Variable in controlpage not updating
Fri May 01, 2015 3:48 am
MortenB offline
Hi
I have a controlpage that has a button that changes a variable. If I look at the variable it is being changed as wanted but the problem is that I display the variable
below the button and there it only updates if I touch the screen or if I go in to the controlpage in design-mode and saves it.
I use the DomoPad app but unshure if the problem is in that app or if it is the controlpage itself that is the problem.
If I pull up the controlpage in the browser it seems to work fine so maybe it is a bug in the DomoPad app?
Mac Mini with Indigo 6 - Testing Indigo 7
18 Qubino dimmers
6 Fibaro dimmers (v2)
13 Fibaro Smoke Sensors
13 HeatIt floor thermostats
Also running Node Red and OpenHab2
Fri May 01, 2015 5:45 am
RogueProeliator offline
Re: Variable in controlpage not updating
I am pretty sure this is a refresh bug/issue - it looks like updating the text on a view does not automatically trigger that part of the screen to refresh if any scaling is being done. I found this literally a day or two ago and have it on my log to fix up hopefully before the next release.
Adam
Fri May 01, 2015 10:04 am
MortenB offline
Hi
I can also mention that I scale my pages so it uses scaling as well.
18 Qubino dimmers
