Moved to New MAc Plugin not show/started
Fri May 04, 2018 7:40 am
qcvictor offline
Hi Guys
Just move to my new mac server, follow this post here http://forums.indigodomo.com/viewtopic.php?f=75&t=14966 and wiki everything goes smooth except all plugins are not show /enabled after the switch....
One thing for example has been odd, my database on previous mac was in my documents... put in the database folder on the newer mac.
Fri May 04, 2018 9:21 am
Re: Moved to New MAc Plugin not show/started
Did you rerun the Indigo Installer after moving everything over? That will correct permission issues which may be causing the issue with the plugins.
Moving your DB to a new location is ok, but you may need to explicitly open it (File->Select Database...)
Fri May 04, 2018 9:33 am
qcvictor offline
I moved the backup folder, start indigo installation and select the database!
At this point what is the best way to achieve this migration?
Fri May 04, 2018 1:17 pm
Do the missing plugins show up in either of these folders?
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins (Disabled)/
Fri May 04, 2018 1:23 pm
qcvictor offline
yes all required are located
Fri May 04, 2018 1:32 pm
But they aren't showing up in the Plugins menu?
Fri May 04, 2018 1:43 pm
qcvictor offline
nope in the menu excepted base plugin even after reload plugin nothing, mail setting are gone !
Fri May 04, 2018 2:14 pm
Are you sure that you're connecting to the correct Indigo Server (the local one vs a remote one)? If the plugins exist in those directories and the permissions are correct, they should be showing up in the Plugins menu.
Fri May 04, 2018 2:34 pm
qcvictor offline
Where are stored mail setting ?
Fri May 04, 2018 3:52 pm
If you are using Indigo's built-in email scanning and sending, then those are stored in here:
/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Indigo Server Prefs.indiPref
along with all of Indigo's preferences.
Sat May 05, 2018 1:02 am
Have you restarted Indigo Server after moving the plugins?
If you moved them after you started Indigo, they won’t show.
Users browsing this forum: No registered users and 21 guests
