.2" (pid 41842)
Loading plugin "Harmony Hub 7.2.3"
Starting plugin "Harmony Hub 7.2.3" (pid 41843)
Loading plugin "Hue Lights 1.6.11"
Starting plugin "Hue Lights 1.6.11" (pid 41844)
Loading plugin "INDIGOplotD 3.6.18"
Starting plugin "INDIGOplotD 3.6.18" (pid 41845)
Loading plugin "Notification plugin 0.8.2"
Starting plugin "Notification plugin 0.8.2" (pid 41846)
Loading plugin "Prowl 1.1.2"
Starting plugin "Prowl 1.1.2" (pid 41847)
Loading plugin "SQL Logger 2.0.7"
Starting plugin "SQL Logger 2.0.7" (pid 41848)
Loading plugin "Timers and Pesters 2.0.2"
Starting plugin "Timers and Pesters 2.0.2" (pid 41849)
Loading interface "Virtual Devices 2.0.4"
Starting interface "Virtual Devices 2.0.4" (pid 41850)
Loading plugin "Watchdog 1.6.5"
Starting plugin "Watchdog 1.6.5" (pid 41851)
Loading plugin "ZEAL 0.3.7"
Starting plugin "ZEAL 0.3.7" (pid 41852)
Found disabled interface "INSTEON Commands 2.0.10"
Found disabled plugin "Airfoil 1.1.14"
Found disabled plugin "DIRECTV DVR Control 1.1.1"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "EPS - Device Extensions 1.53"
Found disabled plugin "EPS - Homebridge Buddy 1.0.1"
Found disabled plugin "EPS - Super Conditions 0.5"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "NOAA Weather 2.0.1"
Found disabled plugin "Z-Wave Node Matrix 0.3.01"
Found disabled plugin "On-Screen Keyboard 1.0.0"
Found disabled plugin "Smartphone Radar 1.1.3"
Found disabled plugin "Vera Bridge 1.0.10"
Found disabled plugin "WeatherSnoop 2.1.3"
Found disabled plugin "Yamaha RX Receiver 1.0.0"
Found disabled plugin "Z-Wave Lock Manager 1.0.46"
Bonjour registered "Indigo - Hutzelhaus"
Indigo Cocoa client connected
Started plugin "Growl 2.0.2"
Started plugin "Action Collection 2.0.4"
Started plugin "Beacon 1.5.3"
Beacon Listening on TCP port 6192
GhostXML
Started plugin "Prowl 1.1.2"
Started plugin "Adapters 1.0.0"
GhostXML ================================================ Initializing New Plugin Session =================================================
GhostXML Plugin name: GhostXML
GhostXML Plugin version: 0.4.09
GhostXML Plugin ID: com.fogbert.indigoplugin.GhostXML
GhostXML Indigo version: 7.1.1
GhostXML Python version: 2.7.5 (default, Mar 9 2014, 22:15:05) [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
GhostXML ==================================================================================================================================
Started plugin "SQL Logger 2.0.7"
SQL Logger connected to /Library/Application Support/Perceptive Automation/Indigo 7/Logs/indigo_history.sqlite
SQL Logger updating all device tables
Started plugin "Notification plugin 0.8.2"
Started plugin "Harmony Hub 7.2.3"
Harmony Hub Starting Harmony Hub
ZEAL Setting log level to INFO
Started plugin "Timers and Pesters 2.0.2"
Started plugin "EPS - Control Page Keypad 1.2.1"
Started plugin "Watchdog 1.6.5"
Watchdog Starting Watchdog plugin
Watchdog Daylight Saving Time is active
Watchdog Watchdog failure messages will be sent using Prowl
Watchdog Watchdog failure messages will be emailed to info@wilhelmspeck.de
Watchdog Daily reminder messages will be sent at 0800
Watchdog Plugin will check for new versions every 1 day(s)
Started plugin "GhostXML 0.4.09"
Started interface "Virtual Devices 2.0.4"
Started plugin "Airfoil Pro 1.0.9"
Watchdog Starting Watchdog monitoring thread
Started plugin "INDIGOplotD 3.6.18"
INDIGOplotD initializing ... 3-6-18
INDIGOplotD indigo version found: 7
INDIGOplotD checking py-restore files
INDIGOplotD clearing plot flags
Adapters Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 130, in deviceUpdated
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/sensor_adapter.py", line 37, in go
KeyError: key outside_value not found in dict
Started interface "Z-Wave 2.0.111"
Started plugin "Hue Lights 1.6.11"
Hue Lights Loaded 2 lights.
Hue Lights Loaded 1 group.
Hue Lights Loaded 3 scenes.
Hue Lights Loaded 1 sensor.
ZEAL Finished mapping 48 z-wave nodes to indigo devices.
Started plugin "ZEAL 0.3.7"
Z-Wave found module included in controller with no matching device (missing or disabled): 009 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 010 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 012 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 039 - Multiposition Motor Control
Z-Wave found module included in controller with no matching device (missing or disabled): 048 - Portable Remote Controller
Z-Wave found module included in controller with no matching device (missing or disabled): 054 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 056 - Relay Power Switch
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Z-Wave found module included in controller with no matching device (missing or disabled): 070 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 073 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 074 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 076 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 077 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 079 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 080 - Relay Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 082 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 084 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 086 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 097 - Relay Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 102 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 103 - Alarm Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 107 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 108 - Portable Remote Controller
Z-Wave found module included in controller with no matching device (missing or disabled): 113 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 124 - Siren
Z-Wave found module included in controller with no matching device (missing or disabled): 127 - Basic Wall Controller
Z-Wave found module included in controller with no matching device (missing or disabled): 130 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 131 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 133 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 135 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 137 - Binary Sensor (routing)
INDIGOplotD ..../data/consumedDuringPeriod empty, resetting consumption data to 0
INDIGOplotD read file /Users/wilhelm/Documents/INDIGOplotD/data/minute.dat lines: 2304 ok
INDIGOplotD read file /Users/wilhelm/Documents/INDIGOplotD/data/hour.dat lines: 912 ok
INDIGOplotD read file /Users/wilhelm/Documents/INDIGOplotD/data/day.dat lines: 390 ok
INDIGOplotD command: reLoad data from SQL for last 2 days started
INDIGOplotD wait 40 secs for SQL logger to finish start up -- before retrieving SQL data
24.07.2018 21:37:31
Trigger InitVariables
Trigger wx010-1 on
Trigger wx030-3 standby
Trigger wx030-4 standby
Trigger RX-A2050 on
Trigger wx010-2 standby
Trigger wx030-1 standby
Z-Wave received "Bewegungsmelder 1.OG" status update is on
Z-Wave received "Treppenhaus OG" status update is on (from associate)
24.07.2018 21:38:09
INDIGOplotD sql commands launched 2018-07-24 21:38:09.167391 waiting for SQL tasks to end to read data into INDIGOplotD pid=41921
INDIGOplotD Reading SQL files,filtering,convting Time Stamp Device----- State name------------------------------- records read/imported/ LastID/ F size--Reject: ValueRng/ Number/ TimeStp/ 2Days/ col#
INDIGOplotD Converted 0:00:00.214534 070 - Terrassentür Temperatur -sensorValue-average 18796/ 6635/ 19988/ 494672--rejects: 0/ 0/ 0/ 12161/ 1
INDIGOplotD Converted 0:00:00.324034 073 - Klo - Temperatur-sensorValue-average 9905/ 3252/ 10530/ 255599--rejects: 0/ 0/ 0/ 6653/ 2
INDIGOplotD Converted 0:00:00.402207 077 - Küchenfenster Temperatur-sensorValue-average 4779/ 1734/ 5139/ 122558--rejects: 0/ 0/ 0/ 3045/ 3
INDIGOplotD Converted 0:00:00.698437 082 - Dachfenster links Temperatur-sensorValue-average 25595/ 9393/ 27408/ 677340--rejects: 0/ 0/ 0/ 16202/ 4
INDIGOplotD Converted 0:00:00.738095 079 - Temperatur-sensorValue-average 1754/ 604/ 1871/ 42799--rejects: 0/ 0/ 0/ 1150/ 5
INDIGOplotD Converted 0:00:00.763975 066 - Temperature-sensorValue-average 336/ 148/ 339/ 8259--rejects: 0/ 0/ 0/ 188/ 6
INDIGOplotD SQL import 2018-07-24 21:38:12.975724 ... finished, total number of records imported: 21766
INDIGOplotD initializing ...2
INDIGOplotD initialized
Z-Wave received "Dachfenster rechts Temperatur" sensor update to 30.81 °C
24.07.2018 21:39:32
Z-Wave received "Bewegungsmelder 1.OG" status update is off
Z-Wave received "Treppenhaus OG" status update is off (from associate)
24.07.2018 21:39:56
SQL Logger updating all variable tables
SQL Logger update complete
24.07.2018 21:41:15
Z-Wave received "Helligkeit Küche" sensor update to 0 lux
24.07.2018 21:41:39
Z-Wave received "Fenster W. li. Temperatur" sensor update to 26.93 °C
Umtauscher wrote:I am sorry, I am using this system for nearly 4 years now. Without any problems on the zwave side at all.
And after updating to 7.1.1 it fails twice in one week? I don#t think this is conincidence.
FlyingDiver wrote:Umtauscher wrote:D owngrade to 7.1.0 for a while and see if the problem comes up again.
Umtauscher wrote:What is interresting is that Indigo disables all the devices and when I restart the server, they still are listed as non functional. After I enable them by hand and do a restart, all errors are gone.
This at least seems odd to me, because I didn't resync them and they all work again right away.
Umtauscher wrote:Anyways, could you please tell me what is the fatest way to reactivate my older Indigo installation?
Any low power radio devices operating in the range 862 MHz to 870 MHz are most likely to be affected by interference from the portable devices using the 800 MHz LTE system since they will be transmitting in the upper part of the 790 MHz to 862 MHz band, i.e. the part of the band which is closest to the frequencies used by Low Power Radio Devices.
