Error every 5 minutes
Mon Jan 23, 2017 8:00 pm
srkinard offline
Hey Adam...got home and noticed that every 5 minutes my Indigo mini fans are screaming, so I powered on the monitor and see the following error:
   WebServer                       internal server error "http://192.168.20.4:8176/AndroidClientHelper/updateAndroidDeviceStates" from 192.168.20.117
   WebServer
Request Headers:
  AUTHORIZATION: Digest username="indigo", realm="Indigo Control Server", nonce="60f1872904c555b8c6fbadfe5c5cab9c", uri="/AndroidClientHelper/updateAndroidDeviceStates?pairingId=UX0hqVrKWpcvXV2UpMme&deviceModel=GT-P5110&batteryStatus=NotCharging&batteryLevel=91&longitude=-97.7842484&latitude=30.1534839&locationFixTime=1%2F23%2F17%207%3A40%20PM", response="bc060b7a293265a3c3fab151ce9fbfcc", qop=auth, nc=00000001, cnonce="ab92141b61321731", algorithm=MD5
  HOST: 192.168.20.4:8176
  USER-AGENT: okhttp/3.4.2
  CONNECTION: Keep-Alive
  Remote-Addr: 192.168.20.117
  ACCEPT-ENCODING: gzip
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/_cprequest.py", line 609, in respond
    cherrypy.response.body = self.handler()
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/_cpdispatch.py", line 25, in __call__
    return self.callable(*self.args, **self.kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/plugins/AndroidClientHelper/reqhandler.py", line 254, in updateAndroidDeviceStates
    conn.connect()
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 832, in connect
    self.timeout, self.source_address)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/socket.py", line 575, in create_connection
    raise err
error: [Errno 61] Connection refused
I just updated to the 2.0.0 version a day or so ago...should I downgrade back to 1.3.0?
Not sure what I can do to help out if it's a bug.
Indigo 7.0.2 on macOS Sierra 10.12.2
Ross
Mon Jan 23, 2017 9:35 pm
RogueProeliator offline
Re: Error every 5 minutes
That error is from the Indigo Web Server plugin saying that it cannot talk to the Domotics Pad Indigo Plugin. Have you tried restarting the plugin? You might turn on debug for the plugin, then restart and see if there are any clues/errors that indicate why it wasn't listening.
Adam
Tue Jan 24, 2017 11:34 pm
srkinard offline
I applied the macOS 10.12.3 update which restarted the machine...it's behaved since. I'll keep an eye on it.
If I see the error again I'll kick on debugging and update you here.
Thanks Adam!
Ross
Tue Jan 24, 2017 11:44 pm
Sounds good - if it reoccurs, we'll get to the bottom of it. I'm all but positive that somehow the plugin was stopped (maybe it crashed or crashed and didn't fully restart) and thus was in a bad state where it was no longer listening for the commands.
Adam
Sun Jan 29, 2017 1:10 am
srkinard offline
Been solid since, so I believe we can just call it a hiccup.
Ross
