Pushover Plugin - push notifications
Fri Nov 28, 2014 10:28 pm
vasisht offline
Re: Pushover Plugin - push notifications
OK took a very long time - but finally figured out how to send a pushover alert with python, so I removed my prior questions.
Here's my code for anyone else who is interested in replicating this
def sendAlert(alert, priority=0):
          alertPlugin = indigo.server.getPlugin('io.thechad.indigoplugin.pushover')
          if alertPlugin.isEnabled():
                    indigo.server.log('pushover plugin is available')
                    alertProps = {  'msgTitle'       :      'Home automation server',
                                        'msgBody'        :      alert,
                                        'msgSound'       :      'pushover',
                                        'msgPriority'    :      priority,
                                        'msgDevice'      :      '',
                                        'msgSupLinkUrl'  :      '',
                                        'msgSupLinkTitle':      ''
                    alertPlugin.executeAction("send", props=alertProps)
                    indigo.server.log('pushover plugin is not available')
Sun Dec 14, 2014 2:56 pm
edrabbit offline
Running into a bit of a weird problem.
Running Indigo 6.0.16 on OS X 10.9.5
Installed v1.1.2 of Pushover plugin (https://github.com/IndigoDomotics/indig ... tag/v1.1.2)
Set things up, working great, did not try variable substitution.
Downloaded and upgraded to marceltrapman's v2.0.5 (https://github.com/IT2BE/indigo-pushover/tree/v2.0.5) because I wanted to support multiple keys.
Created a simple test Action to try sending a message with a variable that tells me the score of my cat bathroom using a variable "cat_bathroom_score". (More info)
Message is simply:
Cat Bathroom score is too damn high %%v:cat_bathroom_score%%
I try executing from the Indigo client manually to test, and it does not give any errors, however I never receive a push notification. As far as I can tell it never gets to Pushover's server.
If I try to open up the Action and click "Edit Action Settings" the dialog for setting title/message/etc doesn't show and eventually I see the following in the Event Log:
Error (client)                  timeout waiting for plugin response from io.thechad.indigoplugin.pushover for request UiGetValues2
  Error (client)                  timeout waiting for plugin response from io.thechad.indigoplugin.pushover for request CallPluginFunc
  Error (client)                  dialogForActionId() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
I'm unable to get to the Edit Action Settings dialog both from a client on the same machine as the server as well as a remote client on another machine running OS X 10.9.5. I have to restart the Indigo Server in order to go back in and edit the action settings. Then it works fine until I try to execute it and then I have to restart again. I upgraded to Indigo 6.0.18 in case it was a bug in Indigo, but same behavior.
If I remove "%%v:cat_bathroom_score%%" from the message, push works totally fine. Looks like either I'm doing something wrong, or there's some errors that aren't being handled, or something.
Sun Dec 14, 2014 2:58 pm
edrabbit offline
Of course I forgot to mention my appreciation for such a useful plugin! Thanks to everyone putting in work on this. It really changes things for me and my house. :D
Wed Dec 31, 2014 8:21 am
DrLove offline
Hi, great plug in!
Is it possible to send messages to more than one client and not all? Say iPhone1 and iPhone2 but not iPad3?
Tested w/ iPhone1,iPhone2 and iPhone1;iPhone2 but all clients receive the message.
Best regards, L
Love Kull (yes it's my name)
Blog (in Swedish)
Sweden
Thu Jan 15, 2015 7:02 am
richo offline
Unfortunatelly I also have problems with variables. If I insert it either in the title or body Pushover plugin hangs for a while and I get the following message in the log:
Anything can be done? I desperately need it working :(
Ryszard
Tue Jan 20, 2015 3:47 am
MarcoGT offline
I haven't looked at docs yet (I have downloaded it).
Does it send push notifications also via Internet?
Sun Feb 15, 2015 1:22 pm
davinci offline
Indigo almost crashes when using variables in the pushover plugin.
It recovers with this message:
Tue May 05, 2015 1:51 am
MarcoGT offline
As far as I understood, the pushover account is free for only 7 days, right?
Wed May 20, 2015 12:32 am
MarcoGT offline
Bought the iOS license, installed and configured, working like a charm.
Wonderful plugin, thanks :)
Thu May 21, 2015 4:26 pm
markf424 offline
Agreed - so glad to be done with the Google SMS method of alerting. Pushover is much more powerful, with the time of day alerts, specific sounds, etc.
Wed Jun 03, 2015 2:41 pm
markf424 offline
Also a note to those having trouble with the variable substitution - make sure you're using the variable ID instead of the name. That is, your substitution should look like:
%%v:54353621%%
and not
%%v:hotPotato%%
The plugin doesn't validate this field and that's why it dies with the error listed above in the thread.
Fri Jul 10, 2015 8:29 pm
discgolfer1138 offline
So glad to see folks are finding this useful! Sorry I haven't had any free time to update it, but it sounds like Marcel and others have adopted it. Huge thanks to them for their hard work :)
Indigo 6.1.0 | Mac Mini | OS 10.10.3 (Yosemite)
Fork Me on GitHub!
Thu Jul 16, 2015 11:38 pm
MarcoGT offline
Yesterday I had a strange behaviour.
I was testing my alarm system.
I have a trigger on a movement sensor, and when it gets breached:
- it send email + pushover notification
- it sets the variable alarmStatus to "fault"; this variable change triggers another trigger which sends e-mail+pushover notification.
I do not understand why I only got the second pushover notification (if I test the first alone, without the second trigger everything is fine).
Why?
Pushover does not accept two notifications in a short time?
Marco
Fri Jul 17, 2015 2:30 am
DrLove offline
I've seen this behavior to. I had to put a delay between the events :/
Blog (in Swedish)
Sweden
Fri Jul 17, 2015 5:45 am
MarcoGT offline
Thanks for the confirmation.
By the way, in the Indigo logs I see that both Pushover notification have been sent, but I receive only one...
Page 4 of 13 1, 2, 3, 4, 5, 6, 7 ... 13
