Custom Images not showing up
Fri Feb 07, 2020 12:53 pm
Re: Custom Images not showing up
Can you take a screen capture of the images variable popup in the control page editor for me?
Fri Feb 07, 2020 2:41 pm
mgolden50 offline
Here's the shot attached
Screenshot 2020-02-07 at 1.39.22 PM.png (38.72 KiB) Viewed 987 times
Fri Feb 07, 2020 2:46 pm
That shows the image in the popup menu though: Thermostat Heat Status 2x
mgolden50 wrote:
... I can't get my new added images in the variables directory in the variable pop down list.
What specifically is not working?
Fri Feb 07, 2020 3:04 pm
mgolden50 offline
The new .png images I add to the directory in the file path provided don't show up in the Control Page Variables pop up list
Fri Feb 07, 2020 3:20 pm
But your above screenshot does show it is added. Note Indigo doesn't add every image, just the base image. So the +true variant won't show in the popup but it will be selected based on the variable value (when viewed from a Web browser or Indigo Touch, but not from within the Control Page editor itself).
Fri Feb 07, 2020 4:03 pm
mgolden50 offline
Thanis Matt,
I finally have it working again.
I was expecting all of my png files to show up in the pop up.
And even when I got the base image to show up in the CP edit image I also expected the "true" image to show up in the edit page when the variable became true.
It's all pretty confusing as to what works when and where.
Thanks for the guidance.
Mike
