How to determine plugin Python 2 dependencies
Thu Jul 13, 2023 2:05 pm
Re: How to determine plugin Python 2 dependencies
It was the first plugin that supported Shelly.
When the other plugin appeared I renamed it as Shelly direkt to indicate that is does not go through middle ware
Thu Jul 13, 2023 2:21 pm
But the plugin store has the old name? No "direct"?
Thu Jul 13, 2023 2:22 pm
I just renamed the plugin
Thu Jul 13, 2023 3:48 pm
DVDDave offline
Version 7.20.55 works now and shows the green dot. For some reason the plugin management list didn't indicate there was an update. Thanks!
--Dave
Thu Jul 13, 2023 4:23 pm
DVDDave offline
autolog wrote:
The nanoleaf plugin has already been converted to Python 3 and is available as a pre-release on Github: Convert to Python 3 for Indigo 2022.1+
Thanks, but I tried the pre-release version but it won't start up. Gives an error in the log: Error in plugin execution InitializeMain
Went back to released version and it works again.
--Dave
Fri Jul 14, 2023 3:04 am
Hi Dave,
Did you report that in the Nanoleaf sub-forum ?
I had a look but couldn't see a report of the error, but I could have missed it?
Could you try the Python 3 version again and post the contents of the the Indigo Event Log when it fails, so that I can try to resolve it for you. :)
Fri Jul 14, 2023 8:33 am
DVDDave offline
autolog wrote:
Hi Dave,
I didn't post it there since there's been no mention of this new pre-release version and I didn't want to confuse people. Of course, this thread is confusing as well and I'll move further discussion soon to the relevant threads now that the initial discussion of Python 2 incompatibilities has run its course.
Here is the Event Log from when I upgraded the version. It includes an expansion of the initialization error which I didn't notice before. Hope it helps. BTW, I would rather not try again unless it's necessary since it took many tries to get the plugin to recognize my device again. Thanks!
2023-07-13 14:32:45.607   Application   Stopping plugin Nanoleaf (pid 880)
2023-07-13 14:32:45.716   Nanoleaf   Autolog 'Nanoleaf V1 Controller' Plugin shutdown requested
2023-07-13 14:32:45.846   Nanoleaf   Stopping 'Nanoleaf'
2023-07-13 14:32:45.853   Nanoleaf   Autolog 'Nanoleaf V1 Controller' Plugin shutdown complete
2023-07-13 14:32:46.838   Application   Stopped plugin Nanoleaf
2023-07-13 14:32:46.838   Application   Upgrading plugin Nanoleaf to newer version 2022.0.2 (previous version moved to trash)
2023-07-13 14:32:47.287   Application   Loading plugin "Nanoleaf 2022.0.2" using API v3.0
2023-07-13 14:32:47.292   Application   Starting plugin "Nanoleaf 2022.0.2" (pid 74355)
2023-07-13 14:32:47.486   Nanoleaf Error   Error in plugin execution InitializeMain:
  File "plugin.py", line 20, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/nanoleafapi/nanoleaf.py", line 12, in <module>
type: No module named 'sseclient'
2023-07-13 14:32:47.486   Application   Stopping plugin "Nanoleaf 2022.0.2" (pid 74355)
2023-07-13 14:32:48.436   Application   Stopped plugin "Nanoleaf 2022.0.2"
Tue Aug 08, 2023 1:29 pm
DVDDave offline
This version of the plugin now works after I ran the command
pip3 install sseclient
