Geofence error message
Sun Oct 03, 2021 11:13 am
aemerick offline
When the box "enabled" is checked and the check mark icon at the top of the screen is Checked a box appears and states "an error was encountered while enabling the geofence". Apologies for not posting this initially.
Wed Oct 06, 2021 9:28 pm
RogueProeliator offline
Re: Geofence error message
Apologies for the delayed response, been away a bit... so I wasn't clear in the other thread -- when you go to create a Geofence, is the Latitude & Longitude filled in correctly by default? And is accurate as per the other screenshot you posted?
Thu Oct 07, 2021 7:45 pm
aemerick offline
Yes. That is correct. Took down ss.
Tue Oct 12, 2021 11:44 pm
Let's check the permissions -- Android likes to fool with permissions with every single OS release...
Go to Settings -> Apps
Find Domotics Pad and bring up the details
Select Permissions
Assuming "Location" is listed under Allowed, click it
Is it set for "Allow all the time"?
Note the above is for Samsung devices, but most versions of Android follow a very similar path to get there.
Wed Nov 17, 2021 11:49 am
aemerick offline
When geofence is enabled at the location it executes. It fails to execute upon engress or egress using 500 meters as the radius. I will try again tonite. Have checked settings in android to allow always. Any help or suggestions greatly appreciated.
