Pushover Plugin - push notifications
Sat Feb 23, 2019 11:37 am
Dual offline
Re: Pushover Plugin - push notifications
dduff617 wrote:
if your energy meter usage value is a property of an indigo device, then you can use the syntax "%%d:nnnnnn:stateid%%", where you would replace "nnnnnn" with the numeric deviceID and "stated" with the name of the state.
Exactly what I needed. Thanks!
Tue Mar 26, 2019 12:36 am
Dual offline
FlyingDiver wrote:
If it's a device state, then you can do that substitution as well.
Is there a link to a list of all possible substitutions and their syntax? A user manual of sorts?
Cheers
John
Tue Mar 26, 2019 7:38 am
FlyingDiver online
There's only variable substitutions and device state substitutions, both of which are described in the last few posts in this thread.
Tue Mar 26, 2019 8:15 am
Dual offline
Thanks! Pushover is awesome. I am using it extensively. Great plugin!
Tue Jul 02, 2019 1:11 am
Dual offline
When entering my message in the Message field how do I include a carriage return (line feed) in my message so I can delineate my message across several lines?
John
Tue Jul 02, 2019 2:27 am
racarter offline
I don't know of a way to do it via the plugin menu dialogue, but you can do it in a Python script:
alertPlugin = indigo.server.getPlugin('io.thechad.indigoplugin.pushover')
if alertPlugin.isEnabled():
   msgTitle = "Test"
   message = "Hello\nsailor"
      alertProps = {'msgTitle':msgTitle, 'msgBody':message, 'msgSound':'pushover', 'msgPriority':0, 'msgDevice':'', 'msgSupLinkUrl':'', 'msgSupLinkTitle':''}
      alertPlugin.executeAction("send", props=alertProps)
   except:
      indigo.server.log('Message send error', isError=True)
   indigo.server.log('Pushover plugin not available', isError=True)
Tue Jul 02, 2019 8:17 am
whmoorejr offline
If you have a multi-line text field saved as a variable, you can use that variable in the pushover message and it will do the carriage returns.
If you are going to have to write a script to build the variable first, either include sending the pushover message from that script or add a slight delay to allow the script to run before the pushover plugin fires.
Most of my pushover actions are currently done via python script outside of the plugin so I can segregate my notifications by type. I've created Application APIs for various subjects (Climate, Security, Network, Motion, Access Control, etc.)
This is one I use with the Fing plugin to notify me via email, pushover and indigo log entry when a new device joins my network. (I stole this from someone else on the forum... credit to that guy :lol: )
ipDev = indigo.variables["ipDevsNewDeviceNo"]
ipDevVarNumber = ipDev.value.split(";")[0]
devName = ipDev.value.split(";")[1]
dev = indigo.devices[devName]
st = dev.states # shortcut
theSubject = "New device on network: " + st["ipNumber"]
theBody  = "New device on network: "  + st["ipNumber"]     +"\n"
theBody += "MACNumber: "            +st["MACNumber"]       +"\n"
theBody += "hardwareVendor: "       +st["hardwareVendor"]  +"\n"
theBody += "indigoID: "             +str(dev.id)           +"\n"
theBody += "Name : "                +devName               +"\n"
indigo.server.log(theBody)# also send it to the indigo log file
indigo.server.sendEmailTo("YourEmail@gmail.com", subject=theSubject, body=theBody)
import requests
r = requests.post("https://api.pushover.net/1/messages.json", data = {
  "token": "ApplicationToken", #your application token, I used a specific one for network
  "user": "YourPushoverUserNumber",
  "message": theBody
print(r.text)
I hope that helps. FYI, I never figured out how to do a pushover subject line via python.... my script only captures the subject line for the email part of my script.
Bill
My Plugin: My People
Tue Jul 02, 2019 8:28 am
whmoorejr offline
Here is another example (used for letting me know if the thermostat setting change) that creates the message by combining different variable. (of course this references my variables and you'd have to change that)
#Build the message
import datetime
Time = "{date:%H%:%M}".format(date=datetime.datetime.now())
DTG = u"{}_{}".format(Time, Title)
theMode = indigo.variables[143562231].value
isCool = indigo.variables[285071090].value
isHeat = indigo.variables[1231095420].value
Temp = indigo.variables[796298002].value
TheMessage = '%s\n%s at %s\n%s is %s\n%s is %s\n%s is %s' % ("Thermostat Mode Change", theMode, Time, "Cool Setpoint", isCool, "Heat Setpoint", isHeat, "Current Temp", Temp)
indigo.variable.updateValue(195713191, value=TheMessage) # I used this line for testing to see if it was building a message or error-ing out.
#Send Pushover message
import requests
  "token": "YourApplicationToken", # I used a specific application token for climate
  "user": "YourPushoveUserID",
  "message": TheMessage
print(r.text)
Bill
Tue Jul 02, 2019 8:55 am
FlyingDiver online
Please file an enhancement request for a multi-line message text field: https://github.com/IndigoDomotics/indig ... ver/issues
Thu Apr 16, 2020 12:44 am
davinci offline
The plugin is not working anymore for me. Seems like a connection error.
Pushover works over the website directly.
I'm running the latest version 1.5.4.
Pushover Error Error in plugin execution ExecuteAction:
File "plugin.py", line 114, in send
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/api.py", line 111, in post
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/api.py", line 57, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 477, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 587, in send
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/adapters.py", line 467, in send
ConnectionError: ('Connection aborted.', error(54, 'Connection reset by peer'))
Thu Apr 16, 2020 1:43 am
Dual offline
I have a message sent via Pushover every hour. It has failed intermittently over the past several weeks. Yesterday 20 messages succeeded and 4 failed.
Thu Apr 16, 2020 1:46 am
vtmikel offline
The api is down due to a DoS attack.
https://twitter.com/pushoverapp/status/ ... 48416?s=21
Wed Sep 09, 2020 5:57 pm
Dual offline
I have a recurring error from Pushover in my log:
2020-09-08 00:00:06.673   Pushover Error   Error in plugin execution ExecuteAction:
  File "plugin.py", line 121, in send
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 25: ordinal not in range(128)
It appears to be due to the degrees symbol included in my Pushover message:
1.112 kWh energy used
83 °F west temperature
I am using the latest version of Pushover from the Plugin store 1.5.3.
I checked on GitHub (I am not a user of GitHub nor knowledgable re GitHub) and see Issue #26 fix - unicode error ... @FlyingDiver committed on Apr 27, 2019. There is a Release 1.5.4 @FlyingDiver released this on Apr 27, 2019. It is labelled Pre-release.
I am guessing the fix by @FlyingDiver would correct my problem. Why is it pre-release and not available from the Indigo Plugin Store? Can I download it from GitHub somehow and use it with Indigo, replacing version 1.4.3? How do I do this?
Cheers
John
Wed Sep 09, 2020 6:00 pm
FlyingDiver online
Cheers
John
Just go to the Releases section of the GitHub project and download it from there.
I expect I was waiting on testing feedback and no one ever got back to me on it. Let me know if you have any issues.
Wed Sep 09, 2020 7:16 pm
Dual offline
I downloaded and installed the 1.5.4 version.
My notification ran at the top of the hour error free.
Thanks @FlyingDiver for the fix and the help on how to get it from GitHub.
Cheers
John
